Radial Lead Varistor (MOV)
10D Series
14D
Description
The 14D series radial leaded varistors provides an ideal circuit
protection solution for lower DC voltage applications by
offering higher surge ratings than ever before available in such
small discs.
The maximum peak surge current rating can reach up to 6KA
(8/20 μs pulse) to protect against high peak surges, including
indirect
lightning
strike
interference,
system
switching
transients and abnormal fast transients from the power
source.
Features
Applicable
u
Wide operating voltage (V1mA) range from 8V to 1800V
u
u
Fast responding to transient over-voltage
u
Large absorbing transient energy capability
u
Surge protection in consumer electronics
u
Low clamping ratio and no following-on current
u
Surge protection in industrial electronics
u
Meets MSL level 1, per J-STD-020
u
Surge protection in electronic home appliances, gas and
Transistor, diode, IC, thyristor or triac semiconductor
protection
petroleum appliances
u
Relay and electromagnetic valve surge absorption
General Characteristics
Material
No Radioactive Material
Operating Temperature
-55~85ºC
Storage Temperature
-55~125ºC
Body
Nickel Plated
Leads
Tin Plated
Devices with No lead
Nickel Plated
SOCAY Electronics Co., Ltd.
Revision September 25, 2013
www.socay.com
1/4
@SOCAY Electronics Co., Ltd. 2013
Specifications are subject to change without notice.
Please refer to www.socay.com for current information.
10D Series
14D
Specifications – General Characteristics (25±5ºC)
Type Number
Maximum
Allowable
voltage
Varistor
Voltage
Maximum
Clamping
Voltage
Withstanding
Surge
Current
I(A)
Standard
Maximum
Energy
(10/1000μs)
I(A)
High Surge
High
Surge
VAC
(V)
VDC
(V)
V1mA
(V)
IP
(A)
VC
(V)
1
2
Time
Times
Time
Times
14D180K
14D180KJ
11
14
18(15~21.6)
10
36
1000
500
2000
14D220K
14D220KJ
14
18
22(19.5~26)
10
43
1000
500
14D270K
14D270KJ
17
22
27(24~30)
10
53
1000
500
14D330K
14D330KJ
33(29.5~36.5)
10
66
1000
14D390K
14D390KJ
25
31
39(35~43)
10
77
1000
14D470K
14D470KJ
30
38
47(42~54)
10
93
14D560K
14D560KJ
35
45
56(50~62)
10
14D680K
14D680KJ
40
56
68(61~75)
10
14D820K
14D820KJ
50
65
82(74~90)
14D101K
14D101KJ
60
85
100(90~110)
14D121K
14D121KJ
75
100
14D151K
14D151KJ
95
125
14D181K
14D181KJ
115
14D201K
14D201KJ
130
14D221K
14D221KJ
14D241K
14D241KJ
14D271K
Rated
Power
Typical
Capacitance
(Reference)
(W)
@1KHZ
(pf)
(J)
(J)
Standard
High Surge
1000
4.0
7.0
0.1
11100
2000
1000
5.0
8.0
0.1
9100
2000
1000
6.0
10.0
0.1
7400
500
2000
1000
7.5
12.0
0.1
6100
500
2000
1000
8.6
13.0
0.1
5100
1000
500
2000
1000
10.0
17.0
0.1
4300
100
1000
500
2000
1000
11.0
20.0
0.1
3600
135
1000
500
2000
1000
14.0
24.0
0.1
2900
50
135
4500
2500
6000
5000
22.0
27.0
0.6
2400
50
165
4500
2500
6000
5000
28.0
33.0
0.6
2000
120(108~132)
50
200
4500
2500
6000
5000
32.0
40.0
0.6
1700
150(135~165)
50
250
4500
2500
6000
5000
40.0
53.0
0.6
1300
150
180(162~198)
50
300
4500
2500
6000
5000
50.0
60.0
0.6
1100
170
200(180~220)
50
340
4500
2500
6000
5000
57.0
70.0
0.6
1000
140
180
220(198~242)
50
360
4500
2500
6000
5000
60.0
78.0
0.6
900
150
200
240(216~264)
50
395
4500
2500
6000
5000
63.0
84.0
0.6
830
14D271KJ
175
225
270(243~297)
50
455
4500
2500
6000
5000
70.0
99.0
0.6
740
14D301K
14D301KJ
190
250
300(270~330)
50
500
4500
2500
6000
5000
77.0
108
0.6
670
14D331K
14D331KJ
210
275
330(297~363)
50
550
4500
2500
6000
5000
85.0
115
0.6
610
14D361K
14D361KJ
230
300
360(324~396)
50
595
4500
2500
6000
5000
93.0
130
0.6
560
14D391K
14D391KJ
250
320
390(351~429)
50
650
4500
2500
6000
5000
100
140
0.6
510
14D431K
14D431KJ
275
350
430(387~473
50
710
4500
2500
6000
5000
