HER201 THRU HER208
Reverse Voltage - 50 to 1000 Volts
Forward Current - 2.0 Ampere
HIGH EFFICIENCY RECTIFIERS
Features
DO-15
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
High speed switching for high efficiency
Low reverse leakage
High forward surge current capability
High temperature soldering guaranteed:
250°C/10 seconds,0.375”(9.5mm) lead length, 5 lbs.
(2.3kg) tension
1.0 (25.4)
MIN.
0.140(3.6)
0.104(2.6)
DIA.
0.300(7.6)
0.230(5.8)
Mechanical Data
1.0 (25.4)
MIN.
0.034(0.86)
0.028(0.70)
DIA.
Case : JEDEC DO-15 Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.014 ounce, 0.40 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unless otherwisespecified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
parameter
SYMBOLS
Typical thermal resistance (NOTE 3)
Operating junction and storage temperature range
MDD
MDD
MDD MDD
MDD
MDD
MDD
UNITS
HER201 HER202 HER203 HER204 HER205 HER206 HER207 HER208
Marking code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
0.375”(9.5mm) lead length at TA=50°C
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage at 2.0A
Maximum DC reverse current
TA=25°C
at rated DC blocking voltage
TA=100°C
Maximum reverse recovery time
(NOTE 1)
Typical junction capacitance (NOTE 2)
MDD
VRRM
VRMS
VDC
50
35
50
100
70
100
200
140
200
300
210
300
400
280
400
600
420
600
800 1000
560 700
800 1000
V
V
V
I(AV)
2.0
A
IFSM
60.0
A
VF
1.0
1.3
1.7
5.0
100.0
IR
V
μA
trr
50
70
ns
CJ
RθJA
30.0
20.0
pF
°C/W
°C
TJ,TSTG
50.0
-65 to +150
Note:1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A
2.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
3.Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length,P.C.B. mounted
http://www.microdiode.com
Rev:2024A1
Page :1
HER201 THRU HER208
FIG. 1- FORWARD CURRENT DERATING CURVE
2.0
1.6
1.2
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
0.8
0.4
50
75
100
125
150
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
Ratings And Characteristic Curves
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
60
50
40
30
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
10
1
10
AMBIENT TEMPERATURE, C
NUMBER OF CYCLES AT 60 Hz
TJ=25 C
PULSE WIDTH=300 µs
1%DUTY CYCLE
1
0.1
HER201-HER203
HER204-HER205
HER206-HER208
0.01
0.2
0.6
1.0
1.4
1.8
2.0
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MICROAMPERES
INSTANTANEOUS FORWARD
CURRENT,AMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
10
1,000
100
TJ=100 C
10
1
TJ=25 C
0.1
0.01
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
60
80
100
200
100
TJ=25 C
10
HER201-HER205
HER206-HER208
TRANSIENT THERMAL IMPEDANCE,
C/W
PERCENT OF PEAK REVERSE VOLTAGE,%
FIG. 5-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE, pF
100
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
0.1
1
10
100
1
0.1
1.0
10
REVERSE VOLTAGE,VOLTS
100
t,PULSE DURATION,sec.
The curve above is for reference only.
Rev:2024A1
Page :2
很抱歉,暂时无法提供与“HER204”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.20326
- 200+0.15833
- 600+0.13338
- 2500+0.11837
- 10000+0.10541
- 20000+0.09839
- 国内价格
- 1+0.10010
- 10+0.09240
- 30+0.09086
- 100+0.08624
