HER208
HER208
    MDD(辰达半导体)
    DO-15(DO-204AC)
    直流反向耐压(Vr):1kV 平均整流电流(Io):2A 正向压降(Vf):1.7V@2A 反向电流(Ir):5uA@1kV 反向恢复时间(trr):70ns 工作温度:-65℃~+150℃@(Tj)
HER208 数据手册
HER201 THRU HER208 Reverse Voltage - 50 to 1000 Volts Forward Current - 2.0 Ampere HIGH EFFICIENCY RECTIFIERS Features DO-15  The plastic package carries Underwriters Laboratory Flammability Classification 94V-0  High speed switching for high efficiency  Low reverse leakage  High forward surge current capability  High temperature soldering guaranteed: 250°C/10 seconds,0.375”(9.5mm) lead length, 5 lbs. (2.3kg) tension 1.0 (25.4) MIN. 0.140(3.6) 0.104(2.6) DIA. 0.300(7.6) 0.230(5.8) Mechanical Data 1.0 (25.4) MIN. 0.034(0.86) 0.028(0.70) DIA. Case : JEDEC DO-15 Molded plastic body Terminals : Solder plated, solderable per MIL-STD-750,Method 2026 Polarity : Polarity symbol marking on body Mounting Position : Any Weight : 0.014 ounce, 0.40 grams Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25°C ambient temperature unless otherwisespecified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. parameter SYMBOLS Typical thermal resistance (NOTE 3) Operating junction and storage temperature range MDD MDD MDD MDD MDD MDD MDD UNITS HER201 HER202 HER203 HER204 HER205 HER206 HER207 HER208 Marking code Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current 0.375”(9.5mm) lead length at TA=50°C Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Maximum instantaneous forward voltage at 2.0A Maximum DC reverse current TA=25°C at rated DC blocking voltage TA=100°C Maximum reverse recovery time (NOTE 1) Typical junction capacitance (NOTE 2) MDD VRRM VRMS VDC 50 35 50 100 70 100 200 140 200 300 210 300 400 280 400 600 420 600 800 1000 560 700 800 1000 V V V I(AV) 2.0 A IFSM 60.0 A VF 1.0 1.3 1.7 5.0 100.0 IR V μA trr 50 70 ns CJ RθJA 30.0 20.0 pF °C/W °C TJ,TSTG 50.0 -65 to +150 Note:1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A 2.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 3.Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length,P.C.B. mounted http://www.microdiode.com Rev:2024A1 Page :1 HER201 THRU HER208 Reverse Voltage - 50 to 1000 Volts Forward Current - 2.0 Ampere FIG. 1- FORWARD CURRENT DERATING CURVE 2.0 1.6 1.2 Single Phase Half Wave 60Hz Resistive or inductive Load 0.8 0.4 0 0 25 50 75 100 125 150 PEAK FORWARD SURGE CURRENT, AMPERES AVERAGE FORWARD RECTIFIED CURRENT, AMPERES Ratings And Characteristic Curves FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT 60 50 40 30 8.3ms SINGLE HALF SINE-WAVE (JEDEC Method) 20 175 10 1 10 AMBIENT TEMPERATURE, C NUMBER OF CYCLES AT 60 Hz 20 TJ=25 C PULSE WIDTH=300 µs 1%DUTY CYCLE 1 0.1 HER201-HER203 HER204-HER205 HER206-HER208 0.01 0.2 0.6 1.0 1.4 1.8 2.0 FIG. 4-TYPICAL REVERSE CHARACTERISTICS INSTANTANEOUS REVERSE CURRENT, MICROAMPERES INSTANTANEOUS FORWARD CURRENT,AMPERES FIG. 3-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 10 1,000 100 TJ=100 C 10 1 TJ=25 C 0.1 0.01 INSTANTANEOUS FORWARD VOLTAGE, VOLTS 0 20 40 60 80 100 200 100 TJ=25 C 10 HER201-HER205 HER206-HER208 TRANSIENT THERMAL IMPEDANCE, C/W PERCENT OF PEAK REVERSE VOLTAGE,% FIG. 5-TYPICAL JUNCTION CAPACITANCE JUNCTION CAPACITANCE, pF 100 FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE 100 10 1 0.1 0.01 0.1 1 10 100 1 0.1 1.0 10 REVERSE VOLTAGE,VOLTS 100 t,PULSE DURATION,sec. The curve above is for reference only. http://www.microdiode.com Rev:2024A1 Page :2
HER208
物料型号:HER201至HER208
器件简介: - 这些整流器是高效率的桥式整流器,具有不同的反向电压和正向电流规格。 - 反向电压范围为50至1000伏特。 - 正向电流为2.0安培。 - 封装类型为DO-15。
引脚分配: - 引脚为镀层轴向引线,可按照MIL-STD-750标准方法2026进行焊接。 - 极性通过色带标识阴极端。
参数特性: - 塑料封装符合UL94V-0可燃性分类。 - 具有高速开关特性,低反向漏电流,高正向浪涌电流能力。 - 保证在250°C下10秒的高温焊接。 - 重量为0.014盎司,约0.40克。
功能详解: - 这些整流器适用于高速开关应用,具有低反向恢复时间和高温度下的焊接保证。
应用信息: - 适用于需要高效率和高速度开关的场合。
封装信息: - 封装类型为JEDEC DO-15,尺寸为1.0英寸(25.4毫米)最小。 - 引线直径为0.140英寸(3.6毫米)最小,0.104英寸(2.6毫米)直径。 - 引线长度为0.375英寸(9.5毫米),在50°C时的典型热阻为1.70℃/W。
HER208 价格&库存
很抱歉,暂时无法提供与“HER208”相匹配的价格&库存,您可以联系我们找货
HER208
    • 1+0.53900
    • 100+0.18040
    • 1250+0.11220
    • 2500+0.08778
    库存:5293
    HER208
    • 20+0.37130
    • 100+0.22150
    • 500+0.15500
    • 2500+0.11070
    • 5000+0.10520
    • 25000+0.09740
    库存:1724
    HER208
