SF11 THRU SF18
Reverse Voltage - 50 to 600 Volts
Forward Current - 1.0 Ampere
SUPER FAST RECTIFIER
Features
DO-41
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0 Idea
for printed circuit board
1.0 (25.4)
MIN.
Super fast switching for high efficiency
Low reverse leakage
High forward surge current capability
0.107(2.7)
0.080(2.0)
DIA.
High temperature soldering guaranteed
0.205(5.2)
0.166(4.2)
250℃/ 10 seconds at terminals
Mechanical Data
1.0 (25.4)
MIN.
Case : JEDEC DO-41 Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.012 ounce, 0.33 grams
0.025(0.64)
0.020(0.53)
DIA.
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unlss otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TA=55℃
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
VRRM
V RMS
V DC
MDD
SF11
MDD
SF12
MDD
SF13
MDD
SF14
MDD
SF15
MDD
SF16
MDD
SF18
UNITS
50
100
70
100
150
105
150
200
140
200
300
210
300
400
280
400
600
420
600
V
V
V
35
50
I(AV)
1.0
A
IFSM
30.0
A
Maximum instantaneous forward voltage at 1.0A
Maximum DC reverse current
TA=25℃
at rated DC blocking voltage
TA=100℃
VF
IR
5.0
50.0
μA
Maximum reverse recovery time
trr
35
ns
(NOTE 1)
Typical junction capacitance (NOTE 2)
Typical thermal resistance (NOTE 3)
Operating junction and storage temperature range
CJ
0.95
1.25
15.0
10.0
1.7
V
pF
RθJA
60.0
℃/W
TJ,T STG
-65 to +150
Note:1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A
2.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
3.Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length,P.C.B. mounted
http://www.microdiode.com
Rev:2024A1
Page :1
SF11 THRU SF18
FIG. 1- FORWARD CURRENT DERATING CURVE
1.0
0.8
0.6
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
0.4
0.2
50
75
100
125
150
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
Ratings And Characteristic Curves
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
30
25
10
175
5.0
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
1
10
AMBIENT TEMPERATURE, C
NUMBER OF CYCLES AT 60 Hz
TJ=25 C
PULSE WIDTH=300 µs
1%DUTY CYCLE
1
0.1
SF11-SF14
SF15-SF16
SF18
0.01
0.8
1.2
1.6
1.8
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MICROAMPERES
INSTANTANEOUS FORWARD
CURRENT,AMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
10
1,000
100
10
TJ=100 C
1
0.1
TJ=25 C
0.01
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
TJ=25 C
10
SF11-SF14
SF15-SF18
TRANSIENT THERMAL IMPEDANCE,
C/W
FIG. 5-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE, pF
60
80
100
PERCENT OF PEAK REVERSE VOLTAGE,%
200
100
100
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
0.1
1
10
100
1
0.1
1.0
10
REVERSE VOLTAGE,VOLTS
100
t,PULSE DURATION,sec.
The curve above is for reference only.
Rev:2024A1
Page :2
很抱歉,暂时无法提供与“SF18”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.08757
- 30+0.08442
- 100+0.07812
- 500+0.07182
- 1000+0.06867
- 国内价格
- 20+0.31000
- 100+0.18490
- 500+0.12950
- 5000+0.09250
- 10000+0.08790
- 50000+0.08140
- 国内价格
- 10+0.17140
- 100+0.13403
- 300+0.11330
- 1000+0.10088
- 5000+0.08759
- 10000+0.08187
