UN2E8-90HSMD
UN2E8-90HSMD
    SOCAY(硕凯)
    GDT_D8.3X6MM_SM
    陶瓷气体放电管 8x6 Vdc=90V±20% IMP=200A@10/1000us
UN2E8-90HSMD 数据手册
2-Electrode Gas Discharge Tube (GDT) UN2E8 Series UN2E8-XXXM/HL Description UN2E8-XXXM/H Gas discharge Tubes (GDT) are classical components for protecting the installations of the telecommunications. It is essential that IT and telecommunications systems -with their high-grade but sensitive electronic circuits - be protected by arresters. They are thus fitted at the input of the power supply UN2E8-XXXM/HSMD system together with varistors and at the connection points to telecommunication lines. They have become equally indispensable for protecting base stations in mobile telephone systems as well as extensive cable television (CATV) networks with their repeaters and distribution systems. These protective components are also indispensable in other Schematic Symbol sectors, In AC power transmission systems, they are often used with current-limiting varistors, In customer premises equipment such as DSL modems, WLAN routers, TV sets and cable modems In air-conditioning equipment, the integral black-box concept offers graduated protection by combining arresters with varistors, PTC, diodes and inductor. Agency Approvals Features u Non-Radioactive u RoHS compliant u High insulation resistance u Excellent response to fast rising transients u Ultra low capacitance u 10~20KA surge capability tested with 8/20μs pulse as defined AGENCY E341061 Product Characteristics Materials by IEC 61000-4-5 Product Marking Communication lines and equipment u CATV equipment u Test equipment u Data lines u Power supplies u Instrumentation circuits u Medical electronics u ADSL equipment u Telecom SLIC protection with -Nominal voltage - 10KA - 20KA < 0.5 Amps Glow Voltage ~60 Volts Storage and Operational Temperature -40 to +90°C Weight SOCAY Electronics Co., Ltd. XXX M H Glow to Arc Transition Current Climatic category (IEC 60068-1) Revision March 6, 2014 Leaded Device: Nickel-plated Tinplated wires Surface Mount: Dull Tin-plated UNION XXXM/H Applications u AGENCY FILE NUMBER UN2E8-XXXML ~1.5g UN2E8-XXXHL ~1.6g UN2E8-XXXM/H ~1.35g UN2E8-XXXM/HSMD ~1.5g 40/ 90/ 21 www.socay.com 1/6 @SOCAY Electronics Co., Ltd. 2014 Specifications are subject to change without notice. Please refer to www.socay.com for current information. 2-Electrode Gas Discharge Tube (GDT) UN2E8 Series Dimensions Unit: mm Axial Leaded Devices (UN2E8-XXXML) Without wire Devices (UN2E8-XXXM/H) Axial Leaded Devices (UN2E8-XXXHL) Surface Mount Devices (UN2E8-XXXM/HSMD) Recommended pad outline Electrical Characteristics Service Life Part Number UN2E8-75M UN2E8-75ML UN2E8-75MSMD UN2E8-90M UN2E8-90ML UN2E8-90MSMD UN2E8-150M UN2E8-150ML UN2E8-150MSMD UN2E8-230M UN2E8-230ML UN2E8-230MSMD UN2E8-250M UN2E8-250ML UN2E8-250MSMD UN2E8-300M UN2E8-300ML UN2E8-300MSMD UN2E8-350M UN2E8-350ML UN2E8-350MSMD Marking DC Spark-ove r Voltage Maximum Impulse Spark-over Voltage Minimum Insulation Resistanc e Max Impulse Discharge Current Nominal Impulse Discharge Current Impulse Life @1A @8/20μs ±5 times @8/20μs 1 time @50Hz 1 Sec 10 times @10/1000μs 300 times Arc Voltage @1MHz @100V/S @100V/μs @1KV/μs 75M 75V±20% <500V <600V 1 GΩ (at 25V) <1.5pF ~15V 