Surface Mount Resettable PTCs
SCF2920 Series
Description
The SCF2920 Series PTC provides surface mount
over-current protection for applications where space is at a
premium and resettable protection is desired.
Features
RoHS compliant, Lead-Free and Halogen-Free
Fast time-to-trip
Compact design saves board space
Low resistance
Low-profile
Applications
PC motherboard - plug and play protection
Mobile phones - battery and port protection
Game console port protection
USB peripherals
Disk drive
PDAS / digital cameras
Power ports
General electronics
Electrical Parameters
Part Number
SCF030-2920R
SCF050-2920R
SCF075-2920R
SCF075-60-2920R
SCF100-2920R
SCF100-60-2920R
SCF125-2920R
SCF150-2920R
SCF185-2920R
SCF200-2920R
SCF200-24-2920R
SCF250-2920R
SCF260-2920R
SCF260-24-2920R
SCF300-2920R
SCF300-15-2920R
SCF300-24-2920R
SCF500-16-2920R
Hold
Current
Trip
Current
Rated
Voltage
Max
Current
Typical
Power
Maximum Time
To Trip
I hold (A)
I trip (A)
V max
(Vdc)
I max
(A)
P dtyp.
(W)
Current
(A)
Time
(Sec.)
R min
(Ω)
R 1max
(Ω)
0.30
0.50
0.75
0.75
1.10
1.10
1.25
1.50
1.85
2.00
2.00
2.50
2.60
2.60
3.00
3.00
3.00
5.00
0.60
1.00
1.50
1.50
2.20
2.20
2.50
3.00
3.70
4.00
4.00
5.00
5.20
5.20
5.20
5.20
5.20
10.0
60
60
33
60
33
60
33
33
33
16
24
16
6
24
6
15
24
16
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
1.5
1.5
1.5
1.5
1.5
1.5
1.5
1.5
1.5
1.5
1.5
1.5
1.5
1.5
1.5
1.5
1.5
1.5
1.5
2.5
8.0
8.0
8.0
8.0
8.0
8.0
8.0
8.0
8.0
8.0
8.0
8.0
8.0
8.0
8.0
20.0
3.0
4.0
0.3
0.3
0.5
0.5
2.0
2.0
2.5
4.5
5.0
16.0
20.0
20.0
25.0
25.0
25.0
5.0
1.000
0.300
0.180
0.180
0.090
0.090
0.050
0.050
0.040
0.035
0.035
0.025
0.020
0.020
0.010
0.010
0.010
0.005
4.800
1.400
1.000
1.000
0.410
0.410
0.250
0.230
0.150
0.120
0.120
0.085
0.075
0.075
0.048
0.048
0.048
0.025
Resistance
I hold= Hold current: maximum current device will pass without tripping in 23°C still air.
I trip= Trip current: minimum current at which the device will trip in 23°C still air.
V max= Maximum voltage device can withstand without damage at rated current (Imax)
I max= Maximum fault current device can withstand without damage at rated voltage (Vmax)
Pdtyp.= Power dissipated from device when in the tripped state at 23°C still air.
R min= Minimum resistance of device in initial (un-soldered) state.
R 1max= Maximum resistance of device at 23°C measured one hour after tripping.
Caution: Operation beyond the specified rating may result in damage and possible arcing and flame.
SOCAY Electronics Corp., Ltd.
Revision March 16, 2017
www.socay.com
1/4
@ SOCAY Electronics Corp., Ltd. 2017
Specifications are subject to change without notice.
Please refer to www.socay.com for current information.
SCF2920 Series
Temperature Rerating Chart – I hold (A)
5Average Time Current Curves
Temperature Derating Curve
A
B
Ambient Temperature (°C)
Fault Current (A)
A= SCF030-2920R
B= SCF050-2920R
C= SCF075-2920R
/SCF075-60-2920R
D= SCF100-2920R
/SCF100-60-2920R
E= SCF125-2920R
F= SCF150-2920R
G= SCF185-2920R
H= SCF200-2920R
/SCF200-24-2920R
I= SCF250-2920R
J= SCF260-2920R
/SCF260-24-2920R
K= SCF300-2920R/
/SCF300-15-2920R
/SCF300-24-2920R
A=SCF125-2920R ~ SCF300-2920R
B=SCF030-2920R ~ SCF100-2920R
Material Specifications
Terminal pad material
Pure Tin
Soldering Characteristics
Meets EIA specification RS 186-9E, ANSI/J-std-002 Category 3
Soldering Parameters
TP
Ramp-up
TL
Critical Zone
TL to TP
Temperature
TS(max)
Ramp-down
TS(min)
Preheat
25
Time to peak temperature
(t 25℃ to peak)
Time
Profile Feature
Pb-Free Assembly
Average Ramp-Up Rate (TS max to TP)
Preheat :
Temperature Min (TSmin)
Temperature Max (TSmax)
Time (TSmin to TSmax)
Time maintained above:
Temperature(TL)
Time (TL)
3°C/second max.
Peak/Classification Temperature(TP):
Time within 5°C of actual peak:
Temperature
260°C
Ramp-down Rate:
6°C/ second max.
Time 25°C to Peak Temperature
8 minutes max.
