BZT52C2V0 - BZT52C75
Zener Voltage - 2 to 75 Volts
Peak Pulse Power - 0.5 W
SURFACE MOUNT ZENER DIODE
Features
SOD-123
Total power dissipation: Max. 500mW.
Wide zener reverse voltage range 2.0V to 75V.
Small plastic package suitable for surface mounted design.
Tolerance approximately±5%
0.028(0.70)
0.071(1.80)
0.018(0.45)
0.055(1.40)
0.008(0.20)max.
Cathode bar
0.110(2.80)
0.098(2.50)
0.154 (3.90)
0.138 (3.50)
0.026 (0.65)
0.014 (0.35)
0.0019 (0.05)
0.006 (0.15)
0° to
9°
0.018 (0.45)
0.0087 (0.22)
0.037(0.95)
0.008 (0.2 )
Case : JEDEC SOD-123 Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.00056 ounce, 0.016 grams
0.049 (1.25)
Mechanical Data
Dimensions in inches and millimeters
Ordering Information
Type No.
Marking
BZT52C2V0-BZT52C75
See table 2
MAXIMUM RATING
@ Ta=25℃ unless otherwise specified
Parameter
Forward Voltage
@ IF=10mA
Power Dissipation
Typical thermal resistance juncting to ambient
Junction temperature
Storage temperature range
(1)
Package Code
SOD-123
Symbol
Value
Unit
VF
0.9
V
Pd
500
mW
RθJA
305
℃/W
Tj
150
Tstg
-65-150
(1) Thermal resistance from junction to ambient at P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper areas pads.
http://www.microdiode.com
Rev:2025A5
Page :1
Fig.1 Maximum Continuous Power Derating
0.6
Power Dissipation ( W )
0.5
0.4
0.3
0.2
0.1
0.0
25
50
75
100
125
150
175
T c ,Case Temperature (°C)
Transient Thermal Impedance( °C /W)
ELECTRICAL CHARACTERISTICS CURVE
Fig.2 Typical Transient Thermal Impedance
2000
1000
100
10
0.01
0.1
1
10
100
t, Pulse Duration(sec)
Fig.3 Change of Zener voltage versus junctiontemperature
V
0.8
Vz=35V
0.7
15V
0.6
ΔVZ
8V
0.5
0.4
0.3
0.2
0.1
5.1V
3.6V
at Iz=5 mA
-0.2
60
80
100
120
140 ℃
Tj
The curve above is for reference only.
Rev:2025A5
Page :2
ELECTRICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified
Dynamic
Impedance
Zener Voltage Range (1)
Type
Marking
V ZT(at I ZT)
Min(V)
Nom(V)
Reverse Current
I ZT
Z ZT(at I ZT)
IR
at V R
Max(V)
(mA)
Max (Ω)
Max(μA)
(V)
BZT52C2V0
WY
1.9
2.0
2.1
5
100
120
0.5
BZT52C2V2
WZ
2.09
2.2
2.31
5
100
120
0.7
BZT52C2V4
WX
2.28
2.4
2.52
5
100
120
1
BZT52C2V7
W1
2.57
2.7
2.84
5
110
120
1
BZT52C3V0
W2
2.85
3.0
3.15
5
120
50
1
BZT52C3V3
W3
3.14
3.3
3.47
5
130
BZT52C3V6
W4
3.42
3.6
3.78
5
130
10
1
BZT52C3V9
W5
3.71
3.9
4.11
5
130
5
1
BZT52C4V3
W6
4.11
4.3
4.52
5
130
5
1
BZT52C4V7
W7
4.47
4.7
4.94
5
130
2
1
BZT52C5V1
W8
4.85
5.1
5.36
5
130
2
1.5
BZT52C5V6
W9
5.32
5.6
5.88
5
80
1
2.5
BZT52C6V2
WA
5.89
6.2
6.51
5
50
1
3
BZT52C6V8
WB
6.46
6.8
7.14
5
30
0.5
3.5
BZT52C7V5
WC
7.13
7.5
7.88
5
30
0.5
4
BZT52C8V2
WD
7.79
8.2
8.61
5
30
0.5
5
BZT52C9V1
WE
8.65
9.1
9.56
5
30
0.5
6
BZT52C10
WF
9.5
