SF26
SF26
    MDD(辰达半导体)
    DO-15(DO-204AC)
    快/超快恢复二极管 VR=400V IF=2A VF=1.25V IR=5uA trr=35nS
SF26 数据手册
SF21 THRU SF28 Reverse Voltage - 50 to 600 Volts Forward Current - 2.0 Ampere SUPER FAST RECTIFIERS Features DO-15  The plastic package carries Underwriters Laboratory Flammability Classification 94V-0  Idea for printed circuit board 1.0 (25.4) MIN.  Super fast switching for high efficiency  Low reverse leakage  High forward surge current capability 0.140(3.6) 0.104(2.6) DIA.  High temperature soldering guaranteed: 0.300(7.6) 0.230(5.8) 250℃/ 10 seconds at terminals Mechanical Data 1.0 (25.4) MIN. Case : JEDEC DO-15 Molded plastic body Terminals : Solder plated, solderable per MIL-STD-750,Method 2026 Polarity : Polarity symbol marking on body Mounting Position : Any Weight : 0.014 ounce, 0.40 grams 0.034(0.86) 0.028(0.70) DIA. Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25°C ambient temperature unlss otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. Parameter SYMBOLS Marking Code Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage V RMM V RMS V DC Maximum average forward rectified current at TA=55℃ Peak forward surge current 8.3ms single half sine-wave superimposed onrated load (JEDEC Method) MDD SF21 MDD SF22 MDD SF23 MDD SF24 MDD SF25 MDD SF26 MDD SF28 UNITS 50 100 70 100 150 105 150 200 140 200 300 210 300 400 280 400 600 420 600 V V V 35 50 I(AV) 2.0 A IFSM 50.0 A Maximum instantaneous forward voltage at 2.0A Maximum DC reverse current TA=25℃ at rated DC blocking voltage TA=100℃ VF IR 5.0 50.0 μA Maximum reverse recovery time trr 35 ns (NOTE 1) CJ Typical junction capacitance (NOTE 2) Typical thermal resistance (NOTE 3) Operating junction and storage temperature range 0.95 1.25 60.0 30.0 1.7 V pF RθJA 50.0 ℃/W TJ,T STG -65 to +150 ℃ Note: 1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A 2. Measured at 1MHz and applied reverse voltage of 4.0V D.C. 3. Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length,P.C.B. mounted http://www.microdiode.com Rev:2024A1 Page :1 SF21 THRU SF28 Reverse Voltage - 50 to 600 Volts Forward Current - 2.0 Ampere FIG. 1- FORWARD CURRENT DERATING CURVE 2.0 1.6 1.2 Single Phase Half Wave 60Hz Resistive or inductive Load 0.8 0.4 0 0 25 50 75 100 125 150 PEAK FORWARD SURGE CURRENT, AMPERES AVERAGE FORWARD RECTIFIED CURRENT, AMPERES Ratings And Characteristic Curves FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT 50 40 30 20 8.3ms SINGLE HALF SINE-WAVE (JEDEC Method) 10 175 0 1 10 AMBIENT TEMPERATURE, C NUMBER OF CYCLES AT 60 Hz 20 TJ=25 C PULSE WIDTH=300 µs 1%DUTY CYCLE 1 0.1 SF21-SF24 SF25-SF26 SF28 0.01 0 0.4 0.8 1.2 1.6 1.8 FIG. 4-TYPICAL REVERSE CHARACTERISTICS INSTANTANEOUS REVERSE CURRENT, MICROAMPERES INSTANTANEOUS FORWARD CURRENT,AMPERES FIG. 3-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 10 1,000 100 10 TJ=100 C 1 0.1 TJ=25 C 0.01 INSTANTANEOUS FORWARD VOLTAGE, VOLTS TJ=25 C 10 SF21-SF24 SF25-SF28 TRANSIENT THERMAL IMPEDANCE, C/W FIG. 5-TYPICAL JUNCTION CAPACITANCE JUNCTION CAPACITANCE, pF 0 20 40 60 80 100 PERCENT OF PEAK REVERSE VOLTAGE,% 200 100 100 FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE 100 10 1 0.1 0.01 0.1 1 10 100 1 0.1 1.0 10 REVERSE VOLTAGE,VOLTS 100 t,PULSE DURATION,sec. The curve above is for reference only. http://www.microdiode.com Rev:2024A1 Page :2
很抱歉,暂时无法提供与“SF26”相匹配的价格&库存,您可以联系我们找货
SF26
  • 5+0.08640
  • 50+0.08540
  • 150+0.08320
库存:917
SF26
  • 1+0.09548
  • 10+0.08778
  • 30+0.08624
  • 100+0.08162
库存:490
SF26
  • 20+0.16533
  • 250+0.12623
  • 1000+0.10672
  • 2500+0.10565
库存:3990
