5KP36A
5KP36A
    SOCAY(硕凯)
    AXIAL_D9.14X9.14MM_TM
    TVS二极管 VRWM=36 V VBR(Min)=40 V VC=58.1 V IPP=86.06 A Ppp=5 KW AXIAL_D9.14X9.14MM_TM
5KP36A 数据手册
Axial Lead Transient Voltage Suppressors (TVS) 5KP Series 5.0 To 190 V 5000W Uni-directional Description Bi-directional The 5KP series is designed specifically to protect sensitive electronic equipment from voltage transients induced by lightning and other transient voltage events. Features u u u u u u u u u u u u u u u u u Glass passivated chip junction in P600 Package Low leakage Uni and Bidirectional unit Excellent clamping capability 5000W Peak power capability at 10 × 1000µs waveform Repetition rate (duty cycle):0.01% Fast response time: typically less than 1.0ps from 0 Volts to VBR min Typical IR less than 5μA above 12V. High Temperature soldering: 260°C/40 seconds at terminals Typical maximum temperature coefficient ΔVBR = 0.1% × VBR@25°C× ΔT Plastic package has Underwriters Laboratory Flammability 94V-0 Matte tin lead–free Plated Halogen free and RoHS compliant Typical failure mode is short from over-specified voltage or current Whisker test is conducted based on JEDEC JESD201A per its table 4a and 4c IEC-61000-4-2 ESD 15kV(Air), 8kV (Contact) ESD protection of data lines in accordance with IEC 61000-4-2 (IEC801-2) EFT protection of data lines in accordance with IEC 61000-4-4 (IEC801-4) Functional Diagram Bi-directional Cathode Anode Uni-direction Agency Approvals AGENCY Applications AGENCY FILE NUMBER TVS devices are ideal for the protection of I/O interfaces, VCC bus and other vulnerable circuits used in Telecom, Computer, Industrial and Consumer electronic applications. E341027 Maximum Ratings (TA=25℃ unless otherwise noted) Parameter Symbol Value Unit Peak Pulse Power Dissipation with a 10/1000µs waveform (Fig.1)(Note 1), (Note 2) PPPM 5000 Watts Amps Peak Pulse Current with a 10/1000µs waveform.(Note1,Fig.3) IPP See Next Table PM(AV) 8.0 Watt Peak Forward Surge Current, 8.3ms Single Half Sine Wave (Note 3) IFSM 500 Amps Maximum Instantaneous Forward Voltage at 25A for Unidirectional Only (Note 4) VF 3.5/5.0 Voltage TJ , TSTG -55 to +150 °C Power Dissipation on Infinite Heat Sink at TL=75°C Operating junction and Storage Temperature Range. Notes: 1. Non-repetitive current pulse, per Fig. 3 and derated above TA = 25°C per Fig. 2. 2. Mounted on 5.0mm x 5.0mm (0.03mm thick) Copper Pads to each terminal. 3. 8.3ms single half sine-wave, or equivalent square wave, Duty cycle = 4 pulses per minutes maximum. 4. VF < 3.5V for VBR < 200V and VF< 6.5V for VBR > 201V. SOCAY Electronics Co., Ltd. Revision September 25, 2013 www.socay.com 1/6 @ SOCAY Electronics Co., Ltd. 2013 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Axial Lead Transient Voltage Suppressors (TVS) 5KP Series 5.0 To 190 V Electrical Characteristics (TA=25℃ unless otherwise noted) Part Number Uni 5KP5.0 5KP5.0A 5KP6.0 5KP6.0A 5KP6.5 5KP6.5A 5KP7.0 5KP7.0A 5KP7.5 5KP7.5A 5KP8.0 5KP8.0A 5KP8.5 5KP8.5A 5KP9.0 5KP9.0A 5KP10 5KP10A 5KP11 5KP11A 5KP12 5KP12A 5KP13 5KP13A 5KP14 5KP14A 5KP15 5KP15A 5KP16 5KP16A 5KP17 5KP17A 5KP18 5KP18A 5KP19 5KP19A 5KP20 