MMBTSC3356S
MMBTSC3356S
    ST(先科)
    SOT-23
    NPN Ic=100mA Vceo=12V hfe=125~250 fT=7GHz P=200mW S档 SOT-23
MMBTSC3356S 数据手册
MMBTSC3356 NPN Silicon Epitaxial Planar Transistor for microwave low noise amplifier at VHF, UHF and CATV band The transistor is subdivided into three groups, Q, R and S, according to its DC current gain. SOT-23 Plastic Package Absolute Maximum Ratings (Ta = 25 OC) Parameter Symbol Value Unit Collector Base Voltage VCBO 20 V Collector Emitter Voltage VCEO 12 V Emitter Base Voltage VEBO 3 V Collector Current IC 100 mA Power Dissipation Ptot 200 mW Tj 150 O TStg - 65 to + 150 O Junction Temperature Storage Temperature Range C C Characteristics (Ta = 25 OC) Symbol Min. Typ. Max. Unit hFE hFE hFE 50 80 125 - 100 160 250 - Collector Cutoff Current at VCB = 10 V ICBO - - 1 µA Emitter Cutoff Current at VEB = 1 V IEBO - - 1 µA Gain Bandwidth Product at VCE = 10 V, IC = 20 mA fT - 7 - GHz Feed-Back Capacitance at VCB = 10 V, f = 1 MHz Cre - 0.55 1 pF Noise Figure at VCE = 10 V, IC = 7 mA, f = 1 GHz NF - 1.1 2 dB Parameter DC Current Gain at VCE = 10 V, IC = 20 mA 1) Current Gain Group Q R S 1) The emitter terminal and the case shall be connected to the guard terminal of the three-terminal capacitance bridge. SEMTECH ELECTRONICS LTD. Subsidiary of Sino-Tech International (BVI) Limited ® Dated : 04/10/2006 MMBTSC3356 SEMTECH ELECTRONICS LTD. Subsidiary of Sino-Tech International (BVI) Limited ® Dated : 04/10/2006
MMBTSC3356S 价格&库存
很抱歉,暂时无法提供与“MMBTSC3356S”相匹配的价格&库存,您可以联系我们找货
MMBTSC3356S
  • 20+0.36630
  • 100+0.21850
  • 800+0.15300
  • 3000+0.10920
  • 6000+0.10380
  • 30000+0.09610
库存:2775
MMBTSC3356S
  • 500+0.10690
  • 3000+0.09571
库存:2750
