UN3E8-230HM
UN3E8-230HM
    SOCAY(硕凯)
    GDT_D8X10MM_TM
    陶瓷气体放电管 10x8 Vdc=230V±20% IMP=200A@10/1000us
UN3E8-230HM 数据手册
3-Electrode Gas Discharge Tube (GDT) UN3E8 Series Description UN3E8-XXXHM UN3E8-XXXHMF UN3E8-XXXHP UN3E8-XXXH Gas discharge Tubes (GDT) are classical components for protecting the installations of the telecommunications. It is essential that IT and telecommunications systems -with their high-grade but sensitive electronic circuits - be protected by arresters. They are thus fitted at the input of the power supply system together with varistors and at the connection points to telecommunication lines. They have become equally indispensable for protecting base stations in mobile telephone systems as well as extensive cable television (CATV) networks with their repeaters and distribution systems. These protective components are also indispensable in other sectors, In AC power transmission systems, they are often used Schematic Symbol with current-limiting varistors, In customer premises equipment such as DSL modems, WLAN routers, TV sets and cable modems In air-conditioning equipment, the integral black-box concept offers a a = Tip b = Ring e = Ground (center electrode) b graduated protection by combining arresters with varistors, PTC, diodes and inductor. Agency Approvals Features u u u u u u u Non-Radioactive RoHS compliant Low insertion loss Excellent response to fast rising transients Ultra low capacitance 20KA surge capability tested with 8/20μs pulse as defined by IEC 61000-4-5 Available with thermal failsafe option (add ‘F’ suffix to part number) Communication equipment CATV equipment Test equipment Data lines Power supplies Telecom SLIC protection Broadband equipment ADSL equipment, including ADSL2+ XDSL equipment Satellite and CATV equipment Consumer electronics Revision March 6, 2014 Product Characteristics Materials Nickel-plated with Tinplated wires UNION XXXH XXX H -Nominal voltage -20KA Glow to Arc Transition Current ~1 Amps Glow Voltage ~70 Volts Storage and Operational Temperature -40 to +90°C Weight Climatic category (IEC 60068-1) SOCAY Electronics Co., Ltd. AGENCY FILE NUMBER E341061 Product Marking Applications u u u u u u u u u u u AGENCY UN3E8-XXXHM ~2.0g UN3E8-XXXHMF ~2.3g UN3E8-XXXHP ~2.1g UN3E8-XXXH ~1.8g 40/ 90/ 21 www.socay.com 1/5 @SOCAY Electronics Co., Ltd. 2014 Specifications are subject to change without notice. Please refer to www.socay.com for current information. 3-Electrode Gas Discharge Tube (GDT) UN3E8 Series Dimensions (Unit: mm) Radial Leaded Devices (UN3E8-XXXHM) Radial Leaded Devices with Fail-Safe (UN3E8-XXXHMF) "T" Leaded Devices (UN3E8-XXXHP) Without wire Devices (UN3E8-XXXH) Electrical Characteristics Service Life DC Spark-over Voltage Part Number Maximum Impulse Spark-over Voltage Marking @100V/S @100V/μs @1KV/μs UN3E8-75HM UN3E8-75HMF UN3E8-75HP UN3E8-75H UNION 75H 75V±20% <500V <600V UN3E8-90HM UN3E8-90HMF UN3E8-90HP UN3E8-90H UNION 90H 90V±20% <500V <600V Maximum Minimum Capacitance Insulation Resistance 1 GΩ (at 25V) 1 GΩ (at 50V) SOCAY Electronics Co., Ltd. Revision March 6, 2014 Arc Voltage Nominal Impulse Discharge Current Nominal Max Impulse Alternating Discharge Discharge Current Current Impulse Life @1MHz @1A @8/20μs 4) ±5 times @8/20μs 4) 1 time @50Hz 4) 1 Sec 10 times @10/1000μs 4) 300 times <1.5pF ~15V 20KA 25KA 20A 200A <1.5pF ~15V 20KA 25KA 20A 200A www.socay.com 2/5 @SOCAY Electronics Co., Ltd. 2014 Specifications are subject to change without notice. Please refer to www.socay.com for current information. 3-Electrode Gas Discharge Tube (GDT) UN3E8 Series Electrical Characteristics (Continue) Service Life DC Spark-over Voltage Part Number Maximum Impulse Spark-over Voltage Marking @100V/S @100V/μs @1KV/μs UN3E8-150HM UN3E8-150HMF UN3E8-150HP UN3E8-150H UNION 150H 150V±20% <500V <600V UN3E8-230HM UN3E8-230HMF UN3E8-230HP UN3E8-230H UNION 230H 230V±20% <600V <700V UN3E8-250HM UN3E8-250HMF UN3E8-250HP UN3E8-250H UNION 250H 250V±20% <600V <700V UN3E8-300HM UN3E8-300HMF UN3E8-300HP UN3E8-300H UNION 300H 300V±20% <800V <900V UN3E8-350HM UN3E8-350HMF UN3E8-350HP UN3E8-350H UNION 350H 350V±20% <800V <900V UN3E8-420HM UN3E8-420HMF UN3E8-420HP UN3E8-420H UNION 420H 420V±20% <900V <1000V UN3E8-470HM UN3E8-470HMF UN3E8-470HP UN3E8-470H UNION 470H 470V±20% <900V <1000V UN3E8-600HM UN3E8-600HMF UN3E8-600HP UN3E8-600H UNION 600H 600V±20% <1100V <1200V UN3E8-800HM UN3E8-800HMF UN3E8-800HP UN3E8-800H UNION 800H 800V±20% <1200V <1400V Maximum Minimum Capacitance Insulation Resistance 1 GΩ (at 50V) 1 GΩ (at 100V) 1 GΩ (at 100V) 1 GΩ (at 100V) 1 GΩ (at 100V) 1 GΩ (at 100V) 1 GΩ (at 100V) 1 GΩ (at 100V) 1 GΩ (at 100V) Arc Voltage Nominal Impulse Discharge Current Nominal Max Impulse Alternating Discharge Discharge Current Current Impulse Life @1MHz @1A @8/20μs 4) ±5 times @8/20μs 4) 1 time @50Hz 4) 1 Sec 10 times @10/1000μs 4) 300 times <1.5pF ~25V 20KA 25KA 20A 200A <1.5pF ~25V 20KA 25KA 20A 200A <1.5pF ~25V 20KA 25KA 20A 200A <1.5pF ~25V 20KA 25KA 20A 200A <1.5pF ~25V 20KA 25KA 20A 200A <1.5pF ~25V 20KA 25KA 20A 200A <1.5pF ~25V 20KA 25KA 20A 200A <1.5pF ~25V 20KA 25KA 20A 200A <1.5pF ~25V 20KA 25KA 20A 200A Notes: 1). Terms in accordance with ITU-T K.12 and GB/T 9043-2008 2). At delivery AQL 0.65 level Ⅱ, DIN ISO 2859 3). Tip or ring electrode to center electrode 4). Total current through center electrode, half value through tip respectively ring electrode SOCAY Electronics Co., Ltd. Revision March 6, 2014 www.socay.com 3/5 @SOCAY Electronics Co., Ltd. 2014 Specifications are subject to change without notice. Please refer to www.socay.com for current information. 3-Electrode Gas Discharge Tube (GDT) UN3E8 Series Electrical Rating Item Test Condition / Description DC Spark-over Voltage Impulse Spark-over Voltage Insulation Resistance Capacitance Requirement The voltage is measured with a slowly rate of rise dv / dt=100V/s The maximum impulse spark-over voltage is measured with a rise time of dv / dt=100V//μs or 1KV/μs The resistance of gas tube shall be measured each terminal each other terminal, please see above spec. The capacitance of gas tube shall be measured each terminal to each other terminal. Test frequency :1MHz The maximum current applying a waveform of 8/20μs that can be applied across the terminals of the gas tube. One hour after the test is completed, re-testing of the DC spark-over voltage does not exceed ±30% of the nominal DC spark-over voltage. Dwell time between pulses is 3 minutes. I 1.0 0.9 To meet the specified value Nominal Impulse Discharge Current 0.5 0.1 0.0 30% Max 20μsec Nominal Alternating Discharge Current T Rated RMS value of AC current at 50Hz, 1 sec. 10 times. Intervals: 3min. The DC spark-over voltage does not exceed ±30% of the nominal DC spark-over voltage. 8 IR > 10 ohms. Recommended soldering profile Reflow soldering Wave soldering Soldering profile applied a single process Soldering Parameters - Hand Soldering Solder Iron Temperature: 350°C +/-5°C Heating Time: 5 seconds max. SOCAY Electronics Co., Ltd. Revision March 6, 2014 www.socay.com 4/5 @SOCAY Electronics Co., Ltd. 2014 Specifications are subject to change without notice. Please refer to www.socay.com for current information. 3-Electrode Gas Discharge Tube (GDT) UN3E8 Series Part Numbering UN3E8 – XXX H M F F, No, with Fail-Safe without Fail-Safe M, No, with wire without wire 8/20μs Level H, 20KA Nominal DC Spark-over Voltage 75 = 75V 350=350V 90 = 90V 470=470V 150 = 150V 600=600V 230 = 230V 800=800V Series Packaging Part Number Description Quantity UN3E8-XXXHM 100PCS per Tray, 10 Trays / Inner Carton 1000 UN3E8-XXXHMF 100PCS per Tray, 10 Trays / Inner Carton 1000 UN3E8-XXXHP 50PCS per Tray, 10 Trays / Inner Carton 500 UN3E8-XXXH 100PCS per Tray, 10 Trays / Inner Carton 1000 Tray Dimension (Unit: mm) Tray Dimension (Unit: mm) Used in UN3E8-XXXHM, UN3E8-XXXHMF, UN3E8-XXXH Used in UN3E8-XXXHP Cautions and warnings u u u u Gas discharge tubes (GDT) must not be operated directly in power supply networks. Gas discharge tubes (GDT) may become hot in case of longer periods of current stress (danger of burning). Gas discharge tubes (GDT) may be used only within their specified values. In the event of overload, the head contacts may fail or the component may be destroyed. Damaged Gas discharge tubes (GDT) must not be re-used. SOCAY Electronics Co., Ltd. Revision March 6, 2014 www.socay.com 5/5 @SOCAY Electronics Co., Ltd. 2014 Specifications are subject to change without notice. Please refer to www.socay.com for current information.
UN3E8-230HM 价格&库存
很抱歉,暂时无法提供与“UN3E8-230HM”相匹配的价格&库存,您可以联系我们找货
