1N4148WS
Reverse Voltage 100 Volts
Forward Current - 0.15 Ampere
FAST SWITCHING DIODES
Features
SOD-323
Fast switching speed
Surface mount package ideally suited
for automatic insertion
0.016(0.40)
0.057(1.45)
0.007(0.20)
0.043(1.10)
For general purpose switching applications
High conductance
0.008(0.20)max.
Cathode bar
0.071(1.80)
0.063(1.40)
0.110 (2.80)
0.024 (0.60)
0.014 (0.35)
Absolute Maximum Ratings at 25 °C
0.0019 (0.05)
0.006 (0.15)
0.0079 (0.20)
9°
0.016 (0.45)
0.008 (0.2 )
Case: JEDEC SOD-323 molded plastic body
Terminals: Plated leads solderable per MIL-STD-750,
Method 2026
Polarity: Polarity symbols marked on case
Weight : 0.0007 ounce, 0.02 grams
Marking: T4
0° to
0.043 (1.10)
Mechanical Data
0.032 (0.80)
0.098 (2.50)
Dimensions in inches and (millimeters)
SYMBOLS
1N4148WS
VRRM
100
VRMS
V
V(BR)R
75
75
Forward continuous current
IFM
300
mA
Average rectified output current
IO
150
0.5
1
4.0
mA
PARAMETER
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Reverse Breakdown voltage at IR=1 μA
Peak forward current at 1s
at 1ms
at 1us
Power dissipation
IFSM
UNITS
A
400
mW
RΘJA
250
°C/W
Junction temperature
Tj
-55 to +150
C
Storage temperature
TSTG
-55 to +150
C
Thermal resistance junction to ambient
Pd
Characteristics at Ta= 25 °C
PARAMETER
Forward voltage
Reverse current
Max.
Unit
Conditions
VF1
0.715
V
IF=1.0mA
VF2
0.855
V
IF=10mA
VF3
1.0
V
IF=50mA
VF4
1.25
V
IF=150mA
IR1
0.025
SYMBOLS
Min.
Typ.
uA
a t VR= 2 0 V
1
uA
a t VR= 7 5 V
T j= 2 5
IR3
30
uA
uA
a t VR= 2 5 V
T j= 1 5 0
°C
a t VR= 7 5 V
T j= 1 5 0
°C
IR4
50
Capacitance between terminals
CT
2
pF
Reverse recovery time
trr
4
ns
http://www.microdiode.com
T j= 2 5°C
IR2
Rev:2025A5
°C
VR=0V,f=1.0MHz
IF=IR=10mA
Irr=0.1XIR,RL=100
Page :1
1N4148WS
Typical Characterisitics
Forward
200
Characteristics
Reverse
1000
Characteristics
100
(nA)
(mA)
Ta=100℃
0.1
0.01
0.0
0.2
0.4
0.6
FORWARD VOLTAGE
0.8
VF
1.0
Ta=25℃
10
1
1.2
(V)
REVERSE VOLTAGE
Capacitance Characteristics
1.2
100
REVERSE CURRENT IR
1
T=
a 2
5℃
FORWARD CURRENT
IF
T=
a 1
00
10
60
VR
80
(V)
Power Derating Curve
600
Ta=25℃
PD
(mW)
500
POWER DISSIPATION
CAPACITANCE BETWEEN TERMINALS
CT (pF)
f=1MHz
1.0
400
300
200
100
0.8
10
REVERSE VOLTAGE
15
VR
(V)
50
75
AMBIENT TEMPERATURE
100
Ta
125
150
The curve above is for reference only.
Rev:2025A5
Page :2
1N4148WS
Packing information
P0
unit:mm
P1
d
Item
E
F
B
A
W
Carrier width
Carrier length
Carrier depth
Sprocket hole
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
P
D2
T
D1
C
W1
D
Symbol
Tolerance
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
SOD-323
2.1
4.0
1.60
1.55
178.00
50.0
13.00
1.75
3.50
4.00
4.00
2.00
0.25
8.15
10.5
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
CARTON
SIZE
(m/m)
CARTON
(pcs)
SOD-323
7"
3,000
4.0
45,000
190*190*190
178
400*400*220
180,000
APPROX.
GROSS WEIGHT
(kg)
Suggested Pad Layout
Symbol
Unit (mm)
Unit (inch)
A
0.028
B
0.7
0.7
C
2.15
0.085
D
1.45
0.057
E
2.85
0.112
0.028
Important Notice and Disclaimer
Microdiode Semiconductor(Shenzhen) reserves the right to make changes to this document and its products and specifications at
any time without notice. Customers should obtain and confirm the latest product information and specifications before final design,
purchase or use.
Microdiode Semiconductor(Shenzhen) makes no warranty, representation or guarantee regarding the suitability of its products for
any particular purpose, not does Microdiode Semiconductor(Shenzhen) assume any liability for application assistance or
customer product design. Microdiode Semiconductor(Shenzhen) does not warrant or accept any liability with products which are
purchased or used for any unintended or unauthorized application.
No license is granted by implication or otherwise under any intellectual property rights of Microdiode Semiconductor(Shenzhen).
Microdiode Semiconductor(Shenzhen) products are not authorized for use as critical components in life support devices or
systems without express written approval of Microdiode Semiconductor(Shenzhen).
Rev:2025A5
Page :3
很抱歉,暂时无法提供与“1N4148WS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.17020
- 200+0.05681
- 1500+0.03542
- 3000+0.02818
- 国内价格
- 50+0.05714
- 500+0.05314
- 3000+0.03338
- 6000+0.03208
- 24000+0.03089
- 51000+0.03024
- 国内价格
- 1000+0.03729
- 3000+0.02735
- 国内价格
- 20+0.03141
- 200+0.02937
- 500+0.02733
- 1000+0.02529
- 3000+0.02427
- 6000+0.02284
- 国内价格
- 50+0.05710
- 500+0.05290
- 3000+0.03320
- 6000+0.03180
- 24000+0.03060
- 51000+0.03000