5KP20A 5KP22 5KP22A 5KP24 5KP24A 5KP26 5KP26A 5KP28 5KP28A 5KP30 5KP30A 5KP33 5KP33A 5KP36 5KP36A 5KP40 5KP40A 5KP43 5KP43A 5000W Bi 5KP5.0C 5KP5.0CA 5KP6.0C 5KP6.0CA 5KP6.5C 5KP6.5CA 5KP7.0C 5KP7.0CA 5KP7.5C 5KP7.5CA 5KP8.0C 5KP8.0CA 5KP8.5C 5KP8.5CA 5KP9.0C 5KP9.0CA 5KP10C 5KP10CA 5KP11C 5KP11CA 5KP12C 5KP12CA 5KP13C 5KP13CA 5KP14C 5KP14CA 5KP15C 5KP15CA 5KP16C 5KP16CA 5KP17C 5KP17CA 5KP18C 5KP18CA 5KP19C 5KP19CA 5KP20C 5KP20CA 5KP22C 5KP22CA 5KP24C 5KP24CA 5KP26C 5KP26CA 5KP28C 5KP28CA 5KP30C 5KP30CA 5KP33C 5KP33CA 5KP36C 5KP36CA 5KP40C 5KP40CA 5KP43C 5KP43CA Reverse Stand-Off Voltage VRWM (V) 5.0 5.0 6.0 6.0 6.5 6.5 7.0 7.0 7.5 7.5 8.0 8.0 8.5 8.5 9.0 9.0 10.0 10.0 11.0 11.0 12.0 12.0 13.0 13.0 14.0 14.0 15.0 15.0 16.0 16.0 17.0 17.0 18.0 18.0 19.0 19.0 20.0 20.0 22.0 22.0 24.0 24.0 26.0 26.0 28.0 28.0 30.0 30.0 33.0 33.0 36.0 36.0 40.0 40.0 43.0 43.0 Breakdown Voltage VBR (V) @IT MIN 6.40 6.40 6.67 6.67 7.22 7.22 7.78 7.78 8.33 8.33 8.89 8.89 9.44 9.44 10.00 10.00 11.10 11.10 12.20 12.20 13.30 13.30 14.40 14.40 15.60 15.60 16.70 16.70 17.80 17.80 18.90 18.90 20.00 20.00 21.13 21.10 22.20 22.20 24.40 24.40 26.70 26.70 28.90 28.90 31.10 31.10 33.30 33.30 36.70 36.70 40.00 40.00 44.40 44.40 47.80 47.80 MAX 7.30 7.00 8.15 7.37 8.82 7.98 9.51 8.60 10.20 9.21 10.90 9.83 11.50 10.40 12.20 11.10 13.60 12.30 14.90 13.50 16.30 14.70 17.60 15.90 19.10 17.20 20.40 18.50 21.80 19.70 23.10 20.90 24.40 22.10 25.76 23.30 27.10 24.50 29.80 26.90 32.60 29.50 35.30 31.90 38.00 34.40 40.70 36.80 44.90 40.60 48.90 44.20 54.30 49.10 58.40 52.80 SOCAY Electronics Co., Ltd. Revision September 25, 2013 Test Current IT (mA) Maximum Clamping Voltage VC @IPP (V) 10 10 10 10 10 10 10 10 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 9.6 9.2 11.4 10.3 12.3 11.2 13.3 12.0 14.3 12.9 15.0 13.6 15.9 14.4 16.9 15.4 18.8 17.0 20.1 18.2 22.0 19.9 23.8 21.5 25.8 23.2 26.9 24.4 28.8 26.0 30.5 27.6 32.2 29.2 34.0 30.8 35.8 32.4 39.4 35.5 43.0 38.9 46.6 42.1 50.0 45.4 53.5 48.4 59.0 53.3 64.3 58.1 71.4 64.5 76.7 69.4 Maximum Peak Pulse Current IPP (A) 520.83 543.48 438.60 485.44 406.50 446.43 375.94 416.67 349.65 387.60 333.33 367.65 314.47 347.22 295.86 324.68 265.96 294.12 248.76 274.73 227.27 251.26 210.08 232.56 193.80 215.52 185.87 204.92 173.61 192.31 163.93 181.16 155.28 171.23 147.02 162.44 139.66 154.32 126.90 140.85 116.28 128.53 107.30 118.76 100.00 110.13 93.46 103.31 84.75 93.81 77.76 86.06 70.03 77.52 65.19 72.05 Maximum Reverse Leakage IR @VRWM (μA) 800 800 800 800 500 500 200 200 100 100 50 50 20 20 10 10 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 www.socay.com 2/6 @ SOCAY Electronics Co., Ltd. 2013 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Axial Lead Transient Voltage Suppressors (TVS) 5KP Series 5.0 To 190 V Electrical Characteristics (TA=25℃ unless otherwise noted) (Continue) Part Number Uni 5KP45 5KP45A 5KP48 5KP48A 5KP51 5KP51A 5KP54 5KP54A 5KP58 5KP58A 5KP60 5KP60A 5KP64 5KP64A 5KP70 5KP70A 5KP75 5KP75A 5KP78 5KP78A 5KP80 5KP80A 5KP85 5KP85A 5KP90 5KP90A 5KP100 5KP100A 5KP110 5KP110A 5KP120 5KP120A 5KP130 5KP130A 5KP140 5KP140A 5KP150 5KP150A 5KP160 5KP160A 5KP170 