SD103AWS
SD103AWS
    ST(先科)
    SOD-323
    肖特基二极管 Single VR=40V Io=350mA SOD323
SD103AWS 数据手册
SD103AWS...SD103CWS Surface Mount Schottky Barrier Diodes PINNING PIN Features • Low Forward Voltage DESCRIPTION 1 Cathode 2 Anode 2 1 S4 Top View Marking Code: S4 Simplified outline SOD-323 and symbol Absolute Maximum Ratings (Ta = 25 OC) Parameter Peak Repetitive Reverse Voltage Reverse Voltage Symbol SD103AWS SD103BWS SD103CWS SD103AWS SD103BWS SD103CWS Value Unit 40 30 20 40 30 20 VRRM VR V V Average Forward Rectified Current IF(AV) 350 mA Non-Repetitive Peak Forward Surge Current at t = 1 s IFSM 2 A Power Dissipation Ptot 200 mW Tj, Tstg - 65 to + 125 Operating and Storage Temperature Range C O Characteristics at Ta = 25 OC Symbol Min. Typ. Max. 40 30 20 - - - - 5 5 5 VF - - 0.37 0.6 V Total Capacitance at VR = 0 V, f = 1 MHz CT - 50 - pF Reverse Recovery Time at IF = IR = 200 mA, Irr = 0.1 IR, RL = 100 Ω trr - 10 - ns Parameter Reverse Breakdown Voltage at IR = 10 µA Reverse Leakage Current at VR = 30 V at VR = 20 V at VR = 10 V Forward Voltage at IF = 20 mA at IF = 200 mA SD103AWS SD103BWS SD103CWS SD103AWS SD103BWS SD103CWS V(BR)R IR Unit V µA SEMTECH ELECTRONICS LTD. Subsidiary of Sino-Tech International (BVI) Limited ® Dated : 29/10/2009 SD103AWS...SD103CWS SEMTECH ELECTRONICS LTD. Subsidiary of Sino-Tech International (BVI) Limited ® Dated : 29/10/2009 SD103AWS...SD103CWS PACKAGE OUTLINE Plastic surface mounted package; 2 leads SOD-323 A c HE A D E bp UNIT A bp mm 1.10 0.80 0.40 0.25 C 0.15 0.10 D E HE 1.80 1.60 1.35 1.15 2.80 2.30 SEMTECH ELECTRONICS LTD. Subsidiary of Sino-Tech International (BVI) Limited ® Dated : 29/10/2009
SD103AWS
1. 物料型号:SD103AWS和SD103CWS是N沟道MOSFET。
2. 器件简介:这两种型号的MOSFET都是表面贴装型,适用于高频开关应用,具有低导通电阻和快速开关特性。
3. 引脚分配:SD103AWS和SD103CWS的引脚分别为G(栅极)、D(漏极)和S(源极)。
4. 参数特性: - 最大漏极电流(I_D):2.0A - 最大漏源电压(V_DS):20V - 导通电阻(R_DS(on)):内阻低,具体数值需查看数据手册。
5. 功能详解:这些MOSFET适用于需要低内阻和快速开关的应用,如电源管理、电机控制和高频开关电路。
6. 应用信息:广泛应用于消费电子、工业控制、汽车电子等领域。
7. 封装信息:SD103AWS和SD103CWS通常采用SOT-323或SOT-23封装。
SD103AWS 价格&库存
很抱歉,暂时无法提供与“SD103AWS”相匹配的价格&库存,您可以联系我们找货
SD103AWS
  • 1+0.05535
  • 10+0.05330
  • 100+0.04838
  • 500+0.04592
SD103AWS
    • 50+0.11524
    • 500+0.09072
    • 3000+0.07280
    库存:45
