SMCJ6.5CA
SMCJ6.5CA
    SOCAY(硕凯)
    SMC(DO-214AB)
    ESD抑制器/TVS二极管 VRWM=6.5V VBR(min)=7.22V VC=11.2V@IPP=133.93A SMC
SMCJ6.5CA 数据手册
Surface Mount Transient Voltage Suppressors (TVS) SMCJ Series 5.0 To 440 V 1500W Description Uni-directional Bi-directional The SMCJ series is designed specifically to protect sensitive electronic equipment from voltage transients induced by lightning and other transient voltage events. Features                    For surface mounted applications in order to optimize board space Low leakage Uni and Bidirectional unit Glass passivated junction Low inductance Excellent clamping capability 1500W Peak power capability at 10 × 1000µs waveform Repetition rate (duty cycle):0.01% Fast response time: typically less than 1.0ps from 0 Volts to VBR min Typical IR less than 5μA above 12V. High Temperature soldering: 260°C/40 seconds at terminals Typical maximum temperature coefficient ΔVBR = 0.1% × VBR@25°C× ΔT Plastic package has Underwriters Laboratory Flammability 94V-0 Matte tin lead–free Plated Halogen free and RoHS compliant Typical failure mode is short from over-specified voltage or current Whisker test is conducted based on JEDEC JESD201A per its table 4a and 4c IEC-61000-4-2 ESD 15kV(Air), 8kV (Contact) ESD protection of data lines in accordance with IEC 61000-4-2 (IEC801-2) EFT protection of data lines in accordance with IEC 61000-4-4 (IEC801-4) Functional Diagram Bi-directional Cathode Anode Uni-direction Agency Approvals AGENCY AGENCY FILE NUMBER E341027 Applications TVS devices are ideal for the protection of I/O interfaces, VCC bus and other vulnerable circuits used in Telecom, Computer, Industrial and Consumer electronic applications . Maximum Ratings (TA=25℃ unless otherwise noted) Parameter Symbol Value Unit Peak Pulse Power Dissipation with a 10/1000µs waveform (Fig.1)(Note 1), (Note 2) PPPM 1500 Watts Amps Peak Pulse Current with a 10/1000µs waveform.(Note1,Fig.3) IPP See Next Table PM(AV) 6.5 Watt Peak Forward Surge Current, 8.3ms Single Half Sine Wave (Note 3) IFSM 200 Amps Maximum Instantaneous Forward Voltage at 25A for Unidirectional Only (Note 4) VF 3.5/5.0 Voltage TJ , TSTG -55 to +150 ℃ Power Dissipation on Infinite Heat Sink at TL=75°C Operating junction and Storage Temperature Range. Notes: 1. Non-repetitive current pulse, per Fig. 3 and derated above TA = 25℃ per Fig. 2. 2. Mounted on 5.0mm x 5.0mm (0.03mm thick) Copper Pads to each terminal. 3. 8.3ms single half sine-wave, or equivalent square wave, Duty cycle = 4 pulses per minutes maximum. 4. VF < 3.5V for VBR < 200V and VF< 6.5V for VBR > 201V. SOCAY Electronics Corp., Ltd. Revision March 28, 2017 www.socay.com 1/7 @ SOCAY Electronics Corp., Ltd. 2017 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Surface Mount Transient Voltage Suppressors (TVS) SMCJ Series 5.0 To 440 V 1500W Electrical Characteristics (TA=25℃ unless otherwise noted) Part Number Marking Uni Bi Uni Bi SMCJ5.0A SMCJ5.0CA GDE BDE SMCJ6.0A SMCJ6.0CA GDG SMCJ6.5A SMCJ6.5CA SMCJ7.0A Reverse