Radial Lead Resettable Polymer PTCs
SC30 Series
Description
SC30 series radial leaded PTCs are designed to provide
over-current protection for low voltage (≤30V) applications
where space is not a concern and resettable protection is
preferred.
Features
Cured, flame retardant epoxy polymer meets UL 94V-0
requirements
30V operating voltage
Fast time-to-trip
RoHS compliant, Lead-Free and Halogen-Free
Applications
Computers and peripherals
Power ports
Motor protection
Automotive application
USB hubs ,ports and peripherals
General electronics
Electrical Parameters
Part Number
I hold (A)
I trip (A)
V max
(Vdc)
I max
(A)
P dtyp.
(W)
Maximum Time
To Trip
Current
(A)
Resistance
Time
(Sec.)
R min
(mΩ)
SC30-040
0.40
0.8
30
40
0.45
2.00
3.10
320
SC30-050
0.50
1.0
30
40
0.50
2.50
3.80
240
SC30-065
0.65
1.3
30
40
0.50
3.25
4.50
160
SC30-075
0.75
1.5
30
40
0.55
3.75
5.20
135
SC30-090
0.90
1.8
30
40
0.60
4.50
5.90
110
SC30-110
1.10
2.2
30
40
0.70
5.50
6.60
85
SC30-135
1.35
2.7
30
40
0.80
6.75
7.30
65
SC30-160
1.60
3.2
30
40
0.90
8.00
8.00
55
SC30-185
1.85
3.7
30
40
1.00
9.25
8.70
45
SC30-250
2.5
5.0
30
40
1.20
12.5
10.3
35
SC30-300
3.0
6.0
30
100
2.0
15.0
10.8
30
SC30-400
4.0
8.0
30
100
2.5
20.0
12.7
SC30-500
5.0
10.0
30
100
3.0
25.0
14.5
15
SC30-600
6.0
12.0
30
100
3.5
30.0
16.0
12
SC30-700
7.0
14.0
30
100
3.8
35.0
17.5
10
SC30-800
8.0
16.0
30
100
4.0
40.0
18.8
8
SC30-900
9.0
18.0
30
100
4.2
45.0
20.0
7
I hold= Hold current: maximum current device will pass without tripping in 25°C still air.
I trip= Trip current: minimum current at which the device will trip in 25°C still air.
V max= Maximum voltage that can be safely placed across a device in its tripped state under specified fault conditions.
I max= Maximum fault current device can withstand without damage at rated voltage (Vmax)
Pdtyp.= Power dissipated from device when in the tripped state at 25°C still air.
R min= Minimum resistance of device in initial (un-soldered) state.
R max= Maximum resistance of device in initial (un-soldered) state.
R 1max= Maximum resistance of device at 25°C measured one hour after tripping.
Caution: Operation beyond the specified rating may result in damage and possible arcing and flame.
SOCAY Electronics Corp., Ltd.
Revision November 02, 2017
R max
(mΩ)
R 1max
(mΩ)
800
600
360
300
220
170
130
110
90
70
60
40
30
24
14
1200
900
540
450
330
230
165
140
110
90
80
50
40
30
25
www.socay.com
1/4
@ SOCAY Electronics Corp., Ltd. 2017
Specifications are subject to change without notice.
Please refer to www.socay.com for current information.
SC30 Series
Temperature Rerating Chart – I hold (A)
Ambient Operation Temperature
Part Number
-40°C
-20°C
0°C
25°C
40°C
50°C
60°C
70°C
85°C
Hold Current (A)
SC30-040
0.58
0.52
0.46
0.40
0.33
0.31
0.27
0.24
0.21
SC30-050
0.73
0.65
0.58
0.50
0.42
0.39
0.34
0.31
0.26
SC30-065
0.94
0.85
0.75
0.65
0.54
0.50
0.44
0.40
0.34
SC30-075
1.09
0.98
0.86
0.75
0.62
0.58
0.51
0.46
0.39
SC30-090
1.31
1.17
1.04
0.90
0.75
0.69
0.61
0.55
0.47
SC30-110
1.60
1.43
1.27
1.10
0.91
0.85
0.75
0.67
0.57
SC30-135
1.96
1.76
1.55
1.35
1.12
1.04
0.92
0.82
0.70
SC30-160
2.32
2.08
1.84
1.60
1.33
1.23
1.09
0.98
0.83
SC30-185
2.68
2.41
2.13
1.85
1.54
1.42
1.26
1.13
0.96
SC30-250
3.63
3.25
2.88
2.50
2.08
1.93
1.70
1.53
1.30
SC30-300
4.35
3.90
3.45
3.00
2.49
2.31
2.04
1.83
1.56
SC30-400
5.80
5.20
4.60
4.00
3.32
3.08
2.72
2.44
2.08
SC30-500
7.25
6.50
5.75
5.00
4.15
3.85
3.40
3.05
2.60
SC30-600
8.70
7.80
6.90
6.00
4.98
4.62
4.08
3.66
3.12
SC30-700
10.15
9.10
8.05
7.00
5.81
5.39
4.76
4.27
3.64
SC30-800
11.60
10.40
9.20
8.00
6.64
6.16
5.44
4.88
4.16
SC30-900
13.05
11.70
10.35
9.00
7.47
6.93
6.12
5.49
4.68
Average Time Current Curves
Temperature Rerating Curve
Percentage of Rated Current
1000
Time in Seconds
100
10
1
0.1
0.01
0.001
1
10
Temperature (°C)
100
Current in Amperes
A=SC30-090
B=SC30-110
C=SC30-135
D=SC30-160
E=SC30-185
F=SC30-250
G=SC30-300
H=SC30-400
I=SC30-500
J=SC30-600
K=SC30-700
L=SC30-800
M=SC30-900
www.socay.com
2/4
SC30 Series
Test Procedures and Requirement
Test
Test Conditions
Accept/Reject Criteria
Resistance
In still air @25±2°C
Rmin≤R≤Rmax
Hold Current
60 min, at Ihold, In still air @25±2°C
No trip
Time to Trip
Specified current, Vmax, @25±2°C
T≤Maximum Time To Trip
Trip Cycle Life
Vmax, Imax,100 cycles
No arcing or burning
Trip Endurance
Vmax,24hours
Soldering Parameters
Pre-Heating Zone
Refer to the condition recommended
by the manufacturer. Max. ramping
rate should not exceed 4°C/Sec
Soldering Zone
Max. solder temperature should not
exceed 260°C
Cooling Zone
Cooling by natural convection in air
Physical Specifications
Lead Material
Soldering Characteristics
Insulating Material
Device Labeling
0.4-1.85A Tin-plated Copper clad steel
2.5-9.0A Tin-plated Copper
Solder ability per MIL-STD-202, Method 208E
Cured, flame retardant epoxy polymer meets UL 94V-0 requirements.