10KA 20KA 10A 100A 90M 90V±20% <500V <600V 1 GΩ (at 50V) <1.5pF ~15V 10KA 20KA 10A 100A 150M 150V±20% <500V <600V 1 GΩ (at 50V) <1.5pF ~20V 10KA 20KA 10A 100A 230M 230V±20% <600V <700V 1 GΩ (at 100V) <1.5pF ~20V 10KA 20KA 10A 100A 250M 250V±20% <700V <800V 1 GΩ (at 100V) <1.5pF ~20V 10KA 20KA 10A 100A 300M 300V±20% <800V <900V 1 GΩ (at 100V) <1.5pF ~20V 10KA 20KA 10A 100A 350M 350V±20% <800V <900V 1 GΩ (at 100V) <1.5pF ~20V 10KA 20KA 10A 100A SOCAY Electronics Co., Ltd. Revision March 6, 2014 Nominal Impulse Discharge Current Maximum Capacitance www.socay.com 2/6 @SOCAY Electronics Co., Ltd. 2014 Specifications are subject to change without notice. Please refer to www.socay.com for current information. 2-Electrode Gas Discharge Tube (GDT) UN2E8 Series Electrical Characteristics (Continue) Service Life Part Number Marking DC Spark-ove r Voltage @100V/S UN2E8-420M UN2E8-420ML UN2E8-420MSMD UN2E8-470M UN2E8-470ML UN2E8-470MSMD UN2E8-600M UN2E8-600ML UN2E8-600MSMD UN2E8-800M UN2E8-800ML UN2E8-800MSMD UN2E8-75H UN2E8-75HL UN2E8-75HSMD UN2E8-90H UN2E8-90HL UN2E8-90HSMD UN2E8-150H UN2E8-150HL UN2E8-150HSMD UN2E8-230H UN2E8-230HL UN2E8-230HSMD UN2E8-250H UN2E8-250HL UN2E8-250HSMD UN2E8-300H UN2E8-300HL UN2E8-300HSMD UN2E8-350H UN2E8-350HL UN2E8-350HSMD UN2E8-420H UN2E8-420HL UN2E8-420HSMD UN2E8-470H UN2E8-470HL UN2E8-470HSMD UN2E8-600H UN2E8-600HL UN2E8-600HSMD UN2E8-800H UN2E8-800HL UN2E8-800HSMD Maximum Impulse Spark-over Voltage @100V/μs Minimum Insulation Resistanc e @1KV/μs Maximum Capacitance @1MHz Arc Voltage @1A Nominal Max Nominal Impulse Impulse Alternating Impulse Discharge Discharge Discharge Life Current Current Current @8/20μs @8/20μs ±5 times 1 time @50Hz 1 Sec 10 times @10/1000μs 300 times 420M 420V±20% <900V <1000V 1 GΩ (at 100V) <1.5pF ~20V 10KA 20KA 10A 100A 470M 470V±20% <900V <1000V 1 GΩ (at 100V) <1.5pF ~20V 10KA 20KA 10A 100A 600M 600V±20% <1100V <1200V 1 GΩ (at 100V) <1.5pF ~20V 10KA 20KA 10A 100A 800M 800V±20% <1200V <1400V 1 GΩ (at 100V) <1.5pF ~20V 10KA 20KA 10A 100A 75H 75V±20% <500V <600V 1 GΩ (at 25V) <1.5pF ~15V 20KA 25KA 20A 200A 90H 90V±20% <500V <600V 1 GΩ (at 50V) <1.5pF ~15V 20KA 25KA 20A 200A 150H 150V±20% <500V <600V 1 GΩ (at 50V) <1.5pF ~20V 20KA 25KA 20A 200A 230H 230V±20% <600V <700V 1 GΩ (at 100V) <1.5pF ~20V 20KA 25KA 20A 200A 250H 250V±20% <700V <800V 1 GΩ (at 100V) <1.5pF ~20V 20KA 25KA 20A 200A 300H 300V±20% <800V <900V 1 GΩ (at 100V) <1.5pF ~20V 20KA 25KA 20A 200A 350H 350V±20% <800V <900V 1 GΩ (at 100V) <1.5pF ~20V 20KA 25KA 20A 200A 420H 420V±20% <900V <1000V 1 GΩ (at 100V) <1.5pF ~20V 20KA 25KA 20A 200A 470H 470V±20% <900V <1000V 1 GΩ (at 100V) <1.5pF ~20V 20KA 25KA 20A 200A 600H 600V±20% <1100V <1200V 1 GΩ (at 100V) <1.5pF ~20V 20KA 25KA 20A 200A 800H 800V±20% <1200V <1400V 1 GΩ (at 100V) <1.5pF ~20V 20KA 25KA 20A 200A Notes: 1). Terms in accordance with ITU-T K.12 and GB/T 9043-2008 2). At delivery AQL 0.65 level Ⅱ, DIN ISO 2859 SOCAY Electronics Co., Ltd. Revision March 6, 2014 www.socay.com 3/6 @SOCAY Electronics Co., Ltd. 2014 Specifications are subject to change without notice. Please refer to www.socay.com for current information. 