MMBT8050C / MMBT8050D (1.5A)
NPN Silicon Epitaxial Planar Transistor
for switching and amplifier applications. Especially
suitable for AF-driver stages and low power output
stages.
The transistor is subdivided into two groups, C and D,
according to its DC current gain. As complementary
type the PNP transistor MMBT8550C and
MMBT8550D (1.5A) is recommended.
SOT-23 Plastic Package
Absolute Maximum Ratings (Ta = 25 OC)
Symbol
Value
Unit
Collector Emitter Voltage
VCEO
25
V
Collector Base Voltage
VCBO
40
V
Emitter Base Voltage
VEBO
6
V
Peak Collector Current
ICM
1.5
A
Power Dissipation
Ptot
200
mW
Junction Temperature
Tj
150
O
Storage Temperature Range
TS
-55 to +150
O
C
C
SEMTECH ELECTRONICS LTD.
(Subsidiary of Sino-Tech International Holdings Limited, a company
listed on the Hong Kong Stock Exchange, Stock Code: 724)
Dated : 20/10/2005
Characteristics at Ta=25 OC
Symbol
Min.
Max.
Unit
MMBT8050C
hFE
100
250
MMBT8050D
hFE
160
400
hFE
40
ICBO
100
nA
IEBO
100
nA
VCE(sat)
0.5
V
VBE(sat)
1.2
V
V(BR)CEO
25
V
V(BR)CBO
40
V
V(BR)EBO
6
V
VBE
1
V
fT
120
MHz
DC Current Gain
at VCE=1V, IC=100mA
at VCE=1V, IC=800mA
Collector Cutoff Current
at VCB=35V
Emitter Cutoff Current
at VEB=6V
Collector Saturation Voltage
at IC=800mA, IB=80mA
Base Saturation Voltage
Collector Emitter Breakdown Voltage
at IC=2mA
Collector Base Breakdown Voltage
at IC=100µA
Emitter Base Breakdown Voltage
at IE=100µA
Base Emitter Voltage
at IC=10mA, VCE=1V
Transition frequency
at VCE=10V, IC=50mA
Dated : 20/10/2005
Typical Characteristics
DC Current Gain
0.5
0.4
I B =3.0mA
I B =2.5mA
0.3
I B =2.0mA
0.2
I B =1.5mA
I B =1.0mA
0.1
I B =0.5mA
0.8
1.2
1.6
2.0
h FE , DC CURRENT GAIN
Ic(mA), COLLECTOR CURRENT
Static Characteristic
VCE=1V
100
10
1
0.1
VCE(V), COLLECTOR-EMITTR VOLTAGE
Base -Emittr Saturation Voltage
Collector-Emitter Saturation Voltage
10000
I C=10I B
VBE(sat)
1000
100
VCE(sat)
10
0.1
1
10
100
1000
I C(mA), COLLECTOR CURRENT
1
10
100
1000
Base-Emitter On Voltage
VBE(sat) , VCE(sat)(mV), SATURATION
VOLTAGE
1000
100
VCE=1V
10
1
0.1
1.0 1.2
VBE (V), BASE-EMITTER VOLTAGE
f T(MHz), CURRENT GAIN
BANDWIDTH PRODUCT
Current Gain Bandwidth Product
1000
VCE=10V
100
10
1
1
10
100
400
Dated : 20/10/2005
很抱歉,暂时无法提供与“MMBT8050D(1.5A)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.27940
- 200+0.09306
- 1500+0.05819
- 3000+0.04620
