P6KE36CA
P6KE36CA
    SOCAY(硕凯)
    DO-15(DO-204AC)
    TVS二极管 VRWM=30.8V VBR(Min)=34.2V VC=49.9V IPP=12.02A Ppp=600W DO15
P6KE36CA 数据手册
Axial Lead Transient Voltage Suppressors (TVS) P6KE Series 6.8 To 600 V 600W Uni-directional Description Bi-directional The P6KE series is designed specifically to protect sensitive electronic equipment from voltage transients induced by lightning and other transient voltage events. Features u u u u u u u u u u u u u u u u u Glass passivated chip junction in DO-15 Package Low leakage Uni and Bidirectional unit Excellent clamping capability 600W Peak power capability at 10 × 1000µs waveform Repetition rate (duty cycle):0.01% Fast response time: typically less than 1.0ps from 0 Volts to VBR min Typical IR less than 5μA above 12V. High Temperature soldering: 260°C/40 seconds at terminals Typical maximum temperature coefficient ΔVBR = 0.1% × VBR@25°C× ΔT Plastic package has Underwriters Laboratory Flammability 94V-0 Matte tin lead–free Plated Halogen free and RoHS compliant Typical failure mode is short from over-specified voltage or current Whisker test is conducted based on JEDEC JESD201A per its table 4a and 4c IEC-61000-4-2 ESD 15kV(Air), 8kV (Contact) ESD protection of data lines in accordance with IEC 61000-4-2 (IEC801-2) EFT protection of data lines in accordance with IEC 61000-4-4 (IEC801-4) Functional Diagram Bi-directional Cathode Anode Uni-direction Agency Approvals AGENCY Applications AGENCY FILE NUMBER TVS devices are ideal for the protection of I/O interfaces, VCC bus and other vulnerable circuits used in Telecom, Computer, Industrial and Consumer electronic applications. Maximum Ratings E341027 (TA=25℃ unless otherwise noted) Parameter Symbol Value Unit Peak Pulse Power Dissipation with a 10/1000µs waveform (Fig.1)(Note 1), (Note 2) PPPM 600 Watts Amps Peak Pulse Current with a 10/1000µs waveform.(Note1,Fig.3) IPP See Next Table PM(AV) 5.0 Watt Peak Forward Surge Current, 8.3ms Single Half Sine Wave (Note 3) IFSM 100 Amps Maximum Instantaneous Forward Voltage at 25A for Unidirectional Only (Note 4) VF 3.5/5.0 Voltage TJ , TSTG -55 to +150 °C Power Dissipation on Infinite Heat Sink at TL=75°C Operating junction and Storage Temperature Range. Notes: 1. Non-repetitive current pulse, per Fig. 3 and derated above TA = 25°C per Fig. 2. 2. Mounted on 5.0mm x 5.0mm (0.03mm thick) Copper Pads to each terminal. 3. 8.3ms single half sine-wave, or equivalent square wave, Duty cycle = 4 pulses per minutes maximum. 4. VF < 3.5V for VBR < 200V and VF< 6.5V for VBR > 201V. SOCAY Electronics Co., Ltd. Revision September 25, 2013 www.socay.com 1/6 @ SOCAY Electronics Co., Ltd. 2013 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Axial Lead Transient Voltage Suppressors (TVS) P6KE Series 6.8 To 600 V Electrical Characteristics (TA=25℃ unless otherwise noted) Part Number Uni P6KE6.8 P6KE6.8A P6KE7.5 P6KE7.5A P6KE8.2 P6KE8.2A P6KE9.1 P6KE9.1A P6KE10 P6KE10A P6KE11 P6KE11A P6KE12 P6KE12A P6KE13 P6KE13A P6KE15 P6KE15A P6KE16 P6KE16A P6KE18 P6KE18A P6KE20 P6KE20A P6KE22 P6KE22A P6KE24 P6KE24A P6KE27 P6KE27A P6KE30 