GBJ1510
GBJ1510
    MDD(辰达半导体)
    GBJ
    耐压:1000V 电流:15A
GBJ1510 数据手册
GBJ15005 THRU GBJ1510 Reverse Voltage - 50 to 1000 Volts Forward Current - 15.0 Amperes SILICON BRIDGE RECTIFIERS Features GBJ ? .134(3.4) ? .122(3.1) .189(4.8) .173(4.4) .150(3.8) .134(3.4)  Low forward voltage drop,high current capability Case : JEDEC GBJ Molded plastic body Terminals : Solder plated, solderable per MIL-STD-750,Method 2026 Polarity : Polarity symbol marking on body Mounting Position : Any ~ ~ _ .165(4.2) .142(3.6) .708(18.0) .669(17.0) .106(2.7) .096(2.3) Mechanical Data + .441(11.2) .425(10.8)  Plastic material has U/L lammability classification 94V-0 ? .134(3.4) ? .122(3.1) 1.193(30.3) 1.169(29.7) .198 MAX (5.1) .800(20.3) .776(19.7)  Ideal for printed circuit board  Reliable low cost construction utilizing molded plastic technique .094(2.4) .078(2.0) .043(1.1) .035(0.9) .114(2.9) .098(2.5) .031(0.8) .023(0.6) .402(10.2) .303(7.7).303(7.7) SPACING .386(9.8) .287(7.3).287(7.3) Maximum Ratings And Electrical Characteristics Dimensions in inches and (millimeters) Ratings at 25°C ambient temperature unless otherwisespecified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. Parameter Marking Code Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward(with heatsink NOTE 2) Rectified current @T c =100°C(without heatsink) Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Rating for Fusing(t
GBJ1510 价格&库存
很抱歉,暂时无法提供与“GBJ1510”相匹配的价格&库存,您可以联系我们找货
GBJ1510
库存:179
GBJ1510
  • 1+1.72700
  • 50+1.33100
  • 250+1.23200
库存:355