115
155
0.6
460
14D471K
14D471KJ
300
335
470(423~517)
50
775
4500
2500
6000
5000
125
175
0.6
430
Standard
1
2
14D511K
14D511KJ
320
415
510(459~561)
50
845
4500
2500
6000
5000
125
180
0.6
390
14D561K
14D561KJ
350
460
560(504~616)
50
925
4500
2500
6000
5000
125
185
0.6
360
14D621K
14D621KJ
385
505
620(558~682)
50
1025
4500
2500
6000
5000
125
190
0.6
320
14D681K
14D681KJ
420
560
680(612~748)
50
1120
4500
2500
6000
5000
130
200
0.6
290
14D751K
14D751KJ
460
615
750(675~825)
50
1240
4500
2500
6000
5000
143
210
0.6
270
14D781K
14D781KJ
485
640
780(702~858)
50
1290
4500
2500
6000
5000
148
220
0.6
260
14D821K
14D821KJ
510
670
820(738~902)
50
1355
4500
2500
6000
5000
157
235
0.6
240
14D911K
14D911KJ
550
745
910(819~1001)
50
1500
4500
2500
6000
5000
175
255
0.6
220
14D102K
14D102KJ
625
825
1000(900~1100)
50
1650
4500
2500
6000
5000
190
280
0.6
200
14D112K
14D112KJ
680
895
1100(990~1210)
50
1814
4500
2500
6000
5000
213
310
0.6
180
14D122K
14D122KJ
750
990
1200(1080~1320)
50
1980
4500
2500
6000
5000
213
310
0.6
150
14D182K
14D182KJ
1000
1465
1800(1620~1980)
50
2970
4500
2500
6000
5000
250
335
0.6
130
www.socay.com
2/4
10D Series
14D
Electrical Rating
Item
Test Condition / Description
Maximum
Allowable Voltage
The recommended maximum sine wave voltage (RMS) or the maximum DC
voltage can be applied continuously.
Varistor Voltage
Requirement
The voltage between two terminals with the specified measuring current
1mA.DC applied is call Vb.
The maximum voltage between two terminals with the specification
standard impulse current.
Applied waveform: 8/20μs
Maximum
Clamping Voltage
To meet the
specified value
Rated Wattage
The maximum average power that can be applied within the specified
ambient temperature.
Energy
The maximum energy within the varistor voltage change of ±10% when one
impulse of 10/1000μs. or 2 msec. is applied.
Withstanding
Surge
Current
The maximum current within the varistor voltage change of ±10% with the
standard impulse current (8/20ȝsec.) applied one time
Vb at 20ºC-Vb at 70ºC
Varistor Voltage
Temp. Coefficient
Vb at 20ºC
1
50
× 100(% / ºC)
0.05% / ºC max
The change of Vb shall be measured after the impulse listed below is
applied 10,000 times continuously with the interval of ten seconds at room
temperature.
5D Series
7D Series
Surge Life
10D Series
14D Series
20D Series
180K to 680K
10A (8/20μs)
820K to 751K
20A (8/20μs)
180K to 680K
25A (8/20μs)
820K to 751K
50A (8/20μs)
180K to 680K
50A (8/20μs)
820K to 751K
100A (8/20μs)
180K to 680K
75A (8/20μs)
820K to 751K
150A (8/20μs)
180K to 680K
100A (8/20μs)
820K to 751K
200A (8/20μs)
△Vb / Vb ≤ ±10%
www.socay.com
3/4
10D Series
14D
Part Marking
Part Numbering
14 D XXX K J
J: High Surge, without: Standard
Tolerance:
K: ±10%,
L:
±15%, M:
Logo
14DXXXX
±20%
UL Accreditation Logo
Product Type
VDE Accreditation Logo
Varistor Voltage
Type:
D: Disk, S: Square
Element Diameter
Packaging Information
Part Number
Quantity
Packaging Option
Packaging
Specification
14DXXXXX
500
Plastic bag
Bulk Pack
Package Dimensions
Unit: mm
TABLE1
TABLE2
Symbol
Dimensions
Model
T(max.)
Model
T(max.)
H(max.)
H1(max.)
L(min.)
L1(min.)
D(max.)
D1(±0.8)
T(max.)
d(±0.05)
d1(±0.4)
20.0
21.0
20.0
15.0
16.5
7.5
TABLE2
0.8
1.4
180K
220K
270K
330K
390K
470K
560K
680K
820K
101K
121K
151K
181K
201K
221K
241K
271K
301K
4.6
4.7
4.8
5.0
5.3
5.4
5.5
5.6
4.7
4.9
5.1
5.4
4.8
5.0
5.1
5.2
5.4
5.5
331K
361K
391K
431K
471K
511K
561K
621K
681K
751K
781K
821K
911K
102K
112K
122K
182K
5.8
6.0
6.2
6.5
6.7
6.8
7.0
7.3
7.6
8.0
8.1
8.3
8.8
9.3
9.9
10.4
13.0
www.socay.com
4/4
很抱歉,暂时无法提供与“14D390K”相匹配的价格&库存,您可以联系我们找货
