SOD1F1 THRU SOD1F7
Reverse Voltage - 50 to 1000 Volts
Forward Current - 1.0 Ampere
SURFACE MOUNT FAST RECOVERY RECTIFIER
Features
SOD-123FL
Glass passivated device
Ideal for surface mouted applications
Low reverse leakage
Metallurgically bonded construction
0.075(1.90)
0.067(1.70)
0.031 (0.80)
0.043 (1.10)
0.114(2.90)
0.102(2.60)
High temperature soldering guaranteed:
250°C/10 seconds,0.375”(9.5mm) lead length,
0.051(1.30)
0.039(1.00)
5 lbs. (2.3kg) tension
0.010(0.25)
0.004(0.10)
0.035(0.90)
0.028(0.70)
Mechanical Data
0.154(3.90)
0.141(3.60)
Case : JEDEC 6OD-123FL molded plastic body
Terminals : Solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.007 ounce, 0.02 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current at
TL(see fig.1)
VRRM
VRMS
VDC
SOD1F1 SOD1F2 SOD1F3 SOD1F4 SOD1F5 SOD1F6 SOD1F7
F1
F2
F3
F4
F5
F6
F7
50
35
50
100
70
100
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
UNITS
V
V
V
I(AV)
1.0
A
Peak forward surge current 8.3ms single half
sine-wave
superimposed onrated load (JEDEC Method)
IFSM
30
A
Maximum instantaneous forward voltage at 1.0A
VF
IR
1.3
5
100
V
Maximum DC reverse current
rated DCblocking voltage
TA=25℃ at
TA=125℃
Typical junction capacitance (NOTE 1)
Maximum Reverse Recovery Time
Typical thermal resistance (NOTE 2)
Operating junction temperature range
Storage temperature range
CJ
trr
uA
pF
15
150
250
500
ns
RJA
85
℃/W
TJ
-55 to +150
TSTG
-55 to +150
Note: 1.Averaged over any 20ms period.
2.Measured with IF=0.5A, IR=1A, Irr=0.25A.
3.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
4.Thermal resistance junction to ambient, 6.0 mm2 coppeer pads to each terminal.
http://www.microdiode.com
Rev:2024A2
Page :1
SOD1F1 THRU SOD1F7
Typical Characterisitics
Fig.2 Typical Reverse Characteristics
1.2
1.0
0.8
0.6
0.4
0.2
Single phase half-wave 60 Hz
0.0
25
75
50
100
125
150
175
Instaneous Reverse Current(μ A)
Average Forward Current (A)
Fig.1 Forward Current Derating Curve
100
T J =125°C
10
1.0
T J =25°C
0.1
00
T J =25°C
1.0
0.1
pulse with 300μs
1% duty cycle
0.01
0.0
40
60
80
100
120
140
Fig.4 Typical Junction Capacitance
Junction Capacitance (pF)
Instaneous Forward Current (A)
Fig.3 Typical Instaneous Forward
Characteristics
10
percent of Rated Peak Reverse Voltage (%)
Case Temperature (°C)
100
T J =25°C
10
1
0.5
1.0
1.5
2.0
2.5
0.1
1.0
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Peak Forward Surge Current (A)
Fig.5 Maximum Non-Repetitive Peak
35
30
25
10
05
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
The curve above is for reference only.
Rev:2024A2
Page :2
SOD1F1 THRU SOD1F7
Packing information
unit:mm
P0
P1
d
Item
Symbol
Tolerance
SOD-123FL
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
2.1
4.0
1.60
1.55
178.00
50.0
13.00
1.75
3.50
4.00
4.00
2.00
E
F
B
A
Carrier width
Carrier length
Carrier depth
Sprocket hole
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
W
P
D2
T
D1
C
W1
D
0.25
8.15
10.5
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
CARTON
SIZE
(m/m)
CARTON
(pcs)
SOD-123FL
7"
3,000
4.0
45,000
210*208*203
178
430*430*235
180,000
APPROX.
GROSS WEIGHT
(kg)
9.0
Suggested Pad Layout
Symbol
Unit (mm)
Unit (inch)
A
1.2
0.047
B
1.2
3.2
0.126
D
2
0.079
E
4.4
0.173
C
0.047
Rev:2024A2
Page :3
很抱歉,暂时无法提供与“SOD1F7”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 7+0.08350
- 100+0.06680
- 300+0.05840
- 3000+0.05100
- 9000+0.04780
- 21000+0.04530
- 国内价格
- 100+0.06200
- 1000+0.04920
- 3000+0.03990
- 9000+0.03560
- 51000+0.03190
- 99000+0.02980
- 国内价格
- 50+0.05504
- 600+0.04326
- 1200+0.04261
- 3000+0.03465
- 15000+0.03069
- 30000+0.03023
