DB101S THRU DB107S
Voltage Range - 50 to 1000 Volts
Current - 1.0 Ampere
SINGLE PHASE GLASS PASSIVATED BRIDGE RECTIFIERS
Features
DBS
Ideal for printed circuit board
Reliable low cost construction utilizing molded plastic technique
.205(5.2)
High temperature soldering guaranteed: 260°/10 seconds at 5
.195(5.0)
.335(8.50)
.307(7.8)
lbs., (2.3kg) tension
45
.118(3.0)
Small size, simple installation
High surge current capability
.087(2.20)
.047(1.20)
.035(0.88)
(1)
(2)
.402(10.2)
.382(9.70)
Mechanical Data
.255(6.5)
.245(6.2)
.014(0.35)
.008(0.15)
Case : JEDEC DBS Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method
2026
Polarity : Polarity symbol marking on case
Mounting Position : Any
Weight : 0.02 ounce, 0.4 grams
.008(0.20)
.060(1.53)
(3)
.002(0.05)
(4)
.040(1.02)
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unless otherwisespecified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TC=40°C
Peak forward surge current,
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage drop
per leg at 1A
Typical thermal resistance
Maximum DC reverse current
at rated DC blocking voltage
TA=25°C
TA=100°C
Operating temperature range
storage temperature range
MDD
SYMBOLS
DB101S
VRRM
VRMS
VDC
50
35
50
MDD
MDD
MDD
MDD
MDD
MDD
DB102S DB103S DB104S DB105S DB106S DB107S
100
70
100
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
UNITS
V
V
V
IF(AV)
1.0
A
IFSM
30
A
VF
1.1
V
RθJA
°C/W
IR
110
10
500
TJ
TSTG
-55 to +150
-55 to +150
°C
°C
µA
µA
NOTES:DBS for surface mount package.
http://www.microdiode.com
Rev:2024A4
Page :1
DB101S THRU DB107S
Ratings And Characteristic Curves
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
PEAK FORWARD CURRENT.(A)
AVERAGE FORWARD CURRENT(A)
FIG. 1- MAXIMUN DERATING CURVE FOR
OUTPUT RECTIFIED CURRENT
1.0
0.6''(1.5mm)
0.8
Copper Pauls .51''x.51''
(13mmx13mm)
0.6
0.4
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
0.2
60
TJ=25*
Single sine-wave
(JEDEC Method)
50
40
30
60
80
100
120
140 150
2
FIG. 3-TYPICAL REVERSE CHARACTERISTICS
PER BRIDGE ELEMENT
100
TJ=125*
10
1
1.0
0.1
TJ=25*
.10
0.01
.01
60
80
100
120
4
6
10
100
60
NUMBER OF CYCLES AT 60 Hz
INSTANTANEOUS REVERSE CURRENT.(A)
INSTANTANEOUS REVERSE CURRENT(*A)
AMBIENT TEMPERATURE, C
140
FIG. 4-TYPICAL FORWARD CHARACTERISTICS
PER BRIDGE ELEMNT
10
1
0.1
TJ=25*
PULSE WIDTH:300*S
1% DUTY CYCLE
0.01
0.4
0.6
0.8
1.0
1.2
1.4
1.6
FORWARD VOLTAGE,(V)
PERCENT OF RATED PEAK REVERSE VOLTAGE.(%)
FIG. 3-TYPICAL JUNCTION CAPACITANCE
PER BRIDGE ELEMENT
CAPACITANCE.(pF)
100
10
TJ=25*
f=1.0MHZ
Visg=50mV p-p
1
1
10
100
REVERSE VOLTAGE.(V)
The curve above is for reference only.
Rev:2024A4
Page :2
很抱歉,暂时无法提供与“DB107S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.34460
- 100+0.27777
- 300+0.24440
- 600+0.24073
- 1500+0.18706
- 15000+0.18425
- 国内价格
- 10+0.34640
- 100+0.28403
- 200+0.27977
- 400+0.25196
- 1000+0.18345
