SR05-4B
SR05-4B
    SOCAY(硕凯)
    SOT26
    ESD抑制器 VRWM=5V VBR(Min)=6V VC=12V IPP=5A SOT26
SR05-4B 数据手册
Transient Voltage Suppressors Array for ESD Protection Low Capacitance SR05-4B Description SOT-26 The SR05-4B is designed to protect voltage sensitive components from ESD and transient voltage events. Excellent clamping capability, low leakage, and fast response time, make these parts ideal for ESD protection on designs where board space is at a premium. Feature Functional Diagram  350 Watts Peak Pulse Power per Line (tp=8/20μs)  Protects four I/O lines  Low clamping voltage  Working voltages : 5V  Low leakage current  IEC61000-4-2 (ESD) ±15kV (air), ±8kV (contact)  IEC61000-4-4 (EFT) 40A (5/50ns)  IEC61000-4-5 (Lightning) 5A (8/20μs) Applications  USB 2.0 Power and Data LineProtection  Video Graphics Cards  Monitors and Flat Panel Displays  Digit Video Interface (DVI)  10/100/1000 Ethernet  Notebook Computers  SIM Ports  ATM Interfaces Mechanical Characteristics  JEDEC SOT-26 Package  Molding Compound Flammability Rating : UL94V-0  Weight 16.0 Milligrams (Approximate)  Quantity Per Reel : 3,000pcs  Reel Size : 7 inch  Lead Finish : Lead Free Mechanical Characteristics Symbol Parameter Value Units TL Lead Soldering Temperature 260 (10sec) ºC TSTG Storage Temperature Range -55 to +150 ºC TOP Operating Temperature Range -55 to +150 ºC IEC61000-4-2 (ESD) Air Discharge ±15 Contact Discharge ±8 SOCAY Electronics Co., Ltd. Revision October 18, 2018 KV www.socay.com 1/4 @ SOCAY Electronics Co., Ltd. 2018 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Transient Voltage Suppressors Array for ESD Protection Low Capacitance SR05-4B Electrical Characteristics (@ 25℃ Unless Otherwise Specified ) Symbol Parameter IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP VRWM IR Working Peak Reverse Voltage Maximum Reverse Leakage Current @ VRWM VBR Breakdown Voltage @ IT IT Test Current IF Forward Current VF Forward Voltage @ IF Electrical Characteristics (@ 25℃ Unless Otherwise Specified ) Symbol VRWM IR VBR VC1 VC1 VC2 VC2 CJ1 CJ2 Test Condition — VRWM = 5V, T = 25℃ Between I/Oand GND IT = 1mA Between I/Oand GND IPP = 1A, tp = 8/20μs Between I/Oand GND IPP = 5A, tp = 8/20μs Between I/Oand GND IPP = -1A, tp = 8/20μs Between I/Oand GND IPP = -5A, tp = 8/20μs Between I/Oand GND VR = 0V, f = 1MHz Between I/O and I/O VR = 0V, f = 1MHz Between I/Oand GND SOCAY Electronics Co., Ltd. Revision October 18, 2018 Minimum Typical Maximum Units — — 5.0 V — — 1.0 μA 6.0 — — V — 8.5 12 V — 12 16 V — 1.8 — V — 5.0 — V — 0.3 0.4 pF — 0.6 0.8 pF www.socay.com 2/4 @ SOCAY Electronics Co., Ltd. 2018 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Transient Voltage Suppressors Array for ESD Protection Low Capacitance SR05-4B Characteristic Curves Fig1. 8/20μsPulse Waveform Fig2. ESD Pulse Waveform (according to IEC 61000-4-2) tr 100 100% TEST WAVEFORM PARAMETERS tr=8μs td=20μs Peak Value IPP 80 Percent of Peak Pulse Current % IPP - Peak Pulse Current - % of IPP 120 60 40 td=t IPP/2 20 0 0 5 10 15 20 25 90% 10% tr = 0.7~1ns Time (ns) 30ns 30 60ns t - Time (μs) Fig3. Power Derating Curve % of Rated Power 110 100 90 80 70 60 50 40 30 20 10 0 0 25 50 75 100 125 150 Ambient Temperature – TA (ºC) SOCAY Electronics Co., Ltd. Revision October 18, 2018 www.socay.com 3/4 @ SOCAY Electronics Co., Ltd. 2018 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Transient Voltage Suppressors Array for ESD Protection Low Capacitance SR05-4B SOT-26 Package Outline & Dimensions Inches Symbol θ Min. A 0.035 - 0.057 0.90 - 1.45 A1 0.000 - 0.006 0.00 - 0.15 A2 0.035 0.045 0.051 0.90 1.15 1.30 b 0.010 - 0.020 0.25 - 0.50 c 0.003 - 0.009 0.08 - 0.22 D 0.110 0.114 0.122 2.80 2.90 3.10 E1 0.060 0.063 0.069 1.50 1.60 1.75 E 0.110 BSC 2.80 BSC e 0.037 BSC 0.95 BSC 0.075 BSC 1.90 BSC e1 L 0.012 0.018 0.024 0.30 0.45 0.60 L1 (0.024) θ Soldering Footprint SOCAY Electronics Co., Ltd. Revision October 18, 2018 Millimeters Nom. Max. Min. Nom. Max. 0° - (0.60) 10° 0° - 10° aaa 0.004 0.10 bbb 0.008 0.20 ccc 0.008 0.20 Symbol Inches Millimeters C (0.098) (2.50) G 0.055 1.40 P 0.037 0.95 X 0.024 0.60 Y 0.043 1.10 Z 0.141 3.60 www.socay.com 4/4 @ SOCAY Electronics Co., Ltd. 2018 Specifications are subject to change without notice. Please refer to www.socay.com for current information.
SR05-4B 价格&库存
很抱歉,暂时无法提供与“SR05-4B”相匹配的价格&库存,您可以联系我们找货
