Surface Mount Resettable PTCs
SCF0603 Series
Description
The SCF0603 Series PTC provides surface mount
over-current protection for applications where space is at a
premium and resettable protection is desired.
Features
u
u
u
u
u
RoHS compliant, Lead-Free and Halogen-Free
Fast time-to-trip
Compact design saves board space
Low resistance
Low-profile
Applications
u
u
u
u
u
u
u
u
PC motherboard - plug and play protection
Mobile phones - battery and port protection
Game console port protection
USB peripherals
Disk drive
PDAS / digital cameras
Power ports
General electronics
Electrical Parameters
Part Number
Hold
Current
Trip
Current
I hold (A)
I trip
(A)
Rated
Voltage
Max
Current
Typical
Power
Maximum Time
To Trip
V max
(Vdc)
I max
(A)
P dtyp.
(W)
Current
(A)
Time
(Sec.)
R min
(Ω)
R 1max
(Ω)
Resistance
SCF001-0603R
0.01
0.03
60
40
0.5
0.20
1.00
15.00
100.00
SCF002-0603R
0.02
0.06
60
40
0.5
0.20
1.00
12.00
70.00
SCF003-0603R
0.03
0.09
30
40
0.5
0.20
1.00
6.00
50.00
SCF004-0603R
0.04
0.12
24
40
0.5
0.20
1.00
4.00
40.00
SCF005-0603R
0.05
0.15
15
40
0.5
0.50
0.10
3.80
30.00
SCF010-0603R
0.10
0.25
15
40
0.5
0.70
0.10
0.90
8.00
SCF012-0603R
0.12
0.30
9
40
0.5
0.80
0.10
1.10
5.80
SCF016-0603R
0.16
0.40
9
40
0.5
1.00
0.10
1.00
4.20
SCF020-0603R
0.20
0.45
9
40
0.5
2.00
0.10
0.55
3.50
I hold= Hold current: maximum current device will pass without tripping in 23°C still air.
I trip= Trip current: minimum current at which the device will trip in 23°C still air.
V max= Maximum voltage device can withstand without damage at rated current (Imax)
I max= Maximum fault current device can withstand without damage at rated voltage (Vmax)
Pdtyp.= Power dissipated from device when in the tripped state at 23°C still air.
R min= Minimum resistance of device in initial (un-soldered) state.
R 1max= Maximum resistance of device at 23°C measured one hour after tripping.
Caution: Operation beyond the specified rating may result in damage and possible arcing and flame.
SOCAY Electronics Co., Ltd.
Revision December 31, 2015
www.socay.com
1/4
@ SOCAY Electronics Co., Ltd. 2015
Specifications are subject to change without notice.
Please refer to www.socay.com for current information.
SCF0603 Series
Temperature Rerating Chart – I hold (A)
Average Time Current Curves
Temperature Derating Curve
Fault Current (A)
A= SCF001-0603R
B= SCF002-0603R
C= SCF003-0603R
D= SCF004-0603R
E= SCF005-0603R
Ambient Temperature (°C)
F= SCF010-0603R
G= SCF012-0603R
H= SCF016-0603R
I = SCF020-0603R
Material Specifications
Terminal pad material
Pure Tin
Soldering Characteristics
Meets EIA specification RS 186-9E, ANSI/J-std-002 Category 3
Soldering Parameters
TP
Ramp-up
Critical Zone
TL to TP
TL
Temperature
TS(max)
Ramp-down
TS(min)
Preheat
25
Time to peak temperature
(t 25℃ to peak)
Time
Profile Feature
Pb-Free Assembly
Average Ramp-Up Rate (TS max to TP)
3°C/second max.
Preheat :
Temperature Min (TSmin)
Temperature Max (TSmax)
Time (TSmin to TSmax)
Time maintained above:
Temperature(TL)
Time (TL)
217°C
60-150 seconds
Peak/Classification Temperature(TP):
260°C
Time within 5°C of actual peak:
Temperature
20-40 seconds
Ramp-down Rate:
6°C/ second max.