5KP170A 5KP180 5KP180A 5KP190 5KP190A 5000W Bi 5KP45C 5KP45CA 5KP48C 5KP48CA 5KP51C 5KP51CA 5KP54C 5KP54CA 5KP58C 5KP58CA 5KP60C 5KP60CA 5KP64C 5KP64CA 5KP70C 5KP70CA 5KP75C 5KP75CA 5KP78C 5KP78CA 5KP80C 5KP80CA 5KP85C 5KP85CA 5KP90C 5KP90CA 5KP100C 5KP100CA 5KP110C 5KP110CA 5KP120C 5KP120CA 5KP130C 5KP130CA 5KP140C 5KP140CA 5KP150C 5KP150CA 5KP160C 5KP160CA 5KP170C 5KP170CA 5KP180C 5KP180CA 5KP190C 5KP190CA Reverse Stand-Off Voltage VRMW (V) 45.0 45.0 48.0 48.0 51.0 51.0 54.0 54.0 58.0 58.0 60.0 60.0 64.0 64.0 70.0 70.0 75.0 75.0 78.0 78.0 80.0 80.0 85.0 85.0 90.0 90.0 100.0 100.0 110.0 110.0 120.0 120.0 130.0 130.0 140.0 140.0 150.0 150.0 160.0 160.0 170.0 170.0 180.0 180.0 190.0 190.0 Breakdown Voltage VBR (V) @IT MIN 50.00 50.00 53.30 53.30 56.70 56.70 60.00 60.00 64.40 64.40 66.70 66.70 71.10 71.10 77.80 77.80 83.30 83.30 86.70 86.70 88.96 88.80 94.40 94.40 100.00 100.00 111.00 111.00 122.00 122.00 133.00 133.00 144.00 144.00 155.68 155.00 167.00 167.00 178.00 178.00 189.00 189.00 201.00 201.00 211.21 211.00 MAX 61.10 55.30 65.10 58.90 69.30 62.70 73.30 66.30 78.70 71.20 81.50 73.70 86.90 78.60 95.10 86.00 102.00 92.10 106.00 95.80 108.80 97.60 115.00 104.00 122.00 111.00 136.00 123.00 149.00 135.00 163.00 147.00 176.00 159.00 190.40 171.00 204.00 185.00 218.00 197.00 231.00 209.00 244.80 220.00 258.40 232.00 Test Current IT (mA) Maximum Clamping Voltage VC @IPP (V) Maximum Peak Pulse Current IPP (A) Maximum Reverse Leakage IR @VRWM (μA) 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 80.3 72.7 85.5 77.4 91.1 82.4 96.3 87.1 103.0 93.6 107.0 96.8 114.0 103.0 125.0 113.0 134.0 121.0 139.0 126.0 143.2 129.6 151.0 137.0 160.0 146.0 179.0 162.0 196.0 177.0 214.0 193.0 231.0 209.0 250.6 226.8 268.0 243.0 287.0 259.0 304.0 275.0 322.2 291.6 340.1 307.8 62.27 68.78 58.48 64.60 54.88 60.68 51.92 57.41 48.54 53.42 46.73 51.65 43.86 48.54 40.00 44.25 37.31 41.32 35.97 39.68 34.92 38.58 33.11 36.50 31.25 34.25 27.93 30.86 25.51 28.25 23.36 25.91 21.65 23.92 19.95 22.05 18.66 20.58 17.42 19.31 16.45 18.18 15.52 17.15 14.70 16.24 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 Note: 1. Suffix 'A ' denotes 5% tolerance device. Without 'A' denotes 10% tolerance device 2. Add suffix 'C 'or ' CA ' after part number to specify Bi-directional devices 3. For Bi-Directional devices having VR of 10 volts and under, the IR limit is double SOCAY Electronics Co., Ltd. Revision September 25, 2013 www.socay.com 3/6 @ SOCAY Electronics Co., Ltd. 2013 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Axial Lead Transient Voltage Suppressors (TVS) 5KP Series 5.0 To 190 V 5000W Ratings and Characteristic Curves (TA=25°C unless otherwise noted) Figure 1 - Peak Pulse Power Rating Curve Figure 2 - Pulse Derating Curve Peak Pulse Power (PPP) or Current (IPP) Derating in Percentage % PPPM - Peak Pulse Power (kW) 100 10 1 0.1 0.1 1 10 100 td - Pulse Width (μs) 1000 60 40 20 0 0 25 50 75 100 125 TA-Ambient temperature(°C) 150 175 Figure 4 - Typical Junction Capacitance 100000 150 tr=10µsec Peak Value IPPM Bi-directional @zero bins TJ=25°C Pulse Width(td) is defined as the point where the peak