SCF075-60-2920R
SCF075-60-2920R
    SOCAY(硕凯)
    PTC自恢复保险丝 FUSE2920 Vmax=60V Ih=750mA
SCF075-60-2920R 数据手册
Surface Mount Resettable PTCs SCF2920 Series Description The SCF2920 Series PTC provides surface mount over-current protection for applications where space is at a premium and resettable protection is desired. Features      RoHS compliant, Lead-Free and Halogen-Free Fast time-to-trip Compact design saves board space Low resistance Low-profile Applications     PC motherboard - plug and play protection Mobile phones - battery and port protection Game console port protection USB peripherals     Disk drive PDAS / digital cameras Power ports General electronics Electrical Parameters Part Number SCF030-2920R SCF050-2920R SCF075-2920R SCF075-60-2920R SCF100-2920R SCF100-60-2920R SCF125-2920R SCF150-2920R SCF185-2920R SCF200-2920R SCF200-24-2920R SCF250-2920R SCF260-2920R SCF260-24-2920R SCF300-2920R SCF300-15-2920R SCF300-24-2920R SCF500-16-2920R Hold Current Trip Current Rated Voltage Max Current Typical Power Maximum Time To Trip I hold (A) I trip (A) V max (Vdc) I max (A) P dtyp. (W) Current (A) Time (Sec.) R min (Ω) R 1max (Ω) 0.30 0.50 0.75 0.75 1.10 1.10 1.25 1.50 1.85 2.00 2.00 2.50 2.60 2.60 3.00 3.00 3.00 5.00 0.60 1.00 1.50 1.50 2.20 2.20 2.50 3.00 3.70 4.00 4.00 5.00 5.20 5.20 5.20 5.20 5.20 10.0 60 60 33 60 33 60 33 33 33 16 24 16 6 24 6 15 24 16 100 100 100 100 100 100 100 100 100 100 100 100 100 100 100 100 100 100 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 2.5 8.0 8.0 8.0 8.0 8.0 8.0 8.0 8.0 8.0 8.0 8.0 8.0 8.0 8.0 8.0 20.0 3.0 4.0 0.3 0.3 0.5 0.5 2.0 2.0 2.5 4.5 5.0 16.0 20.0 20.0 25.0 25.0 25.0 5.0 1.000 0.300 0.180 0.180 0.090 0.090 0.050 0.050 0.040 0.035 0.035 0.025 0.020 0.020 0.010 0.010 0.010 0.005 4.800 1.400 1.000 1.000 0.410 0.410 0.250 0.230 0.150 0.120 0.120 0.085 0.075 0.075 0.048 0.048 0.048 0.025 Resistance I hold= Hold current: maximum current device will pass without tripping in 23°C still air. I trip= Trip current: minimum current at which the device will trip in 23°C still air. V max= Maximum voltage device can withstand without damage at rated current (Imax) I max= Maximum fault current device can withstand without damage at rated voltage (Vmax) Pdtyp.= Power dissipated from device when in the tripped state at 23°C still air. R min= Minimum resistance of device in initial (un-soldered) state. R 1max= Maximum resistance of device at 23°C measured one hour after tripping. Caution: Operation beyond the specified rating may result in damage and possible arcing and flame. SOCAY Electronics Corp., Ltd. Revision March 16, 2017 www.socay.com 1/4 @ SOCAY Electronics Corp., Ltd. 2017 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Surface Mount Resettable PTCs SCF2920 Series Temperature Rerating Chart – I hold (A) 5Average Time Current Curves Temperature Derating Curve A B Ambient Temperature (°C) Fault Current (A) A= SCF030-2920R B= SCF050-2920R C= SCF075-2920R /SCF075-60-2920R D= SCF100-2920R /SCF100-60-2920R E= SCF125-2920R F= SCF150-2920R G= SCF185-2920R H= SCF200-2920R /SCF200-24-2920R I= SCF250-2920R J= SCF260-2920R /SCF260-24-2920R K= SCF300-2920R/ /SCF300-15-2920R /SCF300-24-2920R A=SCF125-2920R ~ SCF300-2920R B=SCF030-2920R ~ SCF100-2920R Material Specifications Terminal pad material Pure Tin Soldering Characteristics Meets EIA specification RS 186-9E, ANSI/J-std-002 Category 3 Soldering Parameters TP Ramp-up TL Critical Zone TL to TP Temperature TS(max) Ramp-down TS(min) Preheat 25 Time to peak temperature (t 25℃ to peak) Time Profile Feature Pb-Free Assembly Average Ramp-Up Rate (TS max to TP) Preheat : Temperature Min (TSmin) Temperature Max (TSmax) Time (TSmin to TSmax) Time maintained above: Temperature(TL) Time (TL) 3°C/second max. Peak/Classification Temperature(TP): Time within 5°C of actual peak: Temperature 260°C Ramp-down Rate: 6°C/ second max. Time 25°C to Peak Temperature 8 minutes max. 150°C 200°C 60-180 seconds 217°C 60-150 seconds 20-40 seconds Note: All temperatures refer to of the package, measured on the package body surface. Solder reflow Caution: Due to “Lead Free” nature, Temperature and Dwelling time for the soldering zone is higher than those for Regular. This may cause damage to other components. 