2-Electrode Gas Discharge Tube (GDT) UN2E8 Series Electrical Rating Item Test Condition / Description DC Spark-over Voltage Impulse Spark-over Voltage Insulation Resistance Capacitance Requirement The voltage is measured with a slowly rate of rise dv / dt=100V/s The maximum impulse spark-over voltage is measured with a rise time of dv / dt=100V//μs or 1KV/μs The resistance of gas tube shall be measured each terminal each other terminal, please see above spec. The capacitance of gas tube shall be measured each terminal to each other terminal. Test frequency :1MHz The maximum current applying a waveform of 8/20μs that can be applied across the terminals of the gas tube. One hour after the test is completed, re-testing of the DC spark-over voltage does not exceed ±30% of the nominal DC spark-over voltage. Dwell time between pulses is 3 minutes. I 1.0 0.9 To meet the specified value Nominal Impulse Discharge Current 0.5 0.1 0.0 8μsec 20μsec Nominal Alternating Discharge Current 30% Max T Rated RMS value of AC current at 50Hz, 1 sec. 10 times. Intervals: 3min. The DC spark-over voltage does not exceed ±30% of the nominal DC spark-over voltage. 8 IR > 10 ohms. Recommended soldering profile Reflow soldering Wave soldering Soldering profile applied a single process Soldering Parameters - Hand Soldering Solder Iron Temperature: 350°C +/-5°C Heating Time: 5 seconds max. SOCAY Electronics Co., Ltd. Revision March 6, 2014 www.socay.com 4/6 @SOCAY Electronics Co., Ltd. 2014 Specifications are subject to change without notice. Please refer to www.socay.com for current information. 2-Electrode Gas Discharge Tube (GDT) UN2E8 Series Part Numbering UN2E8 – XXX M L No, L, SMD, without wire with axial wire Surface Mount 8/20μs Level M, 10KA H, 20KA Nominal DC Spark-over Voltage 75 = 75V 350=350V 90 = 90V 470=470V 150 = 150V 600=600V 230 = 230V 800=800V Series Packaging Information Unit: mm Part Number Description Quantity UN2E8-XXXM / UN2E8XXXH 100PCS per Tray, 10 Trays / Inner Carton 1000 UN2E8-XXXML / UN2E8XXXHL 100PCS per Tray, 10 Trays / Inner Carton 1000 100PCS per Tray, 10 Trays / Inner Carton 1000 Tape & Reel -16mm tape/13″Reel 500 UN2E8-XXXMSMD / UN2E8XXXHSMD Tray used in UN2E8-XXXML / UN2E8-XXXHL Tray used in UN2E8-XXXM / UN2E8-XXXH / UN2E8-XXXSMD SOCAY Electronics Co., Ltd. Revision March 6, 2014 www.socay.com 5/6 @SOCAY Electronics Co., Ltd. 2014 Specifications are subject to change without notice. Please refer to www.socay.com for current information. 2-Electrode Gas Discharge Tube (GDT) UN2E8 Series Tape and Reel Dimensions Tape Unit: mm Used in UN2E8-XXXMSMD /UN2E8-XXXHSMD Reel Packaging Information (Continue) Unit: mm u Gas discharge tubes (GDT) must not be operated directly in power supply networks. u Gas discharge tubes (GDT) may become hot in case of longer periods of current stress (danger of burning). u Gas discharge tubes (GDT) may be used only within their specified values. In the event of overload, the head contacts may fail or the component may be destroyed. u Damaged Gas discharge tubes (GDT) must not be re-used. SOCAY Electronics Co., Ltd. Revision March 6, 2014 www.socay.com 6/6 @SOCAY Electronics Co., Ltd. 2014 Specifications are subject to change without notice. Please refer to www.socay.com for current information.
UN2E8-90HSMD 价格&库存
很抱歉,暂时无法提供与“UN2E8-90HSMD”相匹配的价格&库存,您可以联系我们找货
