UN2E5-470LL
UN2E5-470LL
    SOCAY(硕凯)
    GDT_D5.5X6MM_TM
    陶瓷气体放电管 5.5x6 Vdc=470V±20% IMP=100A@10/1000us
UN2E5-470LL 数据手册
2-Electrode Gas Discharge Tube (GDT) UN2E5 Series UN2E5-XXXLL Description UN2E5-XXXL Gas discharge Tubes (GDT) are classical components for protecting the installations of the telecommunications. It is essential that IT and telecommunications systems -with their high-grade but sensitive electronic circuits - be protected by arresters. They are thus fitted at the input of the power supply system together with varistors and at the connection points to telecommunication lines. They have become equally indispensable for protecting base stations in mobile telephone systems as well as extensive cable television (CATV) networks with their repeaters and distribution systems. These protective components are also indispensable in other Schematic Symbol sectors, In AC power transmission systems, they are often used with current-limiting varistors, In customer premises equipment such as DSL modems, WLAN routers, TV sets and cable modems In air-conditioning equipment, the integral black-box concept offers graduated protection by combining arresters with varistors, PTC, diodes and inductor. Features u Non-Radioactive u RoHS compliant u Low insertion loss u Excellent response to fast rising transients u Ultra low capacitance u 5KA surge capability tested with 8/20μs Agency Approvals AGENCY E341061 Product Characteristics Materials pulse as defined by IEC 61000-4-5 Product Marking Communication equipment CATV equipment Test equipment Data lines Power supplies Telecom SLIC protection Broadband equipment ADSL equipment, including ADSL2+ XDSL equipment Satellite and CATV equipment Consumer electronics XXX -Nominal voltage L -5KA Glow to Arc Transition Current < 0.5 Amps Glow Voltage ~60 Volts Storage and Operational Temperature Climatic category (IEC 60068-1) Weight SOCAY Electronics Co., Ltd. Revision October 26, 2015 Nickel-plated with Tinplated wires UNION XXXL Applications u u u u u u u u u u u AGENCY FILE NUMBER -40 to +90°C 40/90/21 UN2E5-XXXLL ~1.0g UN2E5-XXXL ~0.85g www.socay.com 1/4 @SOCAY Electronics Co., Ltd. 2015 Specifications are subject to change without notice. Please refer to www.socay.com for current information. 2-Electrode Gas Discharge Tube (GDT) UN2E5 Series Dimensions (Unit: mm) Axial Leaded Devices (UN2E5-XXXLL) Without wire Devices (UN2E5-XXXL) Electrical Characteristics Service Life Part Number DC Maximum Impulse Spark-over Spark-over Voltage Voltage Nominal Max Nominal Maximum Arc Impulse Alternating Impulse Minimum Capacitance Voltage Impulse Life Discharge Discharge Discharge Marking Insulation Current Current Current Resistance @50Hz @8/20μs @8/20μs @10/1000μs @100V/S @100V/μs @1KV/μs @1MHz @1A 1 Sec ±5 times 1 time 300 times 10 times UN2E5-75LL UN2E5-75L 75L 75V±20% <500V <600V 1 GΩ (at 25V) <1.0pF ~15V 5KA 10KA 5A 100A UN2E5-90LL UN2E5-90L 90L 90V±20% <500V <600V 1 GΩ (at 50V) <1.0pF ~15V 5KA 10KA 5A 100A UN2E5-150LL 150L UN2E5-150L 150V±20% <500V <600V 1 GΩ (at 50V) <1.0pF ~20V 5KA 10KA 5A 100A UN2E5-230LL 230L UN2E5-230L 230V±20% <600V <700V 1 GΩ (at 100V) <1.0pF ~20V 5KA 10KA 5A 100A UN2E5-250LL 250L UN2E5-250L 250V±20% <700V <800V 1 GΩ (at 100V) <1.0pF ~20V 5KA 10KA 5A 100A UN2E5-300LL 300L UN2E5-300L 300V±20% <800V <900V 1 GΩ (at 100V) <1.0pF ~20V 5KA 10KA 5A 100A UN2E5-350LL 350L UN2E5-350L 350V±20% <800V <900V 1 GΩ (at 100V) <1.0pF ~20V 5KA 10KA 5A 100A UN2E5-420LL 420L UN2E5-420L 