P6KE30A P6KE33 P6KE33A P6KE36 P6KE36A P6KE39 P6KE39A P6KE43 P6KE43A P6KE47 P6KE47A P6KE51 P6KE51A P6KE56 P6KE56A P6KE62 P6KE62A P6KE68 P6KE68A P6KE75 P6KE75A P6KE82 P6KE82A 600W Bi P6KE6.8C P6KE6.8CA P6KE7.5C P6KE7.5CA P6KE8.2C P6KE8.2CA P6KE9.1C P6KE9.1CA P6KE10C P6KE10CA P6KE11C P6KE11CA P6KE12C P6KE12CA P6KE13C P6KE13CA P6KE15C P6KE15CA P6KE16C P6KE16CA P6KE18C P6KE18CA P6KE20C P6KE20CA P6KE22C P6KE22CA P6KE24C P6KE24CA P6KE27C P6KE27CA P6KE30C P6KE30CA P6KE33C P6KE33CA P6KE36C P6KE36CA P6KE39C P6KE39CA P6KE43C P6KE43CA P6KE47C P6KE47CA P6KE51C P6KE51CA P6KE56C P6KE56CA P6KE62C P6KE62CA P6KE68C P6KE68CA P6KE75C P6KE75CA P6KE82C P6KE82CA Reverse Stand-Off Voltage VRWM (V) 5.5 5.8 6.1 6.4 6.6 7.0 7.4 7.8 8.1 8.6 8.9 9.4 9.7 10.2 10.5 11.1 12.1 12.8 12.9 13.6 14.5 15.3 16.2 17.1 17.8 18.8 19.4 20.5 21.8 23.1 24.3 25.6 26.8 28.2 29.1 30.8 31.6 33.3 34.8 36.8 38.1 40.2 41.3 43.6 45.4 47.8 50.2 53.0 55.1 58.1 60.7 64.1 66.4 70.1 Breakdown Voltage VBR (V) @IT MIN 6.12 6.46 6.75 7.13 7.38 7.79 8.19 8.65 9.00 9.50 9.90 10.45 10.80 11.40 11.70 12.35 13.50 14.25 14.40 15.20 16.20 17.10 18.00 19.00 19.80 20.90 21.60 22.80 24.30 25.65 27.00 28.50 29.70 31.35 32.40 34.20 35.10 37.05 38.70 40.85 42.30 44.65 45.90 48.45 50.40 53.20 55.80 58.90 61.20 64.60 67.50 71.25 73.80 77.90 MAX 7.48 7.14 8.25 7.88 9.02 8.61 10.01 9.56 11.00 10.50 12.10 11.55 13.20 12.60 14.30 13.65 16.50 15.75 17.60 16.80 19.80 18.90 22.00 21.00 24.20 23.10 26.40 25.20 29.70 28.35 33.00 31.50 36.30 34.65 39.60 37.80 42.90 40.95 47.30 45.15 51.70 49.35 56.10 53.55 61.60 58.80 68.20 65.10 74.80 71.40 82.50 78.75 90.20 86.10 SOCAY Electronics Co., Ltd. Revision September 25, 2013 Test Current IT (mA) Maximum Clamping Voltage VC @IPP (V) Maximum Peak Pulse Current IPP (A) Maximum Reverse Leakage IR @VRWM (μA) 10 10 10 10 10 10 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 10.8 10.5 11.7 11.3 12.5 12.1 13.8 13.4 15.0 14.5 16.2 15.6 17.3 16.7 19.0 18.2 22.0 21.2 23.5 22.5 26.5 25.2 29.1 27.7 31.9 30.6 34.7 33.2 39.1 37.5 43.5 41.4 47.7 45.7 52.0 49.9 56.4 53.9 61.9 59.3 67.8 64.8 73.5 70.1 80.5 77.0 89.0 85.0 98.0 92.0 108.0 103.0 118.0 113.0 55.56 57.14 51.28 53.10 48.00 49.59 43.48 44.78 40.00 41.38 37.04 38.46 34.68 35.93 31.58 32.97 27.27 28.30 25.53 26.67 22.64 23.81 20.62 21.66 18.81 19.61 17.29 18.07 15.35 16.00 13.79 14.49 12.58 13.13 11.54 12.02 10.64 11.13 9.69 10.12 8.85 9.26 8.16 8.56 7.45 7.79 6.74 7.06 6.12 6.52 5.56 5.83 5.08 5.31 1000 1000 500 500 200 200 50 50 10 10 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 www.socay.com 2/6 @ SOCAY Electronics Co., Ltd. 2013 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Axial Lead Transient Voltage Suppressors (TVS) P6KE Series 6.8 To 600 V Electrical Characteristics 600W (TA=25℃ unless otherwise noted) (Continue) Part Number Uni Bi P6KE91 P6KE91A P6KE100 P6KE100A P6KE110 P6KE110A P6KE120 P6KE120A P6KE130 P6KE130A P6KE150 P6KE150A P6KE160 P6KE160A P6KE170 P6KE170A P6KE180 P6KE180A P6KE200 P6KE200A P6KE220 P6KE220A P6KE250 P6KE250A P6KE300 P6KE300A P6KE350 P6KE350A P6KE380 P6KE380A P6KE400 P6KE400A P6KE440 P6KE440A