SMDJ24CA
SMDJ24CA
    SOCAY(硕凯)
    SMC(DO-214AB)
    SMC SMT 24V 38.9V
SMDJ24CA 数据手册
Surface Mount Transient Voltage Suppressors (TVS) SMDJ Series 5.0 To 440 V 3000W Description Uni-directional Bi-directional The SMDJ series is designed specifically to protect sensitive electronic equipment from voltage transients induced by lightning and other transient voltage events. Features                    For surface mounted applications in order to optimize board space Low leakage Uni and Bidirectional unit Glass passivated junction Low inductance Excellent clamping capability 3000W Peak power capability at 10 × 1000µs waveform Repetition rate (duty cycle):0.01% Fast response time: typically less than 1.0ps from 0 Volts to VBR min Typical IR less than 5μA above 12V. High Temperature soldering: 260°C/40 seconds at terminals Typical maximum temperature coefficient ΔVBR = 0.1% × VBR@25°C× ΔT Plastic package has Underwriters Laboratory Flammability 94V-0 Matte tin lead–free Plated Halogen free and RoHS compliant Typical failure mode is short from over-specified voltage or current Whisker test is conducted based on JEDEC JESD201A per its table 4a and 4c IEC-61000-4-2 ESD 15kV(Air), 8kV (Contact) ESD protection of data lines in accordance with IEC 61000-4-2 (IEC801-2) EFT protection of data lines in accordance with IEC 61000-4-4 (IEC801-4) Functional Diagram Bi-directional Cathode Anode Uni-direction Agency Approvals AGENCY AGENCY FILE NUMBER E341027 Applications TVS devices are ideal for the protection of I/O interfaces, VCC bus and other vulnerable circuits used in Telecom, Computer, Industrial and Consumer electronic applications. Maximum Ratings (TA=25℃ unless otherwise noted) Parameter Symbol Value Unit Peak Pulse Power Dissipation with a 10/1000µs waveform (Fig.1)(Note 1), (Note 2) PPPM 3000 Watts Amps Peak Pulse Current with a 10/1000µs waveform.(Note1,Fig.3) IPP See Next Table PM(AV) 6.0 Watt Peak Forward Surge Current, 8.3ms Single Half Sine Wave (Note 3) IFSM 300 Amps Maximum Instantaneous Forward Voltage at 25A for Unidirectional Only (Note 4) VF 3.5/5.0 Voltage TJ , TSTG -55 to +150 ℃ Power Dissipation on Infinite Heat Sink at TL=75°C Operating junction and Storage Temperature Range. Notes: 1. Non-repetitive current pulse, per Fig. 3 and derated above TA = 25℃ per Fig. 2. 2. Mounted on 5.0mm x 5.0mm (0.03mm thick) Copper Pads to each terminal. 3. 8.3ms single half sine-wave, or equivalent square wave, Duty cycle = 4 pulses per minutes maximum. 4. VF < 3.5V for VBR < 200V and VF< 6.5V for VBR > 201V. SOCAY Electronics Corp., Ltd. Revision March 28, 2017 www.socay.com 1/7 @ SOCAY Electronics Corp., Ltd 2017 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Surface Mount Transient Voltage Suppressors (TVS) SMDJ Series 5.0 To 440 V 3000W Electrical Characteristics (TA=25℃ unless otherwise noted) Part Number Marking Uni Bi Uni Bi SMDJ5.0A SMDJ5.0CA RDE DDE SMDJ6.0A SMDJ6.0CA RDG SMDJ6.5A SMDJ6.5CA SMDJ7.0A Reverse Stand-Off Voltage VRWM (V) Breakdown