HER104
HER104
    MDD(辰达半导体)
    DO-41(DO-204AL)
    二极管配置:独立式 直流反向耐压(Vr):300V 平均整流电流(Io):1A 正向压降(Vf):1.3V@1A 反向电流(Ir):5uA@300V 反向恢复时间(trr):50ns 工作温度:-65...
HER104 数据手册
HER101 THRU HER108 Reverse Voltage - 50 to 1000 Volts Forward Current - 1.0 Ampere HIGH EFFICIENCY RECTIFIERS Features DO-41  The plastic package carries Underwriters Laboratory Flammability Classification 94V-0  High speed switching for high efficiency  Low reverse leakage  High forward surge current capability  High temperature soldering guaranteed: 250°C/10 seconds,0.375”(9.5mm) lead length, 5 lbs. (2.3kg) tension 1.0 (25.4) MIN. 0.107(2.7) 0.080(2.0) DIA. 0.205(5.2) 0.166(4.2) Mechanical Data Case : JEDEC DO-41 Molded plastic body Terminals : Solder plated, solderable per MIL-STD-750,Method 2026 Polarity : Polarity symbol marking on body Mounting Position : Any Weight : 0.012 ounce, 0.34 grams 1.0 (25.4) MIN. 0.034(0.86) 0.028(0.70) DIA. Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. parameter SYMBOLS Marking code Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current 0.375”(9.5mm) lead length at TA=50°C Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Maximum instantaneous forward voltage at 1.0A Maximum DC reverse current TA=25°C at rated DC blocking voltage TA=100°C Maximum reverse recovery time (NOTE 1) Typical junction capacitance (NOTE 2) Typical thermal resistance (NOTE 3) Operating junction and storage temperature range VRRM VRMS VDC MDD MDD MDD HER101 HER102 HER103 HER104 50 35 50 100 70 100 200 140 200 MDD MDD 300 210 300 MDD MDD MDD HER105 HER106 HER107 HER108 400 280 400 600 420 600 800 1000 560 700 800 1000 UNITS V V V I(AV) 1.0 A IFSM 30.0 A VF 1.0 1.3 5.0 100.0 IR 1.7 V μA trr 50 70 ns CJ RθJA 15.0 12.0 pF °C/W °C TJ,TSTG 50.0 -65 to +150 Note:1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A 2.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 3.Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length,P.C.B. mounted http://www.microdiode.com Rev:2024A1 Page :1 HER101 THRU HER108 Reverse Voltage - 50 to 1000 Volts Forward Current - 1.0 Ampere FIG. 1- FORWARD CURRENT DERATING CURVE 1.0 0.8 0.6 Single Phase Half Wave 60Hz Resistive or inductive Load 0.4 0.2 0 0 25 50 75 100 125 150 PEAK FORWARD SURGE CURRENT, AMPERES AVERAGE FORWARD RECTIFIED CURRENT, AMPERES Ratings And Characteristic Curves FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT 30 25 20 15 10 175 5.0 8.3ms SINGLE HALF SINE-WAVE (JEDEC Method) 1 10 AMBIENT TEMPERATURE, C 20 TJ=25 C PULSE WIDTH=300 µs 1%DUTY CYCLE 1 0.1 HER101-HER103 HER104-HER105 HER106-HER108 0.01 0.2 0.6 1.0 1.4 1.8 2.0 FIG. 4-TYPICAL REVERSE CHARACTERISTICS INSTANTANEOUS REVERSE CURRENT, MICROAMPERES INSTANTANEOUS FORWARD CURRENT,AMPERES FIG. 3-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 10 1,000 100 TJ=100 C 10 1 TJ=25 C 0.1 0.01 0 INSTANTANEOUS FORWARD VOLTAGE, VOLTS TJ=25 C 10 HER101-HER105 HER106-HER108 TRANSIENT THERMAL IMPEDANCE, C/W FIG. 5-TYPICAL JUNCTION CAPACITANCE JUNCTION CAPACITANCE, pF 20 40 60 80 100 PERCENT OF PEAK REVERSE VOLTAGE,% 200 100 100 NUMBER OF CYCLES AT 60 Hz FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE 100 10 1 0.1 0.01 0.1 1 10 100 1 0.1 1.0 10 REVERSE VOLTAGE,VOLTS 100 t,PULSE DURATION,sec. The curve above is for reference only. http://www.microdiode.com Rev:2024A1 Page :2
HER104
物料型号:HER101至HER108 高效率整流器
器件简介: - 反向电压:50至1000伏特 - 前向电流:1.0安培 - 封装:DO-41 - 极性:色环表示阴极端 - 安装位置:任意 - 尺寸:以英寸和毫米为单位
特性: - 塑料封装符合UL 94V-0可燃性分类 - 高速开关适用于高效率 - 低反向漏电 - 高前向浪涌电流能力 - 高温度焊接保证:250°C/10秒,0.375"(9.5mm)引脚长度,5 lbs.(2.3kg)张力
机械数据: - 外壳:JEDEC DO-41模塑塑料体 - 终端:镀层轴向引线,可焊性符合MIL-STD-750 - 重量:0.012盎司,0.34克
最大额定值和电气特性: - 除非另有说明,否则所有额定值均在25°C环境温度下 - 单相半波60Hz,电阻性或感性负载,对于电容性负载电流降额20%
MDD目录编号: - 50:35、50、100 - 70:100 - 100:200 - 200:140、200 - 400:280、400 - 600:420、600 - 800:560、800
符号、单位: - VRRM:最大重复峰值反向电压 - VRMS:最大RMS电压 - VDC:最大直流阻断电压 - I(AV):最大平均前向整流电流 - IFSM:峰值前向浪涌电流
参数特性: - 操作结和存储温度范围:-65至+150°C - 最大瞬时前向电压:1.0A - 最大直流反向电流:50μA - 典型热阻:70ns(注3) - 典型结电容:12.0pF(注2) - 最大反向恢复时间:1.70μs(注1)
功能详解应用信息: - 曲线图仅供参考,不能作为判断依据
封装信息: - 封装类型:JEDEC DO-41 - 引脚:镀层轴向引线
HER104 价格&库存
很抱歉,暂时无法提供与“HER104”相匹配的价格&库存,您可以联系我们找货
HER104
  • 1000+0.08390
  • 5000+0.07831
HER104
  • 20+0.29510
  • 100+0.17600
  • 500+0.12320
  • 5000+0.08800
  • 10000+0.08360
  • 50000+0.07750
库存:59
