DB201 THRU DB207
Voltage Range - 50 to 1000 Volts
Current - 1.0 Ampere
SINGLE PHASE GLASS PASSIVATED BRIDGE RECTIFIERS
Features
DB
Ideal for printed circuit board
Reliable low cost construction utilizing molded plastic technique
High temperature soldering guaranteed: 260°/10 seconds at 5
lbs., (2.3kg) tension
Small size, simple installation
High surge current capability
0.255(6.5)
0.350(8.9)
0.245(6.2)
0.300(7.6)
0.335(8.51)
0.325(8.10)
(1)
(2)
0.135(3.4)
0.115(2.9)
Mechanical Data
0.185(4.69)
0.150(3.81)
0.020(.51)
0.016(.41)
0.060
0.205(5.2)
Case : JEDEC DB Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method
2026 Polarity : Polarity symbol marking on case
Mounting Position : Any
Weight : 0.02 ounce, 0.4 grams
(1.5)
0.195(5.0)
(3)
(4)
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unless otherwisespecified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TC=40°C
Peak forward surge current,
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage drop
per leg at 2A
Maximum DC reverse current
TA=25°C
at rated DC blocking voltage
TA=100°C
Operating temperature range
storage temperature range
VRRM
VRMS
VDC
MDD
MDD
MDD
MDD
MDD
MDD
MDD
UNITS
DB201 DB202 DB203 DB204 DB205 DB206 DB207
V
50
100
200
400
600
800
1000
V
35
70
140
280
420
560
700
V
50
100
200
400
600
800
1000
IF(AV)
2.0
A
IFSM
50
A
VF
1.1
V
IR
10
500
µA
µA
TJ
TSTG
-55 to +150
-55 to +150
°C
°C
Note: 1.Measured at 1.0 MHz and applied reverse voltage of 4.0 Volts.
2.Unit mounted on P.C. board with 0.51” x 0.51”(13x13mm) copper pads.
http://www.microdiode.com
Rev:2024A2
Page :1
DB201 THRU DB207
Ratings And Characteristic Curves
Average Forward Output
Current, Amperes
2.0
60Hz Resistive of
Inductive Load
1.0
Fig. 2 Maximum Non-repetitive Peak
Forward Surge Current
Peak Forward Surge Current,
Amperes
Fig. 1 Derating Curve for
Output Rectified Current
60
8.3ms
Single half-sine-Wave
[JEDEC Method]
50
40
30
1
100
Number of Cycles at 60HZ
Fig. 4 Typical Revers Characteristics
100
80
100
120
140
Ambient Temperature, C
Fig. 3 Typical Instantaneous
Forward Characteristics
Tj=125 C
10
1.0
Tj=25 C
0.1
.01
Tj=25 C
Pulse Width=300us
2% duty cycle
1.0
60
100
100
120
140
Tj=25C
f=1.0MHz
Vsig =50mV p.p.
0.1
.01
0.4
80
Percent of Rated Peak Reverse
Voltage, %
Fig. 5 Typical Junction Capacitance
0.6
0.8
1.0
1.2
Instantaneous Forward
Voltage, Volts
1.4
Capacitance, pF
Instantaneous Forward Current,
Amperes
10
Instantaneous Reverse
Current ,Amperes
40
10
1
1.5 2
10
100
Reverse Voltage, Volts
The curve above is for reference only.
Rev:2024A2
Page :2
很抱歉,暂时无法提供与“DB207”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 100+0.21380
- 500+0.20882
- 国内价格
- 10+0.52359
- 100+0.42812
- 300+0.28944
- 1000+0.25359
- 5000+0.22497
- 10000+0.21071