Voltage VBR (V) @IT Test Current IT (mA) Maximum Clamping Voltage VC @IPP (V) Maximum Peak Pulse Current IPP (A) Maximum Reverse Leakage IR @VRWM (μA) MIN MAX 5.0 6.40 10 9.2 326.09 1000 DDG 6.0 6.67 7.00 7.37 7.37 10 10.3 291.26 1000 RDK DDK 6.5 7.22 7.98 10 11.2 267.86 500 SMDJ7.0CA PDM DDM 7.0 7.78 8.60 10 12.0 250.00 200 SMDJ7.5A SMDJ7.5CA PDP DDP 7.5 8.33 9.21 1 12.9 232.56 100 SMDJ8.0A SMDJ8.0CA PDR DDR 8.0 8.89 9.83 1 13.6 220.59 50 SMDJ8.5A SMDJ8.5CA PDT DDT 8.5 9.44 10.40 1 14.4 208.33 25 SMDJ9.0A SMDJ9.0CA PDV DDV 9.0 10.00 11.10 1 15.4 194.81 10 SMDJ10A SMDJ10CA PDX DDX 10.0 11.10 12.30 1 17.0 176.47 5 SMDJ11A SMDJ11CA PDZ DDZ 11.0 12.20 13.50 1 18.2 164.84 5 SMDJ12A SMDJ12CA PEE DEE 12.0 13.30 14.70 1 19.9 150.75 5 SMDJ13A SMDJ13CA PEG DEG 13.0 14.40 15.90 1 21.5 139.53 5 SMDJ14A SMDJ14CA PEK DEK 14.0 15.60 17.20 1 23.2 129.31 5 SMDJ15A SMDJ15CA PEM DEM 15.0 16.70 18.50 1 24.4 122.95 5 SMDJ16A SMDJ16CA PEP DEP 16.0 17.80 19.70 1 26.0 115.38 5 SMDJ17A SMDJ17CA PER DER 17.0 18.90 20.90 1 27.6 108.70 5 SMDJ18A SMDJ18CA PET DET 18.0 20.00 22.10 1 29.2 102.74 5 SMDJ19A SMDJ19CA PEB DEB 19.0 21.10 23.30 1 30.8 97.47 5 SMDJ20A SMDJ20CA PEV DEV 20.0 22.20 24.50 1 32.4 92.59 5 SMDJ22A SMDJ22CA PEX DEX 22.0 24.40 26.90 1 35.5 84.51 5 SMDJ24A SMDJ24CA PEZ DEZ 24.0 26.70 29.50 1 38.9 77.12 5 SMDJ26A SMDJ26CA PFE DFE 26.0 28.90 31.90 1 42.1 71.26 5 SMDJ28A SMDJ28CA PFG DFG 28.0 31.10 34.40 1 45.4 66.08 5 SMDJ30A SMDJ30CA PFK DFK 30.0 33.30 36.80 1 48.4 61.98 5 SMDJ33A SMDJ33CA PFM DFM 33.0 36.70 40.60 1 53.3 56.29 5 SMDJ36A SMDJ36CA PFP DFP 36.0 40.00 44.20 1 58.1 51.64 5 SMDJ40A SMDJ40CA PFR DFR 40.0 44.40 49.10 1 64.5 46.51 5 SMDJ43A SMDJ43CA PFT DFT 43.0 47.80 52.80 1 69.4 43.23 5 SOCAY Electronics Corp., Ltd. Revision March 28, 2017 www.socay.com 2/7 @ SOCAY Electronics Corp., Ltd 2017 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Surface Mount Transient Voltage Suppressors (TVS) SMDJ Series 5.0 To 440 V Electrical Characteristics 3000W (TA=25℃ unless otherwise noted) (Continue) Uni Bi Uni Bi Reverse Stand-Off Voltage VRWM (V) SMDJ45A SMDJ45CA PFV DFV SMDJ48A SMDJ48CA PFX SMDJ51A SMDJ51CA SMDJ54A Breakdown Voltage VBR (V) @IT Maximum Clamping Voltage VC @IPP (V) Maximum Peak Pulse Current IPP (A) Maximum Reverse Leakage IR @VRWM (μA) MIN MAX Test Current IT (mA) 45.0 50.00 55.30 1 72.7 41.27 5 DFX 48.0 53.30 58.90 1 77.4 38.76 5 PFZ DFZ 51.0 56.70 62.70 1 82.4 36.41 5 SMDJ54CA RGE DGE 54.0 60.00 66.30 1 87.1 34.44 5 SMDJ58A SMDJ58CA PGG DGG 58.0 64.40 71.20 1 93.6 32.05 5 SMDJ60A SMDJ60CA PGK DGK 60.0 66.70 73.70 1 96.8 30.99 5 SMDJ64A SMDJ64CA PGM DGM 64.0 71.10 78.60 1 103.0 29.13 5 SMDJ70A SMDJ70CA PGP DGP 70.0 77.80 86.00 1 113.0 26.55 5 SMDJ75A SMDJ75CA PGR DGR 75.0 83.30 92.10 1 121.0 24.79 5 SMDJ78A SMDJ78CA PGT DGT 78.0 86.70 95.80 1 126.0 23.81 5 SMDJ80A SMDJ80CA PGB DGB 80.0 88.80 97.60 1 129.6 23.15 5 SMDJ85A SMDJ85CA PGV DGV 85.0 94.40 104.00 1 137.0 21.90 5 SMDJ90A SMDJ90CA PGX DGX 90.0 100.00 111.00 1 146.0 20.55 5 SMDJ100A SMDJ100CA