150°C
200°C
60-180 seconds
217°C
60-150 seconds
20-40 seconds
Note: All temperatures refer to of the package, measured on the package body surface.
Solder reflow
Caution:
Due to “Lead Free” nature, Temperature and Dwelling time for the
soldering zone is higher than those for Regular. This may cause
damage to other components.
1. Recommended max past thickness > 0.25mm.
2. Devices can be cleaned using standard methods and aqueous
solvent.
3. Rework use standard industry practices.
4. Storage Environment : < 30℃/ 60%RH
1. If reflow temperatures exceed the recommended profile, devices
may not meet the performance requirements.
2. Devices are not designed to be wave soldered to the bottom side
of the board.
www.socay.com
2/4
SCF2920 Series
Part Numbering
Part Marking
SCF XXX – XX – 2920 R
F XXXL
F200L
Hold Current
Logo
Device Size Code
F XXX
XX
Rated Voltage
F
Hold Current
075
60
Hold Current
/Rated Voltage
Logo
Socay Product Code
Example
Pad Layouts
Unit: mm
The dimension in the table below provide the recommended
pad layout for each SCF2920 device
Device
2920 Series
Dimensions
Part Number
A
B
C
Nominal
Nominal
Nominal
5.10
2.30
5.60
Unit: mm
A
B
C
D
E
Min.
Max.
Min.
Max.
Min.
Max.
Min.
Max.
Min.
Max.
SCF030-2920R
6.73
7.98
4.80
5.44
0.60
1.15
0.50
1.20
0.50
0.90
SCF050-2920R
6.73
7.98
4.80
5.44
0.60
1.15
0.50
1.20
0.50
0.90
SCF075-2920R
6.73
7.98
4.80
5.44
0.40
1.15
0.50
1.20
0.50
0.90
SCF075-60-2920R
6.73
7.98
4.80
5.44
0.60
1.15
0.50
1.20
0.50
0.90
SCF100-2920R
6.73
7.98
4.80
5.44
0.40
1.00
0.50
1.20
0.50
0.90
SCF100-60-2920R
6.73
7.98
4.80
5.44
0.40
1.70
0.50
1.20
0.50
0.90
SCF125-2920R
6.73
7.98
4.80
5.44
0.40
0.90
0.50
1.20
0.50
0.90
SCF150-2920R
6.73
7.98
4.80
5.44
0.40
0.90
0.50
1.20
0.50
0.90
SCF185-2920R
6.73
7.98
4.80
5.44
0.30
0.90
0.50
1.20
0.50
0.90
SCF200-2920R
6.73
7.98
4.80
5.44
0.30
0.90
0.50
1.20
0.50
0.90
SCF200-24-2920R
6.73
7.98
4.80
5.44
0.20
0.80
0.50
1.20
0.50
0.90
SCF250-2920R
6.73
7.98
4.80
5.44
0.30
0.90
0.50
1.20
0.50
0.90
SCF260-2920R
6.73
7.98
4.80
5.44
0.30
0.90
0.50
1.20
0.50
0.90
SCF260-24-2920R
6.73
7.98
4.80
5.44
0.65
1.15
0.50
1.20
0.50
0.90
SCF300-2920R
6.73
7.98
4.80
5.44
0.40
0.90
0.50
1.20
0.50
0.90
SCF300-15-2920R
6.73
7.98
4.80
5.44
0.40
1.15
0.50
1.20
0.50
0.90
SCF300-24-2920R
6.73
7.98
4.80
5.44
0.65
1.15
0.50
1.20
0.50
0.90
SCF500-16-2920R
6.73
7.98
4.80
5.44
0.40
1.50
0.50
1.20
0.50
0.90
www.socay.com
3/4
SCF2920 Series
Packaging
Part Number
Packaging Option
Quantity
SCF030-2920R
Tape & Reel -16mm/7″tape
2000
SCF050-2920R
2000
SCF075-2920R
2000
SCF075-60-2920R
2000
SCF100-2920R
2000
SCF100-60-2920R
1000
SCF125-2920R
2000
SCF150-2920R
2000
SCF185-2920R
2000
SCF200-2920R
2000
SCF200-24-2920R
2000
SCF250-2920R
2000
SCF260-2920R
2000
SCF260-24-2920R
2000
SCF300-2920R
2000
SCF300-15-2920R
2000
SCF300-24-2920R
2000
SCF500-16-2920R
2000
Tape and Reel Specifications
7.0
(177.8)
0.157
(4.0)
Packag
ing
0.059 Diameter
(1.5)
0.630
(16.0)
0.524
(13.3)
0.512(13.0)
Arbor Hole Diameter
0.315
(8.0)
Cover tape
0.646
(16.4)
Direction of Feed
Dimensions are in inches
(and millimeters)
Warning
Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or
flame.
PPTC device are intended for occasional over-current protection. Application for repeated over-current condition and/or
prolonged trip are not anticipated.
Avoid contact of PPTC device with chemical solvent. Prolonged contact will damage the device performance.
www.socay.com
4/4
很抱歉,暂时无法提供与“SCF075-2920R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.57154
- 50+0.56009
- 150+0.55242
- 500+0.54476
