SF31 THRU SF38
Reverse Voltage - 50 to 600 Volts
Forward Current - 3.0 Ampere
SUPER FAST RECTIFIERS
Features
DO-201AD
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
Idea for printed circuit board
1.0 (25.4)
MIN.
Super fast switching for high efficiency
Low reverse leakage
High forward surge current capability
0.220(5.6)
0.197(5.0)
DIA.
High temperature soldering guaranteed:
0.375(9.5)
0.285(7.2)
250℃/ 10 seconds at terminals
Mechanical Data
1.0 (25.4)
MIN.
Case : JEDEC DO-201AD Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.04 ounce, 1.1 grams
0.052(1.3)
0.048(1.2)
DIA.
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unlss otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
MDD
SF31
MDD
SF32
MDD
SF33
MDD
SF34
MDD
SF35
MDD
SF36
MDD
SF38
UNITS
VRRM
V RMS
V DC
50
100
70
100
150
105
150
200
140
200
300
210
300
400
280
400
600
420
600
V
V
V
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TA=55℃
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
35
50
I(AV)
3.0
A
IFSM
125.0
A
Maximum instantaneous forward voltage at 3.0A
Maximum DC reverse current
TA=25℃
at rated DC blocking voltage
TA=100℃
VF
IR
10.0
50.0
μA
Maximum reverse recovery time
trr
35
ns
(NOTE 1)
CJ
Typical junction capacitance (NOTE 2)
Typical thermal resistance (NOTE 3)
Operating junction and storage temperature range
0.95
1.25
100.0
50.0
1.7
V
pF
RθJA
30.0
℃/W
TJ,T STG
-65 to +150
Note: 1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A
2. Measured at 1MHz and applied reverse voltage of 4.0V D.C.
3. Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length,P.C.B. mounted
http://www.microdiode.com
Rev:2024A1
Page :1
SF31 THRU SF38
FIG. 1- FORWARD CURRENT DERATING CURVE
3.0
2.4
1.8
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
1.2
0.6
50
75
100
125
150
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
Ratings And Characteristic Curves
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
125
100
75
50
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
25
175
10
AMBIENT TEMPERATURE, C
NUMBER OF CYCLES AT 60 Hz
TJ=25 C
PULSE WIDTH=300 µs
1%DUTY CYCLE
1
0.1
SF31-SF34
SF35-SF36
SF38
0.01
0.8
1.2
1.6
1.8
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MICROAMPERES
INSTANTANEOUS FORWARD
CURRENT,AMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
10
1,000
100
10
TJ=100 C
1
TJ=25 C
0.1
0.01
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
TJ=25 C
SF31-SF34
SF35-SF38
TRANSIENT THERMAL IMPEDANCE,
C/W
FIG. 5-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE, pF
60
80
100
PERCENT OF PEAK REVERSE VOLTAGE,%
400
200
100
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
0.1
1
10
100
2
0.1
1.0
10
REVERSE VOLTAGE,VOLTS
100
t,PULSE DURATION,sec.
The curve above is for reference only.
Rev:2024A1
Page :2
SF31 THRU SF38
Package Information
Taping Specifications
Item
Symbol
Specifications(mm)
Component Pitch
A
10.0±0.5
Inner Tape Pitch
B
52.4±1.5
Component alignment
Z
1.2 Max
Tape width
T
6.0±0.5
Exposed adhesive
E
0.8 Max
Body eccentricity
L1-L2
1.0 Max
Ammunition Package Specifications
Package
Inner Box Size
(mm)
QTY/Box
(pcs)
Carton Size
(mm)
Q'TY/Carton
(pcs)
DO - 201AD
255*74*145
1000
410*275*340
10000
Bulk Package Specifications
Package
Inner Box Size
(mm)
QTY/Box
(pcs)
Carton Size
(mm)
Q'TY/Carton
(pcs)
DO - 201AD
198*86*21
200
460*220*250
10000
Rev:2024A1
Page :3
很抱歉,暂时无法提供与“SF34”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+1.01210
- 100+0.60380
- 500+0.42260
- 1000+0.30190
- 2000+0.28680
- 10000+0.26560
- 国内价格
- 5+0.51225
- 50+0.40490
- 150+0.35122
- 1000+0.31104
- 2000+0.27886
- 5000+0.26277
- 国内价格
- 10+0.46956
- 100+0.37115
- 200+0.32195
- 400+0.31712
- 1000+0.28512