PGZ DGZ 100.0 111.00 123.00 1 162.0 18.52 5 SMDJ110A SMDJ110CA PHE DHE 110.0 122.00 135.00 1 177.0 16.95 5 SMDJ120A SMDJ120CA PHG DHG 120.0 133.00 147.00 1 193.0 15.54 5 SMDJ130A SMDJ130CA PHK DHK 130.0 144.00 159.00 1 209.0 14.35 5 SMDJ140A SMDJ140CA PHB DHB 140.0 155.00 171.00 1 226.8 13.23 5 SMDJ150A SMDJ150CA PHM DHM 150.0 167.00 185.00 1 243.0 12.35 5 SMDJ160A SMDJ160CA PHP DHP 160.0 178.00 197.00 1 259.0 11.58 5 SMDJ170A SMDJ170CA PHR DHR 170.0 189.00 209.00 1 275.0 10.91 5 SMDJ180A SMDJ180CA PHT DHT 180.0 201.00 220.00 1 291.6 10.29 5 SMDJ190A SMDJ190CA PHV DHV 190.0 211.00 232.00 1 307.8 9.75 5 SMDJ200A SMDJ200CA PHW DHW 200.0 224.00 247.00 1 324.0 9.26 5 SMDJ220A SMDJ220CA PHX DHX 220.0 246.00 272.00 1 356.0 8.43 5 SMDJ250A SMDJ250CA PHZ DHZ 250.0 279.00 309.00 1 405.0 7.41 5 SMDJ300A SMDJ300CA PJE DJE 300.0 335.00 371.00 1 486.0 6.17 5 SMDJ350A SMDJ350CA PJG DJG 350.0 391.00 432.00 1 567.0 5.29 5 SMDJ400A SMDJ400CA PJK DJK 400.0 447.00 494.00 1 648.0 4.63 5 SMDJ440A SMDJ440CA PJM DJM 440.0 492.00 543.00 1 713.0 4.21 5 Part Number Marking Note: 1. Suffix 'A ' denotes 5% tolerance device. 2. Add suffix ' CA ' after part number to specify Bi-directional devices. 3. For Bi-Directional devices having VR of 10 volts and under, the IR limit is double. SOCAY Electronics Corp., Ltd. Revision March 28, 2017 www.socay.com 3/7 @ SOCAY Electronics Corp., Ltd 2017 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Surface Mount Transient Voltage Suppressors (TVS) SMDJ Series 5.0 To 440 V 3000W Ratings and Characteristic Curves (TA=25°C unless otherwise noted) Figure 1 - Peak Pulse Power Rating Curve Figure 2 - Pulse Derating Curve Peak Pulse Power (PPP) or Current (IPP) Derating in Percentage % PPPM - Peak Pulse Power (kW) 100 10 1 0.1 0.1 1 10 100 td - Pulse Width (μs) 1000 10000 Figure 3 - Pulse Waveform Peak Value IPPM CJ – Junction Capacitance (pF) IPPM - Peak Pulse Current, % IRSM TJ=25°C Pulse Width(td) is defined as the point where the peak current decays to 50% of IPPM 100 Half Value IPPM (IPPM/2) 50 10/1000µsec. Waveform as defined by R.E.A tc 0 40 20 0 0 25 50 75 100 125 TA-Ambient temperature(°C) 150 175 2.0 t - Time (ms) 3.0 Bi-directional @zero bins 10000 Uni-directional @zero bins 1000 Uni-directional @VRWM 100 10 1 1.0 4.0 Figure 5 - Steady State Power Derating Curve Tj=25°C f=1.0MHz Vsig=50mVp-p 1.0 Bi-directional @VRWM 10.0 100.0 VBR-Reverse Breakdown Voltage (V) 1000.0 Figure 6 - Maximum Non-Repetitive Surge Current 300 6.0 IFSM-Peak Forward Surge Current (A) PM(AV), Steady State Power Dissipation (W) 60 100000 tr=10µsec 5.0 4.0 3.0 2.0 1.0 0.0 80 Figure 4 - Typical Junction Capacitance 150 0 100 0 25 50 75 100 125 150 TL - Lead Temperature(°C) 175 250 200 150 100 200 SOCAY Electronics Corp., Ltd. Revision March 28, 2017 TJ=TJ max. 8.3 ms Single Half Sine-Wave 1 10 Number of Cycles at 60Hz 100 www.socay.com 4/7 @ SOCAY Electronics Corp., Ltd 2017 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Surface Mount Transient Voltage