Negative Temperature Coefficient Resistor
Series
Description
This is a Negative Temperature Coefficient Resistor Whose
resistance changes with ambient temperature changes.
Thermistor comprises 2 or 4 kinds of metal oxides of iron,
nickel, cobalt, manganese and copper, being shaped and
Sintered at high temperature(1200℃ to 1500℃ )
Features
l Small size, large power, strong capacity of suppression of
Applications
inrush current
l Switching power-supply, switch power ,ups power
l Fast resporse
l Electronic energy saving lamps electronic ballast and
l Big material constant(B value),small residual resistance
all kinds of electric heater
l Long life and high reliability
l All kinds of RT, display
l Complete series, wide applications
l Bulb and other lighting lamps
Part Number Code
N
T
1
C
Resistance Value:10Ω
D
1
3
Diameter of Chip: Φ13
Materials
Item
name
Wrapper
Modified phenolic resin
Down-lead
CP Wire
Coating color
Black
Specifications are subject to change without notice.
Please refer to http://www.ruilon.com.cn for current information.
Revised: 2019-04-24
Page:1
Series
Parameters of Technology
Model
R25
(Ω)
Max. steady
State current
(A)
Residual
Resistance
(Ω)
Dissipation
factor
(mw/℃)
Themal time
Constant
(s)
NTC5D-5
5
1
0.35
6
NTC10D-5
10
0.7
0.77
6
NTC60D-5
60
0.5
1.88
6
18
NTC200D-5
200
0.1
18.7
6
18
NTC5D-7
5
2
0.28
10
30
NTC8D-7
8
1
0.54
9
28
NTC10D-7
10
1
0.62
9
27
NTC12D-7
12
1
0.82
9
27
NTC16D-7
16
0.7
1.00
9
27
NTC22D-7
22
0.6
1.11
9
27
NTC33D-7
33
0.5
1.49
10
28
NTC200D-7
200
0.2
11.65
11
28
NTC3D-9
3
4
0.12
11
35
NTC4D-9
4
3
0.19
11
35
NTC5D-9
5
3
0.21
11
34
NTC6D-9
6
2
0.32
11
34
NTC8D-9
8
2
0.40
11
32
NTC10D-9
10
2
0.46
11
32
NTC12D-9
12
1
0.66
11
32
NTC15D-9
15
1
0.80
11
31
NTC20D-9
0.88
11
30
NTC22D-9
22
1
0.95
11
30
NTC33D-9
33
1
1.12
11
30
NTC50D-9
50
1
1.25
11
30
NTC80D-9
80
0.8
2.01
11
30
NTC120D-9
120
0.8
3.02
11
30
NTC200D-9
200
0.5
5.01
11
30
NTC2.5D-11
2.5
5
0.10
13
43
NTC3D-11
3
5
0.10
13
43
NTC4D-11
4
4
0.15
13
44
NTC5D-11
5
4
0.16
13
45
NTC6D-11
6
3
0.24
13
45
NTC8D-11
8
3
0.25
14
47
NTC10D-11
10
3
0.28
14
47
NTC12D-11
12
2
0.46
14
48
NTC16D-11
16
2
0.47
14
50
NTC20D-11
0.51
15
52
NTC22D-11
22
2
0.56
15
52
NTC30D-11
30
1.5
0.67
15
52
NTC50D-11
50
1.5
1.02
15
52
NTC60D-11
60
1.5
1.22
15
52
NTC80D-11
80
1.2
1.66
15
52
Revised: 2019-04-24
Operating
Temperature
-40~+150
-40~+175
Page:2
Series
Model
R25
(Ω)
Max. steady
State current
(A)
Residual
Resistance
(Ω)
Dissipation
factor
(mw/℃)
Themal time
Constant
(s)
NTC1.3D-13
1.3
7
0.06
13
60
NTC2.5D-13
2.5
6
0.088
13
60
NTC3D-13
3
6
0.092
14
60
NTC4D-13
4
5
0.12
15
67
NTC5D-13
5
5
0.125
15
68
NTC6D-13
6
4
0.17
15
65
NTC7D-13
7
4
0.188
15
65
NTC8D-13
8
4
0.194
15
65
NTC10D-13
10
4
0.206
15
65
NTC12D-13
12
3