Stand-Off Voltage VRWM (V) Breakdown Voltage VBR (V) @IT Test Current IT (mA) Maximum Clamping Voltage VC @IPP (V) Maximum Peak Pulse Current IPP (A) Maximum Reverse Leakage IR @VRWM (μA) MIN MAX 5.0 6.40 7.00 10 9.2 163.04 1000 BDG 6.0 6.67 7.37 10 10.3 145.63 1000 GDK BDK 6.5 7.22 7.98 10 11.2 133.93 500 SMCJ7.0CA GDM BDM 7.0 7.78 8.60 10 12.0 125.00 200 SMCJ7.5A SMCJ7.5CA GDP BDP 7.5 8.33 9.21 1 12.9 116.28 100 SMCJ8.0A SMCJ8.0CA GDR BDR 8.0 8.89 9.83 1 13.6 110.29 50 SMCJ8.5A SMCJ8.5CA GDT BDT 8.5 9.44 10.40 1 14.4 104.17 20 SMCJ9.0A SMCJ9.0CA GDV BDV 9.0 10.00 11.10 1 15.4 97.40 10 SMCJ10A SMCJ10CA GDX BDX 10.0 11.10 12.30 1 17.0 88.24 5 SMCJ11A SMCJ11CA GDZ BDZ 11.0 12.20 13.50 1 18.2 82.42 5 SMCJ12A SMCJ12CA GEE BEE 12.0 13.30 14.70 1 19.9 75.38 5 SMCJ13A SMCJ13CA GEG BEG 13.0 14.40 15.90 1 21.5 69.77 5 SMCJ14A SMCJ14CA GEK BEK 14.0 15.60 17.20 1 23.2 64.66 5 SMCJ15A SMCJ15CA GEM BEM 15.0 16.70 18.50 1 24.4 61.48 5 SMCJ16A SMCJ16CA GEP BEP 16.0 17.80 19.70 1 26.0 57.69 5 SMCJ17A SMCJ17CA GER BER 17.0 18.90 20.90 1 27.6 54.35 5 SMCJ18A SMCJ18CA GET BET 18.0 20.00 22.10 1 29.2 51.37 5 SMCJ19A SMCJ19CA GEB BEB 19.0 21.10 23.30 1 30.8 48.73 5 SMCJ20A SMCJ20CA GEV BEV 20.0 22.20 24.50 1 32.4 46.30 5 SMCJ22A SMCJ22CA GEX BEX 22.0 24.40 26.90 1 35.5 42.25 5 SMCJ24A SMCJ24CA GEZ BEZ 24.0 26.70 29.50 1 38.9 38.56 5 SMCJ26A SMCJ26CA GFE BFE 26.0 28.90 31.90 1 42.1 35.63 5 SMCJ28A SMCJ28CA GFG BFG 28.0 31.10 34.40 1 45.4 33.04 5 SMCJ30A SMCJ30CA GFK BFK 30.0 33.30 36.80 1 48.4 30.99 5 SMCJ33A SMCJ33CA GFM BFM 33.0 36.70 40.60 1 53.3 28.14 5 SMCJ36A SMCJ36CA GFP BFP 36.0 40.00 44.20 1 58.1 25.82 5 SMCJ40A SMCJ40CA GFR BFR 40.0 44.40 49.10 1 64.5 23.26 5 SMCJ43A SMCJ43CA GFT BFT 43.0 47.80 52.80 1 69.4 21.61 5 SOCAY Electronics Corp., Ltd. Revision March 28, 2017 www.socay.com 2/7 @ SOCAY Electronics Corp., Ltd. 2017 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Surface Mount Transient Voltage Suppressors (TVS) SMCJ Series 5.0 To 440 V Electrical Characteristics 1500W (TA=25℃ unless otherwise noted) (Continue) Uni Bi Uni Bi Reverse Stand-Off Voltage VRWM (V) SMCJ45A SMCJ45CA GFV BFV SMCJ48A SMCJ48CA GFX SMCJ51A SMCJ51CA SMCJ54A Breakdown Voltage VBR (V) @IT Maximum Clamping Voltage VC @IPP (V) Maximum Peak Pulse Current IPP (A) Maximum Reverse Leakage IR @VRWM (μA) MIN MAX Test Current IT (mA) 45.0 50.00 55.30 1 72.7 20.63 5 BFX 48.0 53.30 58.90 1 77.4 19.38 5 GFZ BFZ 51.0 56.70 62.70 1 82.4 18.20 5 SMCJ54CA GGE BGE 54.0 60.00 66.30 1 87.1 17.22 5 SMCJ58A SMCJ58CA GGG BGG 58.0 64.40 71.20 1 93.6 16.03 5 SMCJ60A SMCJ60CA GGK BGK 60.0 66.70 73.70 1 96.8 15.50 5 SMCJ64A SMCJ64CA GGM BGM 64.0 71.10 78.60 1 103.0 14.56 5 SMCJ70A SMCJ70CA GGP BGP 70.0 77.80 86.00 1 113.0 13.27 5 SMCJ75A SMCJ75CA GGR BGR 75.0 83.30 92.10 1 121.0 12.40 5 SMCJ78A SMCJ78CA GGT BGT 78.0 86.70 95.80 1 126.0 11.90 5 SMCJ80A SMCJ80CA GGB BGB 80.0 88.80 97.60 1 129.6 11.57 5 SMCJ85A SMCJ85CA GGV BGV 85.0 94.40 104.00 1 137.0 10.95 5 SMCJ90A SMCJ90CA GGX BGX 90.0 100.00 111.00 1 146.0 10.27 5 