Suppressors (TVS) SMDJ Series 5.0 To 440 V 3000W I-V Curve Characteristics Uni-directional Bi-directional I I IPP IF VC V VBR VRW R M VF IT IPP VC C r i t i c a l IR IT IT V IR VRW VBR VC R M IPP Z o n e T Physical Specifications VBR VRW R M Environmental Specifications L Weight 0.007 ounce, 0.21 gram t o JEDEC DO-214AB Molded Plastic over T glass passivated junction P Color band denotes cathode except Bipolar Matte Tin-plated leads, Solderable per JESD22-B102D Case Polarity Terminal Temperature Cycle JESD22-A104 Pressure Cooker JESD22-A102 High Temp. Storage JESD22-A103 HTRB JESD22-A108 Thermal Shock JESD22-A106 Soldering Parameters Reflow Condition Pre Heat TP Ramp-up TL Critical Zone TL to TP Temperature TS(max) Ramp-down TS(min) 25 -Temperature Min (Ts(min)) 150°C -Temperature Max (Ts(max)) 200°C - Time (min to max) (Ts) 60 -180 Seconds Average ramp up rate ( Liquidus Temp TL) to peak 3°C/second max TS(max) to TL - Ramp-up Rate 3°C/second max Reflow Preheat Lead–free assembly - Temperature (TL) (Liquidus) 217°C - Time (min to max) (TL) 60 -150 Seconds Peak Temperature (TP) Time to peak temperature (t 25℃ to peak) Time Time within 5°C Temperature (tp) SOCAY Electronics Corp., Ltd. Revision March 28, 2017 260 +0/-5°C of actual peak 20 -40 Seconds Ramp-down Rate 6°C/second max Time 25°C to peak Temperature (TP) 8 minutes Max Do not exceed 280°C www.socay.com 5/7 @ SOCAY Electronics Corp., Ltd 2017 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Surface Mount Transient Voltage Suppressors (TVS) SMDJ Series 5.0 To 440 V 3000W Dimensions Inches Dimensions DO-214AB (SMC) Cathode Band Part Numbering Millimeters Min Max Min Max A 0.108 0.126 2.75 3.20 B 0.260 0.280 6.60 7.11 C 0.220 0.244 5.59 6.20 D 0.085 0.103 2.15 2.62 E 0.030 0.060 0.76 1.52 F 0.002 0.008 0.051 0.203 G 0.305 0.320 7.74 8.13 H 0.006 0.012 0.15 0.31 I 0.121 - 3.07 - J 0.068 - 1.715 - K - 0.185 - 4.69 L 0.068 - 1.715 - Part Marking SMDJ×××CA Socay Logo 5% VBR VOLTAGE TOLERANCE BI-DIRECTIONAL VR VOLTAGE Cathode Band Marking Code SERIES SOCAY Electronics Corp., Ltd. Revision March 28, 2017 www.socay.com 6/7 @ SOCAY Electronics Corp., Ltd 2017 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Surface Mount Transient Voltage Suppressors (TVS) SMDJ Series 5.0 To 440 V 3000W Packaging Part Number Component Package Quantity Packaging Option Reel Diameters (mm) SMDJXXXXX DO-214AB (SMC) 500 pcs Tape & Reel -16mm/7″tape 177.8 SMDJXXXXX DO-214AB (SMC) 3000 pcs Tape & Reel -16mm/13″tape 330.0 Tape and Reel Specifications 7.0/13.0 (177.8/330.0) 0.157 (4.0) 0.059 Diameter (1.5) 0.630 (16.0) 0.36 (9.2) 0.512(13.0) Arbor Hole Diameter 0.315 (8.0) 0.646 (16.4) Cover tape Direction of Feed Dimensions are in inches (and millimeters) SOCAY Electronics Corp., Ltd. Revision March 28, 2017 www.socay.com 7/7 @ SOCAY Electronics Corp., Ltd 2017 Specifications are subject to change without notice. Please refer to www.socay.com for current information.
SMDJ24CA 价格&库存
很抱歉,暂时无法提供与“SMDJ24CA”相匹配的价格&库存,您可以联系我们找货