420V±20% <900V <1000V 1 GΩ (at 100V) <1.0pF ~20V 5KA 10KA 5A 100A UN2E5-470LL 470L UN2E5-470L 470V±20% <900V <1000V 1 GΩ (at 100V) <1.0pF ~20V 5KA 10KA 5A 100A UN2E5-600LL 600L UN2E5-600L 600V±20% <1100V <1200V 1 GΩ (at 100V) <1.0pF ~20V 5KA 10KA 5A 100A UN2E5-800LL 800L UN2E5-800L 800V±20% <1200V <1400V 1 GΩ (at 100V) <1.0pF ~20V 5KA 10KA 5A 100A Notes: 1). Terms in accordance with ITU-T K.12 and GB/T 9043-2008 2). At delivery AQL 0.65 level Ⅱ, DIN ISO 2859 SOCAY Electronics Co., Ltd. Revision October 26, 2015 www.socay.com 2/4 @SOCAY Electronics Co., Ltd. 2015 Specifications are subject to change without notice. Please refer to www.socay.com for current information. 2-Electrode Gas Discharge Tube (GDT) UN2E5 Series Electrical Rating Item DC Spark-over Voltage Impulse Spark-over Voltage Insulation Resistance Capacitance Test Condition / Description Requirement The voltage is measured with a slowly rate of rise dv / dt=100V/s The maximum impulse spark-over voltage is measured with a rise time of dv / dt=100V//μs or 1KV/μs The resistance of gas tube shall be measured each terminal each other terminal, see above spec. please The capacitance of gas tube shall be measured each terminal to each other terminal. Test frequency :1MHz The maximum current applying a waveform of 8/20μs that can be applied across the terminals of the gas tube. One hour after the test is completed, re-testing of the DC spark-over voltage does not exceed ±30% of the nominal DC spark-over voltage. Dwell time between pulses is 3 minutes. I 1.0 0.9 To meet the specified value Nominal Impulse Discharge Current 0.5 0.1 0.0 8μsec 20μsec Nominal Alternating Discharge Current 30% Max T Rated RMS value of AC current at 50Hz, 1 sec. 10 times. Intervals: 3min. The DC spark-over voltage does not exceed ±30% of the nominal DC spark-over voltage. IR > 108ohms. Recommended soldering profile Reflow soldering Wave soldering Soldering profile applied a single process Soldering Parameters - Hand Soldering Solder Iron Temperature: 350°C +/-5°C Heating Time: 5 seconds max. SOCAY Electronics Co., Ltd. Revision October 26, 2015 www.socay.com 3/4 @SOCAY Electronics Co., Ltd. 2015 Specifications are subject to change without notice. Please refer to www.socay.com for current information. 2-Electrode Gas Discharge Tube (GDT) UN2E5 Series Part Numbering UN2E5 – XXX L L L, No, with axial wire without wire 8/20μs Level L, 5KA Nominal DC Spark-over Voltage 75 = 75V 250=250V 470=470V 90 = 90V 300=300V 600=600V 150 = 150V 350=350V 800=800V 230 = 230V 420=420V Series Packaging Information Part Number Unit: mm Description Quantity UN2E5-XXXLL 100PCS per Tray, 10 Trays / Inner Carton 1000 UN2E5-XXXL 100PCS per Tray, 10 Trays / Inner Carton 1000 Tray used in UN2E5-XXXLL Tray used in UN2E5-XXXL Cautions and warnings u Gas discharge tubes (GDT) must not be operated directly in power supply networks. u Gas discharge tubes (GDT) may become hot in case of longer periods of current stress (danger of burning). u Gas discharge tubes (GDT) may be used only within their specified values. In the event of overload, the head contacts may fail or the component may be destroyed. u Damaged Gas discharge tubes (GDT) must not be re-used. SOCAY Electronics Co., Ltd. Revision October 26, 2015 www.socay.com 4/4 @SOCAY Electronics Co., Ltd. 2015 Specifications are subject to change without notice. Please refer to www.socay.com for current information.
UN2E5-470LL 价格&库存
很抱歉,暂时无法提供与“UN2E5-470LL”相匹配的价格&库存,您可以联系我们找货
