DB151S THRU DB157S
Voltage Range - 50 to 1000 Volts
Current - 1.5 Ampere
SINGLE PHASE GLASS PASSIVATED BRIDGE RECTIFIERS
Features
DBS
Ideal for printed circuit board
Reliable low cost construction utilizing molded plastic technique
.205(5.2)
High temperature soldering guaranteed: 260°/10 seconds at 5
.195(5.0)
.335(8.50)
.307(7.8)
lbs., (2.3kg) tension
45
.118(3.0)
Small size, simple installation
High surge current capability
.087(2.20)
.047(1.20)
.035(0.88)
(1)
(2)
.402(10.2)
.382(9.70)
Mechanical Data
.255(6.5)
.245(6.2)
.014(0.35)
.008(0.15)
Case : JEDEC DBS Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.02 ounce, 0.4 grams
.008(0.20)
.060(1.53)
(3)
.002(0.05)
(4)
.040(1.02)
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unless otherwisespecified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TC=40°C
Peak forward surge current,
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage drop
per leg at 1.5A
TA=25°C
Maximum DC reverse current
TA=100°C
at rated DC blocking voltage
Operating temperature range
storage temperature range
VRRM
VRMS
VDC
MDD
MDD
MDD
MDD
MDD
MDD
MDD
DB151S DB152S DB153S DB154S DB155S DB156S DB157S
50
35
50
100
70
100
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
UNITS
V
V
V
IF(AV)
1.5
A
IFSM
50
A
VF
1.1
V
IR
10
500
µA
µA
TJ
TSTG
-55 to +150
-55 to +150
°C
°C
NOTES:DBS for surface mount package.
http://www.microdiode.com
Rev:2024A3
Page :1
DB151S THRU DB157S
Ratings And Characteristic Curves
The curve above is for reference only.
Rev:2024A3
Page :2
很抱歉,暂时无法提供与“DB157S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.54994
- 100+0.44885
- 300+0.39831
- 1000+0.31936
- 5000+0.28901
- 10000+0.27378
- 国内价格
- 10+0.50411
- 100+0.41144
- 200+0.40527
- 400+0.36511
- 1000+0.29274
- 国内价格
- 100+0.23617
- 1000+0.22747
