ABS2 THRU ABS10
Voltage Range - 200 to 1000 V olts
Current - 1.0 Ampere
SINGLE PHASE GLASS PASSIVATED BRIDGE RECTIFIERS
Features
ABS
Glass Passivated Chip Junction
Reverse Voltage - 200 to 1000 V
Forward Current - 1 A
High surge current capability
Designed for Surface Mount Application
Mechanical Data
Case : JEDEC ABS Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.0031 ounce, 0.098 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unlss otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Average Rectified Output Current
at Tc = 125 °C
Peak forward surge current,
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage drop
per leg at 1A
TA=25
Maximum DC reverse current
TA=100
at rated DC blocking voltage
TA=125
Typical thermal resistance (Note2)
Typical Junction capacitance (Note1)
Operating and storage temperature range
VRRM
VRMS
VDC
ABS2
ABS4
ABS6
ABS8
ABS10
MDD
ABS2
MDD
ABS4
MDD
ABS6
MDD
ABS8
MDD
ABS10
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
UNITS
V
V
V
IF(AV)
1.0
A
IFSM
35
A
VF
1.1
V
IR
5
50
100
uA
72
°C/W
13
pF
-55 to +150
°C
R
R
JA
JC
CJ
TJ,TSTG
NOTES:1.Measured at 1MHz and applied reverse voltage of 4 V D.C.
2.Mounted on glass epoxy PC board with 4×1.5"×1.5"(3.81×3.81 cm) copper pad.
http://www.microdiode.com
Rev:2024A2
Page :1
ABS2 THRU ABS10
Ratings And Characteristic Curves
Fig.2 Typical Reverse Characteristics
1.2
1.0
0.8
0.6
0.4
0.2
Resistive or Inductive Load
0.0
25
50
75
100
125
150
175
Instaneous Reverse Current(μ A)
Average Rectified Output Current (A)
Fig.1 Average Rectified Output Current
Derating Curve
100
T J =125°C
10
1.0
T J =25°C
0.1
00
60
80
100
120
140
Fig.4 Typical Junction Capacitance
T J =25°C
1.0
0.1
pulse with 300μs
1% duty cycle
Junction Capacitance (pF)
Instaneous Forward Current (A)
Fig.3 Typical Instaneous Forward
Characteristics
0.01
0.0
40
percent of Rated Peak Reverse Voltage (%)
Case Temperature (°C)
10
T J =25°C
10
1
0.5
1.0
1.5
2.0
0.1
1.0
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
Fig.5 Maximum Non-Repetitive Peak
40
30
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
The curve above is for reference only.
Rev:2024A2
Page :2
很抱歉,暂时无法提供与“ABS8”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.19800
- 500+0.13474
- 2000+0.13272
- 5000+0.11573