current decays to 50% of IPPM CJ – Junction Capacitance (pF) IPPM - Peak Pulse Current, % IRSM 80 10000 Figure 3 - Pulse Waveform 100 Half Value IPPM (IPPM/2) 50 10/1000µsec. Waveform as defined by R.E.A 10000 Uni-directional @zero bins Uni-directional @VRWM 1000 100 tc 0 0 Bi-directional @VRWM 10 Tj=25°C f=1.0MHz Vsig=50mVp-p 1 1.0 2.0 t - Time (ms) 3.0 1.0 4.0 Figure 5 - Steady State Power Derating Curve 10.0 100.0 VBR-Reverse Breakdown Voltage (V) 1000.0 Figure 6 - Maximum Non-Repetitive Surge Current 300 8.0 IFSM-Peak Forward Surge Current (A) PM(AV), Steady State Power Dissipation (W) 100 7.0 6.0 5.0 4.0 3.0 2.0 1.0 TJ=TJ max. 8.3 ms Single Half Sine-Wave 250 200 150 100 0.0 0 25 50 75 100 125 150 TL - Lead Temperature(°C) 175 1 200 SOCAY Electronics Co., Ltd. Revision September 25, 2013 10 Number of Cycles at 60Hz 100 www.socay.com 4/6 @ SOCAY Electronics Co., Ltd. 2013 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Axial Lead Transient Voltage Suppressors (TVS) 5KP Series 5.0 To 190 V 5000W I-V Curve Characteristics Physical Specifications Environmental Specifications Weight 0.07 ounce, 2.1gram Temperature Cycle JESD22-A104 Case JEDEC R-6/P600 Molded Plastic over glass passivated junction Pressure Cooker JESD22-A102 High Temp. Storage JESD22-A103 HTRB JESD22-A108 Thermal Shock JESD22-A106 Color band denotes cathode except Bipolar Matte Tin-plated leads, Solderable per JESD22-B102D Polarity Terminal Soldering Parameters Reflow Condition Lead–free assembly TP Ramp-up Critical Zone TL to TP TL Pre Heat -Temperature Min (Ts(min)) 150°C -Temperature Max (Ts(max)) 200°C - Time (min to max) (ts) 60 -180 Seconds Temperature TS(max) Ramp-down TS(min) Average ramp up rate ( Liquidus Temp TL) to peak 3°C/second max TS(max) to TL - Ramp-up Rate 3°C/second max Preheat Time to peak temperature (t 25℃ to peak) - Temperature (TL) (Liquidus) 217°C - Time (min to max) (ts) 60 -150 Seconds Reflow 25 Time Peak Temperature (TP) Time within 5°C Temperature (tp) SOCAY Electronics Co., Ltd. Revision September 25, 2013 260 +0/-5°C of actual peak 20 -40 Seconds Ramp-down Rate 6°C/second max Time 25°C to peak Temperature (TP) 8 minutes Max Do not exceed 280°C www.socay.com 5/6 @ SOCAY Electronics Co., Ltd. 2013 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Axial Lead Transient Voltage Suppressors (TVS) 5KP Series 5.0 To 190 V 5000W Dimensions Inches R6/P600 Millimeters Dimensions Min Max Min Max A 1.000 - 25.40 - B 0.340 0.360 8.64 9.14 C 0.048 0.052 1.22 1.32 D 0.340 0.360 8.64 9.14 Cathode Band Part Marking Part Numbering 5KP×××CA Cathode Band Socay Logo 5% VBR VOLTAGE TOLERANCE 5KPXXX BI-DIRECTIONAL Product Type VR VOLTAGE SERIES Packaging Part Number Component Package 5KPXXXXX Packaging Dimensions R6/P600 Quantity Packaging Option 200 Box Unit: Inches (Millimeters) 2.56 (65.00) 0.25 (6.35) 0.40±0.020 (10.16±0.508) SOCAY Electronics Co., Ltd. Revision September 25, 2013 www.socay.com 6/6 @ SOCAY Electronics Co., Ltd. 2013 Specifications are subject to change without notice. Please refer to www.socay.com for current information.
5KP36A 价格&库存
很抱歉,暂时无法提供与“5KP36A”相匹配的价格&库存,您可以联系我们找货