SMCJ100A SMCJ100CA GGZ BGZ 100.0 111.00 123.00 1 162.0 9.26 5 SMCJ110A SMCJ110CA GHE BHE 110.0 122.00 135.00 1 177.0 8.47 5 SMCJ120A SMCJ120CA GHG BHG 120.0 133.00 147.00 1 193.0 7.77 5 SMCJ130A SMCJ130CA GHK BHK 130.0 144.00 159.00 1 209.0 7.18 5 SMCJ140A SMCJ140CA GHB BHB 140.0 155.00 171.00 1 226.8 6.61 5 SMCJ150A SMCJ150CA GHM BHM 150.0 167.00 185.00 1 243.0 6.17 5 SMCJ160A SMCJ160CA GHP BHP 160.0 178.00 197.00 1 259.0 5.79 5 SMCJ170A SMCJ170CA GHR BHR 170.0 189.00 209.00 1 275.0 5.45 5 SMCJ180A SMCJ180CA GHT BHT 180.0 201.00 220.00 1 291.6 5.14 5 SMCJ190A SMCJ190CA GHV BHV 190.0 211.00 232.00 1 307.8 4.87 5 SMCJ200A SMCJ200CA GHW BHW 200.0 224.00 247.00 1 324.0 4.60 5 SMCJ220A SMCJ220CA GHX BHX 220.0 246.00 272.00 1 356.0 4.20 5 SMCJ250A SMCJ250CA GHZ BHZ 250.0 279.00 309.00 1 405.0 3.70 5 SMCJ300A SMCJ300CA GJE BJE 300.0 335.00 371.00 1 486.0 3.10 5 SMCJ350A SMCJ350CA GJG BJG 350.0 391.00 432.00 1 567.0 2.60 5 SMCJ400A SMCJ400CA GJK BJK 400.0 447.00 494.00 1 648.0 2.30 5 SMCJ440A SMCJ440CA GJM BJM 440.0 492.00 543.00 1 713.0 2.10 5 Part Number Marking Note: 1. Suffix 'A ' denotes 5% tolerance device. 2. Add suffix ' CA ' after part number to specify Bi-directional devices. 3. For Bi-Directional devices having VR of 10 volts and under, the IR limit is doubl. SOCAY Electronics Corp., Ltd. Revision March 28, 2017 www.socay.com 3/7 @ SOCAY Electronics Corp., Ltd. 2017 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Surface Mount Transient Voltage Suppressors (TVS) SMCJ Series 5.0 To 440 V 1500W Ratings and Characteristic Curves (TA=25°C unless otherwise noted) Figure 1 - Peak Pulse Power Rating Curve Figure 2 - Pulse Derating Curve Peak Pulse Power (PPP) or Current (IPP) Derating in Percentage % PPPM - Peak Pulse Power (kW) 100 0 10 1 0.1 0.1 1 10 100 td - Pulse Width (μs) 1000 10000 Figure 3 - Pulse Waveform Peak Value IPPM CJ – Junction Capacitance (pF) IPPM - Peak Pulse Current, % IRSM TJ=25°C Pulse Width(td) is defined as the point where the peak current decays to 50% of IPPM 100 Half Value IPPM (IPPM/2) 50 10/1000µsec. Waveform as defined by R.E.A 40 20 0 0 25 50 75 100 125 TA-Ambient temperature(°C) 150 175 0 2.0 t - Time (ms) 3.0 Uni-directional @zero bins 1000 Uni-directional @VRWM 100 10 1 1.0 Bi-directional @zero bins 10000 tc 4.0 Figure 5 - Steady State Power Derating Curve Tj=25°C f=1.0MHz Vsig=50mVp-p 1.0 Bi-directional @VRWM 10.0 100.0 VBR-Reverse Breakdown Voltage (V) 1000.0 Figure 6 - Maximum Non-Repetitive Surge Current 8.0 200 IFSM-Peak Forward Surge Current (A) PM(AV), Steady State Power Dissipation (W) 60 100000 tr=10µsec 7.0 6.0 5.0 4.0 3.0 2.0 1.0 0.0 80 Figure 4 - Typical Junction Capacitance 150 0 100 0 25 50 75 100 125 150 TL - Lead Temperature(°C) 175 SOCAY Electronics Corp., Ltd. Revision March 28, 2017 120 80 40 0 200 TJ=TJ max. 8.3 ms Single Half Sine-Wave 160 1 10 Number of Cycles at 60Hz 100 www.socay.com 4/7 @ SOCAY Electronics Corp., Ltd. 2017 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Surface Mount Transient