Time 25°C to Peak Temperature
8 minutes max.
150°C
200°C
60-180 seconds
Note: All temperatures refer to of the package, measured on the package body surface.
Solder reflow
Caution:
Due to “Lead Free” nature, Temperature and Dwelling time for the
soldering zone is higher than those for Regular. This may cause
damage to other components.
1. Recommended max past thickness > 0.25mm.
2. Devices can be cleaned using standard methods and aqueous
solvent.
3. Rework use standard industry practices.
4. Storage Environment : < 30℃/ 60%RH
1. If reflow temperatures exceed the recommended profile, devices
may not meet the performance requirements.
2. Devices are not designed to be wave soldered to the bottom side
of the board.
www.socay.com
2/4
SCF0603 Series
Part Marking
Part Numbering
SCF XXX – 0603R
X
D
Part Identification
Device Size Code
Example
Hold Current
Socay Product Code
Pad Layouts
Unit: mm
The dimension in the table below provide the recommended
pad layout for each SCF0603 device
A
B
C
Nominal
Nominal
Nominal
0.80
0.60
0.80
Device
0603 Series
Dimensions
X=SCF001-0603R
Y=SCF002-0603R
Z=SCF003-0603R
A=SCF004-0603R
B=SCF005-0603R
D=SCF010-0603R
E=SCF012-0603R
F=SCF016-0603R
G=SCF020-0603R
Unit: mm
A
B
C
D
E
Part Number
SCF001-0603R
Min.
Max.
Min.
Max.
Min.
Max.
Min.
Max.
Min.
Max.
1.40
1.80
0.45
1.00
0.35
0.85
0.10
0.50
0.08
0.40
SCF002-0603R
1.40
1.80
0.45
1.00
0.35
0.85
0.10
0.50
0.08
0.40
SCF003-0603R
1.40
1.80
0.45
1.00
0.35
0.75
0.10
0.50
0.08
0.40
SCF004-0603R
1.40
1.80
0.45
1.00
0.35
0.75
0.10
0.50
0.08
0.40
SCF005-0603R
1.40
1.80
0.45
1.00
0.35
0.75
0.10
0.50
0.08
0.40
SCF010-0603R
1.40
1.80
0.45
1.00
0.35
0.75
0.10
0.50
0.08
0.40
SCF012-0603R
1.40
1.80
0.45
1.00
0.35
0.75
0.10
0.50
0.08
0.40
SCF016-0603R
1.40
1.80
0.45
1.00
0.35
0.75
0.10
0.50
0.08
0.40
SCF020-0603R
1.40
1.80
0.45
1.00
0.35
0.75
0.10
0.50
0.08
0.40
www.socay.com
3/4
SCF0603 Series
Packaging
Part Number
Packaging Option
Quantity
SCF001-0603R
Tape & Reel -8mm/7″tape
4000
SCF002-0603R
4000
SCF003-0603R
4000
SCF004-0603R
4000
SCF005-0603R
4000
SCF010-0603R
4000
SCF012-0603R
4000
SCF016-0603R
4000
SCF020-0603R
4000
Tape and Reel Specifications
7.0
(177.8)
0.157
(4.0)
Packag
0.059 Diameter
(1.5)
0.314
(8.0)
0.212
(5.4)
0.512(13.0)
Arbor Hole Diameter
0.157
(4.0)
Cover tape
0.33
(8.4)
Direction of Feed
Dimensions are in inches
(and millimeters)
Warning
u
Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or
flame.
u
PPTC device are intended for occasional over-current protection. Application for repeated over-current condition and/or
prolonged trip are not anticipated.
u
Avoid contact of PPTC device with chemical solvent. Prolonged contact will damage the device performance.
www.socay.com
4/4
很抱歉,暂时无法提供与“SCF005-0603R”相匹配的价格&库存,您可以联系我们找货
