US2A-SMB
US2A-SMB
    MDD(辰达半导体)
    SMB(DO-214AA)
    VR=50V IF=2A 28pF Trr=50ns
US2A-SMB 数据手册
US2A THRU US2M SURFACE MOUNT ULTRA FAST RECTIFIER Reverse Voltage - 50 to 1000 Volts Forward Current - 2.0 Amperes SMB/DO-214AA FEATURES The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 For surface mounted applications Ultra fast switching for high efficiency Low reverse leakage Built-in strain relief,ideal for automated placement High forward surge current capability High temperature soldering guaranteed: 250 C/10 seconds at terminals 0.155(3.94) 0.130(3.30) 0.087 (2.20) 0.071 (1.80) 0.180(4.57) 0.160(4.06) 0.012(0.305) 0.006(0.152) MECHANICAL DATA 0.096(2.44) 0.084(2.13) 0.060(1.52) 0.030(0.76) Case: JEDEC DO-214AA molded plastic body Terminals: Solder plated, solderable per MIL-STD-750, Method 2026 Polarity: Color band denotes cathode end Mounting Position: Any Weight:0.003 ounce, 0.093 grams 0.008(0.203)MAX. 0.220(5.59) 0.205(5.21) Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. MDD Catalog Number Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current at TL=75 C Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Maximum instantaneous forward voltage at 2.0A Maximum DC reverse current TA=25 C at rated DC blocking voltage TA=125 C Maximum reverse recovery time (NOTE 1) Typical junction capacitance (NOTE 2) Typical thermal resistance (NOTE 3) Operating junction and storage temperature range SYMBOLS VRRM VRMS VDC US2A US2B US2D US2G US2J 50 35 50 100 70 100 200 140 200 400 280 400 600 420 600 US2K US2M UNITS 800 560 800 VOLTS VOLTS VOLTS 1000 700 1000 I(AV) 2.0 Amps IFSM 50.0 Amps VF 1.0 trr RθJA TJ,TSTG Note:1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A 2.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 3.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas 1.7 5.0 350.0 IR CJ 1.4 50 µA 75 28.0 20.0 -50 to +150 Volts ns pF C/W C FIG. 1- FORWARD CURRENT DERATING CURVE 2.0 1.6 1.2 Single Phase Half Wave 60Hz Resistive or inductive Load 0.8 0.4 0 0 25 50 75 100 125 150 PEAK FORWARD SURGE CURRENT, AMPERES AVERAGE FORWARD RECTIFIED CURRENT, AMPERES RATINGS AND CHARACTERISTIC CURVES US2A THRU US2M FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT 50 40 30 20 10 175 0 8.3ms SINGLE HALF SINE-WAVE (JEDEC Method) 1 10 AMBIENT TEMPERATURE, C TJ=25 C PULSE WIDTH=300 µs 1%DUTY CYCLE 1 0.1 US2A-US2D US2G US2J-US2M 0.01 0.2 0.6 1.0 1.4 1.8 2.0 FIG. 4-TYPICAL REVERSE CHARACTERISTICS INSTANTANEOUS REVERSE CURRENT, MICROAMPERES INSTANTANEOUS FORWARD CURRENT,AMPERES FIG. 3-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 20 10 1,000 100 TJ=100 C 10 1 TJ=25 C 0.1 0.01 INSTANTANEOUS FORWARD VOLTAGE, VOLTS TJ=25 C 10 TRANSIENT THERMAL IMPEDANCE, C/W FIG. 5-TYPICAL JUNCTION CAPACITANCE JUNCTION CAPACITANCE, pF 0 20 40 60 80 FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE 100 10 1 0.1 0.01 0.1 1 10 1 0.1 1.0 10 REVERSE VOLTAGE,VOLTS 100 PERCENT OF PEAK REVERSE VOLTAGE,% 200 100 100 NUMBER OF CYCLES AT 60 Hz 100 t,PULSE DURATION,sec. The cruve graph is for reference only, can't be the basis for judgment(曲线图仅供参考)! 100
US2A-SMB 价格&库存
很抱歉,暂时无法提供与“US2A-SMB”相匹配的价格&库存,您可以联系我们找货