Voltage Suppressors (TVS) SMCJ Series 5.0 To 440 V 1500W I-V Curve Characteristics Uni-directional Bi-directional I I IPP IF VC V VBR VRW R M VF IT IPP VC C r i t i c a l IR IT IT V IR VRW VBR VC R M IPP Z o n e T Physical Specifications VBR VRW R M Environmental Specifications L Weight 0.007 ounce, 0.21 gram Case JEDEC DO-214AB Molded Plastic over T glass passivated junction Polarity Color band denotes cathode except Bipolar Terminal Matte Tin-plated leads, Solderable per JESD22-B102D t o P Temperature Cycle JESD22-A104 Pressure Cooker JESD22-A102 High Temp. Storage JESD22-A103 HTRB JESD22-A108 Thermal Shock JESD22-A106 Soldering Parameters Reflow Condition TP Ramp-up TL Pre Heat Critical Zone TL to TP Temperature TS(max) Ramp-down TS(min) 25 Time to peak temperature (t 25℃ to peak) -Temperature Min (Ts(min)) 150°C -Temperature Max (Ts(max)) 200°C - Time (min to max) (Ts) 60 -180 Seconds Average ramp up rate ( Liquidus Temp TL) to peak 3°C/second max TS(max) to TL - Ramp-up Rate 3°C/second max Reflow Preheat - Temperature (TL) (Liquidus) 217°C - Time (min to max) (TL) 60 -150 Seconds Peak Temperature (TP) Time Time within 5°C Temperature (tp) SOCAY Electronics Corp., Ltd. Revision March 28, 2017 Lead–free assembly 260 +0/-5°C of actual peak 20 -40 Seconds Ramp-down Rate 6°C/second max Time 25°C to peak Temperature (TP) 8 minutes Max Do not exceed 280°C www.socay.com 5/7 @ SOCAY Electronics Corp., Ltd. 2017 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Surface Mount Transient Voltage Suppressors (TVS) SMCJ Series 5.0 To 440 V 1500W Dimensions Inches Dimensions DO-214AB (SMC) Cathode Band Part Numbering Millimeters Min Max Min Max A 0.108 0.126 2.75 3.20 B 0.260 0.280 6.60 7.11 C 0.220 0.244 5.59 6.20 D 0.085 0.103 2.15 2.62 E 0.030 0.060 0.76 1.52 F 0.002 0.008 0.051 0.203 G 0.305 0.320 7.74 8.13 H 0.006 0.012 0.15 0.31 I 0.121 - 3.07 - J 0.068 - 1.715 - K - 0.185 - 4.69 L 0.068 - 1.715 - Part Marking SMCJ×××CA Socay Logo 5% VBR VOLTAGE TOLERANCE BI-DIRECTIONAL VR VOLTAGE Cathode Band Marking Code SERIES SOCAY Electronics Corp., Ltd. Revision March 28, 2017 www.socay.com 6/7 @ SOCAY Electronics Corp., Ltd. 2017 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Surface Mount Transient Voltage Suppressors (TVS) SMCJ Series 5.0 To 440 V 1500W Packaging Part Number Component Package Quantity Packaging Option Reel Diameters (mm) SMCJXXXXX DO-214AB (SMC) 500 pcs Tape & Reel -16mm/7″tape 177.8 SMCJXXXXX DO-214AB (SMC) 3000 pcs Tape & Reel -16mm/13″tape 330.0 Tape and Reel Specifications 7.0/13.0 (177.8/330.0) 0.157 (4.0) 0.059 Diameter (1.5) 0.630 (16.0) 0.36 (9.2) 0.512(13.0) Arbor Hole Diameter 0.315 (8.0) 0.646 (16.4) Cover tape Direction of Feed Dimensions are in inches (and millimeters) SOCAY Electronics Corp., Ltd. Revision March 28, 2017 www.socay.com 7/7 @ SOCAY Electronics Corp., Ltd. 2017 Specifications are subject to change without notice. Please refer to www.socay.com for current information.
SMCJ6.5CA 价格&库存
很抱歉,暂时无法提供与“SMCJ6.5CA”相匹配的价格&库存,您可以联系我们找货
