DB207S
DB207S
    MDD(辰达半导体)
    DBS-4P_8.15X6.35MM_SM
    桥式整流器/整流桥 VRM=100V IF=2.0A VF=1.1V IR=10uA
DB207S 数据手册
DB201S THRU DB207S Voltage Range - 50 to 1000 Volts Current - 1.0 Ampere SINGLE PHASE GLASS PASSIVATED BRIDGE RECTIFIERS Features DBS  Ideal for printed circuit board  Reliable low cost construction utilizing molded plastic technique .205(5.2)  High temperature soldering guaranteed: 260°/10 seconds at 5 .195(5.0) .335(8.50) .307(7.8) lbs., (2.3kg) tension +  Small size, simple installation  High surge current capability 45 .118(3.0) .087(2.20) .047(1.20) .035(0.88) (1) (2) - .402(10.2) + .382(9.70) Mechanical Data .255(6.5) .245(6.2) .014(0.35) .008(0.15) Case : JEDEC DBS Molded plastic body Terminals : Solder plated, solderable per MIL-STD-750,Method 2026 Polarity : Polarity symbol marking on case Mounting Position : Any Weight : 0.02 ounce, 0.4 grams .008(0.20) .060(1.53) ~ .002(0.05) ~ (3) .040(1.02) (4) Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25°C ambient temperature unless otherwisespecified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. Parameter Marking Code Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current at TC=40°C Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Maximum instantaneous forward voltage drop per leg at 2A Maximum DC reverse current TA=25°C at rated DC blocking voltage TA=100°C Operating temperature range storage temperature range SYMBOLS VRRM VRMS VDC MDD DB201S 50 35 50 MDD MDD MDD MDD DB202S DB203S DB204S DB205S 100 70 100 200 140 200 400 280 400 600 420 600 MDD MDD DB206S DB207S 800 560 800 1000 700 1000 UNITS V V V IF(AV) 2.0 A IFSM 50 A VF 1.1 V IR 10 500 µA µA TJ TSTG -55 to +150 -55 to +150 °C °C NOTES:DBS for surface mount package. http://www.microdiode.com Rev:2024A3 Page :1 DB201S THRU DB207S Voltage Range - 50 to 1000 Volts Current - 1.0 Ampere Ratings And Characteristic Curves Average Forward Output Current, Amperes 2.0 60Hz Resistive of IInductive nduc 1.0 Fig. 2 Maximum Non-repetitive Peak Forward Surge Current Peak Forward Surge Current, Amperes Fig. 1 Derating Curve for Output Rectified Current 60 8.3ms Single half-sine-Wave [JEDEC Method] 50 40 30 20 10 0 1 10 100 Number of Cycles at 60HZ Fig. 4 Typical Revers Characteristics 100 0 60 80 100 120 140 Ambient Temperature, C Fig. 3 Typical Instantaneous Forward Characteristics Tj=125 C 10 1.0 Tj=25 C 0.1 .01 10 Tj=25 C Pulse Width=300us 2% duty cycle 1.0 0 20 40 60 100 100 120 140 Tj=25 C f=1.0MHz Vsig =50mV 0.1 .01 0.4 80 Percent of Rated Peak Reverse Voltage, % Fig. 5 Typical Junction Capacitance 0.6 0.8 1.0 1.2 Instantaneous Forward Voltage, Volts 1.4 Capacitance, pF Instantaneous Forward Current, Amperes Instantaneous Reverse Current ,Amperes 40 10 1 1.5 2 10 100 Reverse Voltage, Volts The curve above is for reference only. http://www.microdiode.com Rev:2024A3 Page :2
DB207S
- 物料型号:DB201S至DB207S - 器件简介:这些整流器适用于单相半波60Hz的电路,适用于电阻性或电感性负载,对于电容性负载需要降额电流20%。 - 引脚分配:文档中没有明确提供引脚分配图,但提到了极性符号标记在封装上。 - 参数特性: - 最大重复峰值反向电压:根据型号不同,范围从50到1000伏特。 - 最大RMS电压:同上。 - 最大直流阻断电压:同上。 - 最大平均正向整流电流:在40°C环境温度下为2.0安培。 - 峰值正向浪涌电流:在25°C和125°C下分别为60和10安培。 - 最大瞬时正向电压降:在2.0A电流下为500毫伏。 - 最大直流反向电流:根据型号不同,范围从200到1000微安培。 - 功能详解:文档提供了正向和反向特性的典型曲线图,以及桥式整流器元件的典型结电容特性。 - 应用信息:适用于印刷电路板,具有高浪涌电流能力,保证高温焊接,小尺寸,简单安装。 - 封装信息:采用模塑塑料封装,引脚为镀层引线,可按照MIL-STD-750标准方法2026进行焊接。
DB207S 价格&库存
很抱歉,暂时无法提供与“DB207S”相匹配的价格&库存,您可以联系我们找货
DB207S
  • 10+0.55192
  • 100+0.45906
  • 200+0.45217
  • 400+0.41273
  • 1000+0.28710
库存:2092
DB207S
  • 1+0.26180
  • 30+0.25245
  • 100+0.23375
  • 500+0.21505
  • 1000+0.20570
库存:5212
