DFR1A THRU DFR1M
SUFACE MOUNT FAST RECOVERY RECTIFIER
Reverse Voltage - 50 to 1000 Volts
SOD-123FL
FEATURES
Cathode Band
Top View
1.8± 0.1
1.0±0.2
Glass passivated device
Ideal for surface mouted applications
Low reverse leakage
Metallurgically bonded construction
High temperature soldering guaranteed:
250 C/10 seconds,0.375”(9.5mm) lead length,
5 lbs. (2.3kg) tension
0.10-0.30
2.8±0.1
1.3± 0.15
Forward Current - 1.0Ampere
0.6±0.25
MECHANICAL DATA
Case : JEDEC SOD-123FL molded plastic body over passivated chip
Terminals : Plated axial leads, solderable per MIL-STD-750,
Method 2026
Polarity : Color band denotes cathode end
Mounting Position : Any
Weight :0.0007 ounce, 0.02 grams
3.7±0.2
Dimensions in millimeters
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
SYMBOLS
MDD Catalog Number
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TA=65 C (NOTE 1)
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method) TL=25 C
Maximum instantaneous forward voltage at 1.0A
Maximum DC reverse current
TA=25 C
at rated DC blocking voltage
TA=125 C
Maximum reverse recovery time (NOTE 2)
DFR1A
DFR1B
DFR1D
DFR1G
F1B
F1D
F1G
F1A
VRRM
VRMS
VDC
DFR1J
DFR1K
DFR1M
F1J
F1K
F1M
1000
700
1000
50
100
200
400
600
800
35
50
70
100
140
200
280
400
420
600
560
800
UNITS
VOLTS
VOLTS
VOLTS
I(AV)
1.0
Amp
IFSM
25.0
Amps
VF
1.3
Volts
IR
5.0
50.0
µA
trr
Typical junction capacitance (NOTE 3)
CJ
Operating junction and storage temperature range TJ,TSTG
250
150
15
-50 to +150
500
ns
pF
C
Note: 1.Averaged over any 20ms period.
2.Measured with IF=0.5A, IR=1A, Irr=0.25A.
3.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2014-03 01版
http://www.microdiode.com
RATINGS AND CHARACTERISTIC CURVES DFR1A THRU DFR1M
2014-03 01版
很抱歉,暂时无法提供与“DFR1M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.07229
- 500+0.05751
- 3000+0.04715
- 6000+0.04233
- 24000+0.03803
- 51000+0.03573
- 国内价格
- 50+0.06626
- 600+0.05272
- 1200+0.05193
- 3000+0.04321
