FR151 THRU FR157
Reverse Voltage - 50 to 1000 Volts
Forward Current - 1.5 Ampere
FAST RECOVERY RECTIFIERS
Features
DO-15
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
1.0 (25.4)
MIN.
Idea for printed circuit board
Fast switching for high efficiency
Low reverse leakage
High forward surge current capability
0.140(3.6)
0.104(2.6)
DIA.
High temperature soldering guaranteed
0.300(7.6)
0.230(5.8)
250℃/10 seconds at terminals
Mechanical Data
1.0 (25.4)
MIN.
Case : JEDEC DO-15 Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.014 ounce, 0.40 grams
0.034(0.86)
0.028(0.70)
DIA.
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unlss otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
FR151
FR152
FR153
FR154
FR155
FR156
FR157
MDD
FR151
MDD
FR152
MDD
FR153
MDD
FR154
MDD
FR155
MDD
FR156
MDD
FR157
UNITS
VRMM
50
VRMS
VDC
35
50
100
70
100
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
V
V
V
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TA=75℃
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
I(AV)
1.5
A
IFSM
60
A
Maximum instantaneous forward voltage at 1.5A
Maximum DC reverse current
TA=25℃
at rated DC blocking voltage
TA=100℃
VF
1.30
5.0
50.0
V
Maximum reverse recovery time
trr
(NOTE 1)
Typical junction capacitance (NOTE 2)
Typical thermal resistance (NOTE 3)
Operating junction and storage temperature range
IR
150
μA
250
30.0
500
ns
CJ
RθJA
50.0
pF
℃/W
TJ,TSTG
-65 to +150
Note:1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A
2.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
3.Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length,P.C.B. mounted
https://www.microdiode.com
Rev:2024A1
Page :1
FR151 THRU FR157
FIG. 1- FORWARD CURRENT DERATING CURVE
1.5
1.2
0.9
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
0.6
0.3
50
75
100
125
150
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
Ratings And Characteristic Curves
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
60
50
40
30
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
10
1
10
AMBIENT TEMPERATURE, C
NUMBER OF CYCLES AT 60 Hz
1
TJ=25 C
PULSE WIDTH=300 µs
1%DUTY CYCLE
0.01
0.6
0.8
1.0
1.2
1.4
1.5
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MICROAMPERES
INSTANTANEOUS FORWARD
CURRENT,AMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
0.1
1,000
100
10
TJ=100 C
1
0.1
TJ=25 C
0.01
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
TJ=25 C
10
TRANSIENT THERMAL IMPEDANCE,
C/W
FIG. 5-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE, pF
60
80
100
PERCENT OF PEAK REVERSE VOLTAGE,%
200
100
100
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
0.1
1
10
100
1
0.1
1.0
10
REVERSE VOLTAGE,VOLTS
100
t,PULSE DURATION,sec.
The curve above is for reference only.
Rev:2024A1
Page :2
很抱歉,暂时无法提供与“FR157”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.20910
- 200+0.17139
- 500+0.12110
- 2000+0.10853
- 10000+0.09764
- 20000+0.09177
- 国内价格
- 500+0.08701
- 1000+0.07769
