SODDB3
Reverse Voltage 32 Volts
Power- 150mW
BIDIRECTIONAL TRIGGER DIODE
Features
SOD-123FL
Small glass structure ensures high reliability
VBO:28-36V version
Low breakover current
High temperature soldering guaranteed
0.075(1.90)
0.067(1.70)
0.031 (0.80)
0.043 (1.10)
0.114(2.90)
0.102(2.60)
250 C/10 seconds,0.375”(9.5mm) lead length, 5
lbs. (2.3kg) tension
0.051(1.30)
0.039(1.00)
0.010(0.25)
0.004(0.10)
0.035(0.90)
0.028(0.70)
0.154(3.90)
0.141(3.60)
Mechanical Data
Case: JEDEC SOD-123FL molded plastic body
Terminals: Solderable per MIL-STD-750,
Method 2026 Mounting Position: Any
Weight:0.00048 ounce, 0.015gram
Marking :DB3
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
VALUE
TEST
CONDITION
SYMBOLS
UNITS
Min.
Typ.
Max.
28
32
36
VOLTS
3
VOLTS
Breakover voltage *
C=22nF **
Breakover voltage symmetry
C=22nF **
I+VBOI-I-VBO I
Dynamic breakover voltage *
(NOTE 1)
I∆V+I
5
VOLTS
Output voltage *
DIAGRAM2
VO
5
VOLTS
Breakover current *
C=22nF **
IBO
50
µA
Rise time *
DIAGRAM3
tr
2
µS
Leakage current *
VR=0.5VBO
IB
10
µA
Power dissipation on printed circuit
TA=65 C
Pd
150
mW
ITRM
2
A
Thermal Resistances from Junction to ambient
RΘJA
400
Thermal Resistances from Junction to lead
RΘJL
150
Repetitive peak on-state current
VBO
tp=20µs
f=100Hz
Operating junction and storage temperature range
TJ,TSTG
-40
125
C/W
C
:Electrical characteristic appoicaboe in forward and reverse direct
** :Connected in parallel with the devices.
Note 1:IBO from IBO to 10mA
http://www.microdiode.com
Rev:2024A2
Page :1
SODDB3
Power- 150mW
Typical Characterisitics
Diagram2: Test circuit for output voltage
Diagram1: current-voltage characteristice
10KΩ
+I F
500KΩ
220V
50Hz
IO
R=20Ω
0.1μF
( 10mA)
VO
I BO
IB
-V
D.U.T
+V
0. 5V BO
Diagram3: Test circuit see Fig.2. Adjust R for lp=0.5A
△V
VO
V BO
90%
-I F
10%
tr
Fig.2: Power dissipation versus ambient
temperapture(maximum values)
VBO[Tj]
VBO[Tj=25°C ]
150
120
90
60
30
25
75
100
125
150
RELATIVE VARIATION OF V BO
P,POWER DISSIPATION,mW
Fig.1: Power dissipation versus ambient
1.08
1.06
1.04
1.02
1.00
25
T J (°C)
50
75
100
125
T j,JUNCTION TEMPERATURE, °C
CASE TEMPERATURE,°C
Fig.3: Power dissipation versus ambient
I TRM,PEAK PULSE CURRENT,A
10
1
0.1
0.01
10
100
1000
10000
tp,PULSE DURATION,µs
The curve above is for reference only.
Rev:2024A2
Page :2
SODDB3
Power- 150mW
Packing information
unit:mm
P0
P1
d
Item
Symbol
Tolerance
SOD-123FL
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
2.1
4.0
1.60
1.55
178.00
50.0
13.00
1.75
3.50
4.00
4.00
2.00
E
F
B
A
Carrier width
Carrier length
Carrier depth
Sprocket hole
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
W
P
D2
T
D1
C
W1
D
0.25
8.15
10.5
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
CARTON
SIZE
(m/m)
CARTON
(pcs)
SOD-123FL
7"
3,000
4.0
45,000
210*208*203
178
430*430*235
180,000
APPROX.
GROSS WEIGHT
(kg)
9.0
Suggested Pad Layout
Symbol
Unit (mm)
Unit (inch)
A
1.2
0.047
B
1.2
3.2
0.126
D
2
0.079
E
4.4
0.173
C
0.047
Rev:2024A2
Page :3
很抱歉,暂时无法提供与“SODDB3”相匹配的价格&库存,您可以联系我们找货