P6KE500 P6KE500A P6KE520 P6KE520A P6KE550 P6KE550A P6KE600 P6KE600A P6KE91C P6KE91CA P6KE100C P6KE100CA P6KE110C P6KE110CA P6KE120C P6KE120CA P6KE130C P6KE130CA P6KE150C P6KE150CA P6KE160C P6KE160CA P6KE170C P6KE170CA P6KE180C P6KE180CA P6KE200C P6KE200CA P6KE220C P6KE220CA P6KE250C P6KE250CA P6KE300C P6KE300CA P6KE350C P6KE350CA P6KE380C P6KE380CA P6KE400C P6KE400CA P6KE440C P6KE440CA P6KE500C P6KE500CA P6KE520C P6KE520CA P6KE550C P6KE550CA P6KE600C P6KE600CA Reverse Stand-Off Voltage VRWM (V) 73.7 77.8 81.0 85.5 89.2 94.0 97.2 102.0 105.0 111.0 121.0 128.0 130.0 136.0 138.0 145.0 146.0 154.0 162.0 171.0 175.0 185.0 202.0 214.0 243.0 256.0 284.0 299.3 308.6 324.9 324.8 342.0 357.3 376.2 406.0 427.5 422.2 444.6 446.6 470.3 487.2 513.0 Breakdown Voltage VBR (V) @IT MIN MAX 81.90 86.45 90.00 95.00 99.00 104.50 108.00 114.00 117.00 123.50 135.00 142.50 144.00 152.00 153.00 161.50 162.00 171.00 180.00 190.00 198.00 209.00 225.00 237.50 270.00 285.00 315.00 332.50 342.00 361.00 360.00 380.00 396.00 418.00 450.00 475.00 468.00 494.00 495.00 522.50 540.00 570.00 100.10 95.55 110.00 105.00 121.00 115.50 132.00 126.00 143.00 136.50 165.00 157.50 176.00 168.00 187.00 178.50 198.00 189.00 220.00 210.00 242.00 231.00 275.00 262.50 330.00 315.00 385.00 367.50 418.00 399.00 440.00 420.00 484.00 462.00 550.00 525.00 572.00 546.00 605.00 577.50 660.00 630.00 Test Current IT (mA) Maximum Clamping Voltage VC @IPP (V) Maximum Peak Pulse Current IPP (A) Maximum Reverse Leakage IR @VRWM (μA) 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 131.0 125.0 144.0 137.0 158.0 152.0 173.0 165.0 187.0 179.0 215.0 207.0 230.0 219.0 244.0 234.0 258.0 246.0 287.0 274.0 344.0 328.0 360.0 344.0 430.0 414.0 504.0 482.0 547.2 524.4 576.0 552.0 633.6 607.2 720.0 690.0 748.8 717.6 792.0 759.0 864.0 828.0 4.58 4.80 4.17 4.38 3.80 3.95 3,47 3.64 3.21 3.35 2.79 2.90 2.61 2.74 2.46 2.56 2.33 2.44 2.09 2.19 174 1.83 1.67 1.74 1.40 1.45 1.19 1.24 1.10 1.14 1.05 1.09 0.95 0.99 0.83 0.87 0.80 0.84 0.76 0.79 0.69 0.72 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 Note: 1. Suffix 'A ' denotes 5% tolerance device. Without 'A' denotes 10% tolerance device 2. Add suffix 'C 'or ' CA ' after part number to specify Bi-directional devices 3. For Bi-Directional devices having VR of 10 volts and under, the IR limit is double SOCAY Electronics Co., Ltd. Revision September 25, 2013 www.socay.com 3/6 @ SOCAY Electronics Co., Ltd. 2013 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Axial Lead Transient Voltage Suppressors (TVS) P6KE Series 6.8 To 600 V 600W Ratings and Characteristic Curves (TA=25°C unless otherwise noted) Figure 1 - Peak Pulse Power Rating Curve Figure 2 - Pulse Derating Curve Peak Pulse Power (PPP) or Current (IPP) Derating in Percentage % PPPM - Peak Pulse Power (kW) 100 10 1 100 80 60 40 20 0 0.1 0.1 1 10 100 td - Pulse Width (μs) 1000 0 10000 Figure 3 - Pulse Waveform 150 175 10000 tr=10µsec Bi-directional @zero bins TJ=25°C Pulse Width(td) is defined as the point where the peak current decays to 50% of IPPM Peak Value IPPM Uni-directional @zero bins 1000 100 