1. Recommended max past thickness > 0.25mm. 2. Devices can be cleaned using standard methods and aqueous solvent. 3. Rework use standard industry practices. 4. Storage Environment : < 30℃/ 60%RH 1. If reflow temperatures exceed the recommended profile, devices may not meet the performance requirements. 2. Devices are not designed to be wave soldered to the bottom side of the board. SOCAY Electronics Corp., Ltd. Revision March 16, 2017 www.socay.com 2/4 @ SOCAY Electronics Corp., Ltd. 2017 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Surface Mount Resettable PTCs SCF2920 Series Part Numbering Part Marking SCF XXX – XX – 2920 R F XXXL F200L Hold Current Logo Device Size Code F XXX XX Rated Voltage F Hold Current 075 60 Hold Current /Rated Voltage Logo Socay Product Code Example Pad Layouts Unit: mm The dimension in the table below provide the recommended pad layout for each SCF2920 device Device 2920 Series Dimensions Part Number A B C Nominal Nominal Nominal 5.10 2.30 5.60 Unit: mm A B C D E Min. Max. Min. Max. Min. Max. Min. Max. Min. Max. SCF030-2920R 6.73 7.98 4.80 5.44 0.60 1.15 0.50 1.20 0.50 0.90 SCF050-2920R 6.73 7.98 4.80 5.44 0.60 1.15 0.50 1.20 0.50 0.90 SCF075-2920R 6.73 7.98 4.80 5.44 0.40 1.15 0.50 1.20 0.50 0.90 SCF075-60-2920R 6.73 7.98 4.80 5.44 0.60 1.15 0.50 1.20 0.50 0.90 SCF100-2920R 6.73 7.98 4.80 5.44 0.40 1.00 0.50 1.20 0.50 0.90 SCF100-60-2920R 6.73 7.98 4.80 5.44 0.40 1.70 0.50 1.20 0.50 0.90 SCF125-2920R 6.73 7.98 4.80 5.44 0.40 0.90 0.50 1.20 0.50 0.90 SCF150-2920R 6.73 7.98 4.80 5.44 0.40 0.90 0.50 1.20 0.50 0.90 SCF185-2920R 6.73 7.98 4.80 5.44 0.30 0.90 0.50 1.20 0.50 0.90 SCF200-2920R 6.73 7.98 4.80 5.44 0.30 0.90 0.50 1.20 0.50 0.90 SCF200-24-2920R 6.73 7.98 4.80 5.44 0.20 0.80 0.50 1.20 0.50 0.90 SCF250-2920R 6.73 7.98 4.80 5.44 0.30 0.90 0.50 1.20 0.50 0.90 SCF260-2920R 6.73 7.98 4.80 5.44 0.30 0.90 0.50 1.20 0.50 0.90 SCF260-24-2920R 6.73 7.98 4.80 5.44 0.65 1.15 0.50 1.20 0.50 0.90 SCF300-2920R 6.73 7.98 4.80 5.44 0.40 0.90 0.50 1.20 0.50 0.90 SCF300-15-2920R 6.73 7.98 4.80 5.44 0.40 1.15 0.50 1.20 0.50 0.90 SCF300-24-2920R 6.73 7.98 4.80 5.44 0.65 1.15 0.50 1.20 0.50 0.90 SCF500-16-2920R 6.73 7.98 4.80 5.44 0.40 1.50 0.50 1.20 0.50 0.90 SOCAY Electronics Corp., Ltd. Revision March 16, 2017 www.socay.com 3/4 @ SOCAY Electronics Corp., Ltd. 2017 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Surface Mount Resettable PTCs SCF2920 Series Packaging Part Number Packaging Option Quantity SCF030-2920R Tape & Reel -16mm/7″tape 2000 SCF050-2920R Tape & Reel -16mm/7″tape 2000 SCF075-2920R Tape & Reel -16mm/7″tape 2000 SCF075-60-2920R Tape & Reel -16mm/7″tape 2000 SCF100-2920R Tape & Reel -16mm/7″tape 2000 SCF100-60-2920R Tape & Reel -16mm/7″tape 1000 SCF125-2920R Tape & Reel -16mm/7″tape 2000 SCF150-2920R Tape & Reel -16mm/7″tape 2000 SCF185-2920R Tape & Reel -16mm/7″tape 2000 SCF200-2920R Tape & Reel -16mm/7″tape 2000 SCF200-24-2920R Tape & Reel -16mm/7″tape 2000 SCF250-2920R Tape & Reel -16mm/7″tape 2000 SCF260-2920R Tape & Reel -16mm/7″tape 2000 SCF260-24-2920R Tape & Reel -16mm/7″tape 2000 SCF300-2920R Tape & Reel -16mm/7″tape 2000 SCF300-15-2920R Tape & Reel -16mm/7″tape 2000 SCF300-24-2920R Tape & Reel -16mm/7″tape 2000 SCF500-16-2920R Tape & Reel -16mm/7″tape 2000 Tape and Reel Specifications 7.0 (177.8) 0.157 (4.0) Packag ing 0.059 Diameter (1.5) 0.630 (16.0) 0.524 (13.3) 0.512(13.0) Arbor Hole Diameter 0.315 (8.0) Cover tape 0.646 (16.4) Direction of Feed Dimensions are in inches (and millimeters) Warning  Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame.  PPTC device are intended for occasional over-current protection. Application for repeated over-current condition and/or prolonged trip are not anticipated.  Avoid contact of PPTC device with chemical solvent. Prolonged contact will damage the device performance. SOCAY Electronics Corp., Ltd. Revision March 16, 2017 www.socay.com 4/4 @ SOCAY Electronics Corp., Ltd. 2017 Specifications are subject to change without notice. Please refer to www.socay.com for current information.
SCF075-60-2920R 价格&库存
很抱歉,暂时无法提供与“SCF075-60-2920R”相匹配的价格&库存,您可以联系我们找货