Marked with ‘SC’, voltage, current rating
Part Numbering
Part Marking
www.socay.com
3/4
SC30 Series
Dimensions
Figure1
Figure2
A
Part
Number
Figure
SC30-040
SC30-050
B
Figure3
C
D
Lead (dia)
Inches
mm
Inches
mm
Inches
mm
Inches
mm
Max.
Max.
Max.
Max.
Typ.
Typ.
Max.
Max.
Figure1
0.236
6.0
0.445
11.3
0.200±0.020
5.1±0.5
0.118
Figure1
0.236
6.0
0.472
12.0
0.200±0.020
5.1±0.5
0.118
SC30-065
Figure1
0.276
7.0
0.472
12.0
0.200±0.020
5.1±0.5
SC30-075
Figure1
0.283
7.2
0.480
12.2
0.200±0.020
SC30-090
Figure2
0.276
7.0
0.472
12.0
SC30-110
Figure2
0.256
6.5
0.571
14.5
SC30-135
Figure2
0.346
8.8
0.543
SC30-160
Figure2
0.346
8.8
SC30-185
Figure2
0.394
SC30-250
Figure2
0.445
SC30-300
Figure3
SC30-400
Figure3
SC30-500
Packaging
Inches
mm
(Bulk Pack)
3.0
0.020
0.5
1000
3.0
0.020
0.5
1000
0.118
3.0
0.020
0.5
1000
5.1±0.5
0.118
3.0
0.020
0.5
1000
0.200±0.020
5.1±0.5
0.118
3.0
0.020
0.5
1000
0.200±0.020
5.1±0.5
0.118
3.0
0.020
0.5
1000
13.8
0.200±0.020
5.1±0.5
0.118
3.0
0.020
0.5
1000
0.610
15.5
0.200±0.020
5.1±0.5
0.118
3.0
0.020
0.5
1000
10.0
0.630
16.0
0.200±0.020
5.1±0.5
0.118
3.0
0.020
0.5
1000
11.3
0.728
18.5
0.200±0.020
5.1±0.5
0.118
3.0
0.020
0.5
1000
0.445
11.3
0.669
17.0
0.200±0.020
5.1±0.5
0.118
3.0
0.031
0.8
1000
0.531
13.5
0.700
17.8
0.200±0.020
5.1±0.5
0.118
3.0
0.031
0.8
500
Figure3
0.570
14.5
0.925
23.5
0.400±0.020
10.2±0.5
0.118
3.0
0.031
0.8
500
SC30-600
Figure3
0.630
16.0
0.925
23.5
0.400±0.020
10.2±0.5
0.118
3.0
0.031
0.8
500
SC30-700
Figure3
0.728
18.5
0.965
24.5
0.400±0.020
10.2±0.5
0.118
3.0
0.031
0.8
200
SC30-800
Figure3
0.827
21.0
1.102
28.0
0.400±0.020
10.2±0.5
0.118
3.0
0.031
0.8
200
SC30-900
Figure3
0.965
24.5
1.102
28.0
0.400±0.020
10.2±0.5
0.118
3.0
0.031
0.8
200
Warning
This product should not be used in an application where the maximum interrupt voltage or maximum interrupt current in a fault
condition, Operation beyond the maximum rating or improper use may result in device damage and possible electrical arcing
and flame.
A PPTC device is not a fuse, It is a nonlinear thermistor that limits current, Because under a fault condition all PPTC devices
go into a high resistance state but not open circuit hazardous voltage may be present at PPTC.
The devices are intended for protection against occasional over-current or over-temperature fault conditions and should not
be used when repeated fault conditions or prolonged trip events.
In most application, power must be removed and the fault condition cleared in order to reset a PPTC device.
PPTC devices are not recommended to be installed in applications where the device is constrained such that its PPTC
properties are inhibited, for example in rigid potting materials or Add devices surface coating, Bundled devices ontology, which
lack adequate clearance to accommodate device expansion.
Contamination on of the PPTC material with certain silicone-based oils or some aggressive solvents can adversely impact the
performance of the devices. For example, Organic solvents to cleaning.
www.socay.com
4/4
很抱歉,暂时无法提供与“SC30-400”相匹配的价格&库存,您可以联系我们找货