Uni-directional @VRWM Cj (pF) IPPM - Peak Pulse Current, % IRSM 50 75 100 125 TA-Ambient temperature(°C) Figure 4 - Typical Junction Capacitance 150 Half Value IPPM (IPPM/2) 50 100 10/1000µsec. Waveform as defined by R.E.A 10 Tj=25°C f=1.0MHz Vsig=50mVp-p tc 0 0 Bi-directional @VRWM 1 1.0 2.0 t - Time (ms) 3.0 1.0 4.0 10.0 100.0 1000.0 VBR-Reverse Breakdown Voltage (V) Figure 5 - Steady State Power Derating Curve Figure 6 - Maximum Non-Repetitive Surge Current 5.0 100 IFSM-Peak Forward Surge Current (A) PM(AV), Steady State Power Dissipation (W) 25 4.0 3.0 2.0 1.0 0.0 TJ=TJ max. 8.3 ms Single Half Sine-Wave 80 60 40 20 0 0 25 50 75 100 125 150 175 200 1 TL - Lead Temperature(°C) SOCAY Electronics Co., Ltd. Revision September 25, 2013 10 Number of Cycles at 60Hz 100 www.socay.com 4/6 @ SOCAY Electronics Co., Ltd. 2013 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Axial Lead Transient Voltage Suppressors (TVS) P6KE Series 6.8 To 600 V 600W I-V Curve Characteristics Physical Specifications Environmental Specifications Weight 0.015 ounce, 0.4 gram Temperature Cycle JESD22-A104 Case JEDEC DO-204AC (DO-15) Molded Plastic over glass passivated junction Pressure Cooker JESD22-A102 Color band denotes cathode except Bipolar High Temp. Storage JESD22-A103 Polarity HTRB JESD22-A108 Terminal Matte Tin-plated leads, Solderable per JESD22-B102D Thermal Shock JESD22-A106 Soldering Parameters Reflow Condition Lead–free assembly TP Ramp-up Critical Zone TL to TP TL Pre Heat -Temperature Min (Ts(min)) 150°C -Temperature Max (Ts(max)) 200°C - Time (min to max) (ts) 60 -180 Seconds Temperature TS(max) Ramp-down TS(min) Average ramp up rate ( Liquidus Temp TL) to peak 3°C/second max TS(max) to TL - Ramp-up Rate 3°C/second max Preheat 25 Time to peak temperature (t 25℃ to peak) - Temperature (TL) (Liquidus) 217°C - Time (min to max) (ts) 60 -150 Seconds Reflow Time Peak Temperature (TP) Time within 5°C Temperature (tp) SOCAY Electronics Co., Ltd. Revision September 25, 2013 260 +0/-5°C of actual peak 20 -40 Seconds Ramp-down Rate 6°C/second max Time 25°C to peak Temperature (TP) 8 minutes Max Do not exceed 280°C www.socay.com 5/6 @ SOCAY Electronics Co., Ltd. 2013 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Axial Lead Transient Voltage Suppressors (TVS) P6KE Series 6.8 To 600 V 600W Dimensions Inches DO-204AC (DO-15) Millimeters Dimensions Min Max Min Max A 1.000 - 25.40 - B 0.230 0.300 5.85 7.63 C 0.028 0.033 0.71 0.84 D 0.102 0.142 2.60 3.61 Cathode Band Part Marking Part Numbering P6KE×××CA Cathode Band Socay Logo 5% VBR VOLTAGE TOLERANCE P6KEXXX BI-DIRECTIONAL Product Type VR VOLTAGE SERIES Packaging Part Number Component Package Quantity Packaging Option P6KEXXXXX DO-204AC (DO-15) 2000 Box Packaging Dimensions Unit: Inches (Millimeters) 2.56 (65.00) 0.25 (6.35) 0.20±0.020 (5.08±0.508) SOCAY Electronics Co., Ltd. Revision September 25, 2013 www.socay.com 6/6 @ SOCAY Electronics Co., Ltd. 2013 Specifications are subject to change without notice. Please refer to www.socay.com for current information.
P6KE36CA 价格&库存
很抱歉,暂时无法提供与“P6KE36CA”相匹配的价格&库存,您可以联系我们找货