0.316
16
65
NTC15D-13
15
3
0.335
16
65
NTC18D-13
18
3
0.372
16
65
NTC20D-13
0.372
16
65
NTC30D-13
30
2.5
0.517
16
65
NTC47D-13
47
2
0.81
17
65
NTC2.5D-15
2.5
8
0.071
18
76
NTC3D-15
3
7
0.075
18
76
NTC5D-15
5
6
0.112
NTC6D-15
6
5
0.155
NTC7D-15
7
5
0.173
NTC8D-15
8
5
0.178
NTC10D-15
10
5
0.18
NTC12D-15
12
4
0.25
NTC15D-15
15
4
0.268
21
85
NTC20D-15
0.288
17
86
NTC30D-15
30
3.5
0.438
18
75
NTC47D-15
47
3
0.68
21
86
NTC50D-15
50
3
0.72
21
86
NTC1.3D-20
1.3
9
0.037
24
113
NTC2.5D-20
2.5
8
0.049
24
113
NTC3D-20
3
8
0.055
24
113
NTC5D-20
5
7
0.087
23
113
NTC8D-20
8
6
0.142
25
114
NTC10D-20
10
6
0.162
24
114
NTC12D-20
12
5
0.195
24
114
NTC16D-20
16
5
0.212
25
115
NTC20D-20
0.231
26
115
Revised: 2019-04-24
Operating
Temperature
-40~+200
Page:3
Series
Storage condition
Temperature
-10℃~+40℃
Humidity
≤70%RH
Term
≤12 months (First-in/ First-out)
1.
Do not exposing the components to the following
conditions, otherwise, it may result in deterioration of
characteristics
Place
2.
Corrosive gas or deoxidizing gas
3.
Flammable and explosive gases
4.
Oil, water and chemical liquid
5.
Under the sunlight
Notes: Do not apply the components under the following conditions, otherwise, it may result in deterioration of characteristics, destruction of components orin the
worst case to catching fire:1. Exceeding Imax
2. Exceeding rated temperature range
3. Inferior thermal dissipation,Due to badly inferior thermal dissipation,
some part of the components body will become overheated and then be damaged
properties of products
Mechanical Characteristics
Item
Solder-ability
Specification
Test Conditions & Methods
The terminals shall be uniformly
tinned, and its area≥95%
Dipping the NTC terminals to a depth of 15mm in a soldering
bath of 240-245℃ and to the place of 6mm far from NTC
body for 2-3s (See IEC68-2-20 /GB2423.28 Ta )
Resistance To Soldering
No visible mechanical damage.
Heat
ΔR/RN ≤20% (ΔR =∣RN-RN'∣)
bath of 265±5℃ and to the place for 6mm below from NTC
body for 10±1s.After recovering 4-5h under 25±2℃. The
rated zero power resistance value RN' shall be measured.
(See IEC68-2-20 /GB2423.28 Tb)
Fasten the body and apply a force gradually to each lead
until 10N and then keep for 10sec, Hold body and apply a
force to each lead until 90°slowly at 5N in the direction of
Strength of lead terminal
No break out ΔR/RN ≤20%
(ΔR =∣RN-RN'∣)
lead axis and then keep for 10sec, and do this in the
opposite direction repeat for other terminal. After recovering
4~5h under 25±2℃, the rated zero power resistance value
RN' shall be measured. (See IEC68-2-21/GB2423.29 Ua /
Ub)
Revised: 2019-04-24
Page:4
Series
Electrical Characteristics
Item
Rated Zero-Power
Resistance RN (Ω)
Specification
Ambient temp. Range:25℃±2℃(TA).
