RS2MF-SMAF
RS2MF-SMAF
    MDD(辰达半导体)
    SMAF
    VR=1000V IF=2A 50pF trr=500ns
RS2MF-SMAF 数据手册
RS2AF THRU RS2MF SURFACE MOUNT FAST RECOVERY RECTIFIER Reverse Voltage - 50 to 1000 Volts SMAF FEATURES The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 For surface mounted applications Fast switching for high efficiency Low reverse leakage Built-in strain relief,ideal for automated placement High forward surge current capability High temperature soldering guaranteed: 260 C/10 seconds at terminals Glass passivated chip junction Cathode Band Top View 0.106(2.70) 0.094(2.40) Forward Current - 2.0 Ampere 0.063(1.60) 0.051(1.30) 0.146(3.7) 0.130(3.3) 0.0091(0.23) 0.0071(0.18) 0.051(1.30) 0.043(1.10) 0.051(1.30) 0.039(1.0) MECHANICAL DATA 0.193(4.90) 0.173(4.40) Dimensions in inches and (millimeters) Case: JEDEC SMAF molded plastic body over passivated chip Terminals: Solder plated, solderable per MIL-STD-750, Method 2026 Polarity: Color band denotes cathode end Mounting Position: Any Weight:0.0018 ounce, 0.064 grams MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. MDD Catalog Number Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current at TL=90 C Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Maximum instantaneous forward voltage at 2.0A Maximum DC reverse current TA=25 C at rated DC blocking voltage TA=100 C Maximum reverse recovery time (NOTE 1) Typical junction capacitance (NOTE 2) Typical thermal resistance (NOTE 3) Operating junction and storage temperature range SYMBOLS VRRM VRMS VDC RS2AF RS2BF RS2DF RS2GF RS2JF RS2KF RS2MF 50 35 50 100 70 100 200 140 200 400 280 400 600 420 600 800 560 800 1000 700 1000 UNITS VOLTS VOLTS VOLTS I(AV) 2.0 Amp IFSM 50.0 Amps VF 1.3 Volts IR 5.0 50.0 µA trr CJ RθJA TJ,TSTG Note:1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A 2.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 3.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas 150 250 50.0 20.0 -50 to +150 500 ns pF C/W C 1.6 1.2 Single Phase Half Wave 60Hz Resistive or inductive Load 0.8 0.4 0 0 25 50 75 100 125 150 175 FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT 50 40 30 20 10 0 8.3ms SINGLE HALF SINE-WAVE (JEDEC Method) 1 10 AMBIENT TEMPERATURE, C 10 1 TJ=25 C PULSE WIDTH=300 µs 1%DUTY CYCLE 0.01 0.8 1.0 1.2 1.4 1.5 INSTANTANEOUS FORWARD VOLTAGE, VOLTS FIG. 5-TYPICAL JUNCTION CAPACITANCE 200 TJ=25 C 100 10 INSTANTANEOUS REVERSE CURRENT, MICROAMPERES FIG. 3-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 0.1 100 NUMBER OF CYCLES AT 60 Hz 20 0.6 JUNCTION CAPACITANCE, pF PEAK FORWARD SURGE CURRENT, AMPERES FIG. 1- FORWARD CURRENT DERATING CURVE 2.0 TRANSIENT THERMAL IMPEDANCE, C/W INSTANTANEOUS FORWARD CURRENT,AMPERES AVERAGE FORWARD RECTIFIED CURRENT, AMPERES RATINGS AND CHARACTERISTIC CURVES RS2AF THRU RS2MF FIG. 4-TYPICAL REVERSE CHARACTERISTICS 1,000 100 10 TJ=100 C 1 0.1 TJ=25 C 0.01 0 20 40 60 80 FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE 100 10 1 0.1 0.01 0.1 1 10 1 0.1 1.0 10 REVERSE VOLTAGE,VOLTS 100 PERCENT OF PEAK REVERSE VOLTAGE,% 100 t,PULSE DURATION,sec. The cruve graph is for reference only, can't be the basis for judgment(曲线图仅供参考)! 100
RS2MF-SMAF 价格&库存
很抱歉,暂时无法提供与“RS2MF-SMAF”相匹配的价格&库存,您可以联系我们找货