10
10.5
5
30
0.1
7
BZT52C11
WG
10.45
11
11.55
5
30
0.1
8
BZT52C12
WH
11.4
12
12.6
5
35
0.1
9
BZT52C13
WI
12.35
13
13.65
5
35
0.1
10
BZT52C15
WJ
14.25
15
15.75
5
40
0.1
11
BZT52C16
WK
15.2
16
16.8
5
40
0.1
12
BZT52C18
WL
17.1
18
18.9
5
45
0.1
13
BZT52C20
WM
19
5
50
0.1
15
BZT52C22
WN
20.9
22
23.1
5
55
0.1
17
BZT52C24
WO
22.8
24
25.2
5
60
0.1
19
BZT52C27
WP
25.65
27
28.35
5
70
0.1
21
BZT52C30
WQ
28.5
30
31.5
5
80
0.1
23
BZT52C33
WR
31.35
33
34.65
5
80
0.1
25
BZT52C36
WS
34.2
36
37.8
5
90
0.1
27
BZT52C39
WT
37.05
39
40.95
2.5
100
2
30
BZT52C43
WU
40.85
43
45.15
2.5
130
2
33
BZT52C47
WV
44.65
47
49.35
2.5
150
2
36
BZT52C51
WW
48.45
51
53.55
2.5
180
1
39
BZT52C56
XW
53.2
56
58.8
2.5
180
1
43
BZT52C62
6E
58.9
62
65.1
2.5
200
0.2
47
BZT52C68
6F
64.6
68
71.4
2.5
250
0.2
52
71.25
75
78.75
2.5
300
0.2
57
BZT52C75
6H
(1) V ZT is tested with pulses (20 ms)
Rev:2025A5
Page :3
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
CARTON
SIZE
(m/m)
CARTON
(pcs)
SOD-123
7"
3,000
45,000
190*190*190
178
400*400*220
180,000
SOD-123
13"
10,000
30,000
340*350*40
330
370*370*370
240,000
Suggested Pad Layout
Symbol
A
Unit (mm)
Unit (inch)
0.047
B
1.2
1.2
C
3.2
0.126
D
2.0
0.079
E
4.4
0.173
0.047
Important Notice and Disclaimer
Microdiode Electronics (Shenzhen) reserves the right to make changes to this document and its
products and specifications at any time without notice. Customers should obtain and confirm the
latest product information and specifications before final design,purchase or use.
Microdiode Electronics (Shenzhen) makes no warranty, representation or guarantee regarding the
suitability of its products for any particular purpose, not does Microdiode Electronics (Shenzhen)
assume any liability for application assistance or customer product design. Microdiode Electronics
(Shenzhen) does not warrant or accept any liability with products which are purchased or used for
any unintended or unauthorized application.
No license is granted by implication or otherwise under any intellectual property rights of
Microdiode Electronics (Shenzhen).
Microdiode Electronics (Shenzhen) products are not authorized for use as critical components in
life support devices or systems without express written approval of Microdiode Electronics
(Shenzhen).
Rev:2025A5
Page :4
很抱歉,暂时无法提供与“BZT52C10”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.16190
- 100+0.10070
- 800+0.06650
- 3000+0.04750
- 6000+0.04510
- 30000+0.04170
- 国内价格
- 50+0.08154
- 600+0.06543
- 1200+0.06445
- 国内价格
- 50+0.08964
- 500+0.07031
- 3000+0.05314
- 6000+0.04677
- 24000+0.04115
- 51000+0.03824
- 国内价格
- 1+0.23540
- 200+0.07832
- 1500+0.04895
- 3000+0.03883