RN±20%
Testing voltage: 1.5VDC After placing for 1~2 hours under
TA, the resistance value shall be measured
The thermal dissipation constant(δ) could be calculated by
Thermal Dissipation
Constant δ (mW/℃)
the ratio of a change in power dissipation(ΔP) of the
≥17
thermistor to a change in temperature(ΔT) of the thermistor
at a specified ambient temperature
Thermal Time Constant
T(s)
Material Constant B
Max. Steady State
Current (A)
The time(τ shall be measured within which the temperature
≤80
change of NTC thermistor is reached at 63.2% of the
ambient temperature change under zero power condition
B=T1T2/( T2- T1) × Ln
R1 , R2 is zero-power resistance at T1 , T2
(R1/R2)
T1 = 298.15 K(25℃) T2 = 323.15 K(50℃)
ΔRN / RN ≤20%
ambient temperature:25℃±2℃
Testing Time: min 100h
(ΔR =∣RN-RN'∣)
Reliability Test
Item
Specification
Temp. Cycling Testing
ΔRN / RN ≤20%
Ta:-40±3℃/ 30min→25±2℃/ 5min→Tb:200±3℃/30min→
25±2℃/ 5min Cycles: 5times After recovering 4~5 h under
25±2℃, the rated zero power resistance value RN' shall be
(ΔR =∣RN-RN'∣)
measured.
Ambient temp. Range:25℃±2℃.
Electrical Cycling Testing
ΔRN / RN ≤20%
Cycles: 1,000times On / Off: 1m / 5m
Test Current: 6.0A
(ΔR =∣RN-RN'∣)
After recovering 4~5h under 25±2℃, the rated zero power
LoadLife ( Endurance )
Testing
Humidity Testing
ΔRN / RN ≤20%
Ambient temp. Range:25℃±2℃; 6.0A/ 1,000±24h After
recovering 4~5 h under 25±2℃, the rated zero power
(ΔR =∣RN-RN'∣)
Ambient temp. range : 40℃±2℃,R.H.:93±3% , Energized
ΔRN / RN ≤20%
time:1000±24 h After recovering 4~5 h under 25±2℃, the
(ΔR =∣RN-RN'∣)
Revised: 2019-04-24
Page:5
Series
Graph of Characteristics
Figure 1 - Graph of Resistance vs. Temperature
Figure 2 - Graph of Voltage vs. Current
2
100
1
Voltage (V)
Resistance (Ω)
10
1.0
0.5
0.2
0.1
0.1
-40 -20 0
60
80 100
120 140 160
180 200
0.01
0.02
0.05
0.1
Temperature (℃)
0.2
0.5
1
2
5
10
Current (A)
Product Dimensions
Marking
Marking
Dimensions(mm)
Dimension
D(max)
T(max)
Φd±0.05
F1±1
F2±1.5
7
5
0.55
5
3
NTCxxD-5
NTCxxD-7
9
5
0.55
5
3
NTCxxD-9
11
5.5
0.75 / 0.55
7.5 / 5
5/3
NTCxxD-11
13
5.5
0.75
7.5 / 5
5/3
NTCxxD-13
15.5
6
0.75
7.5
5
NTCxxD-15
17.5
6
0.75
10 / 7.5
5
NTCxxD-20
22.5
7
1
10 / 7.5
Straight Lead Wire
Curved Lead Wire
L(min)
L1±1
L2±2
15
3.0~20
7/4
15
Packaging
Dimension
Bag (pcs)
Inside the box (pcs)
carton (pcs)
NTCxxD-5
1000
3000
18000
NTCxxD-7
1000
3000
18000
NTCxxD-9
500
2000
12000
NTCxxD-11
500
1500
9000
NTCxxD-13
250
1000
6000
NTCxxD-15
250
1000
6000
NTCxxD-20
100
400
2400
Revised: 2019-04-24
Page:6
很抱歉,暂时无法提供与“NTC5D-15”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.99364
- 50+1.56734
- 250+1.25815
- 500+1.03024
- 国内价格
- 5+2.19708
- 50+1.72728
- 250+1.38654
- 500+1.13538
- 2500+1.02354
- 5000+0.95634
