DB107S
DB107S
    SK(時科)
    DBS-4P_8.15X6.3MM_SM
    桥式整流器 VRRM=1KV If=1A VF=1.1V DBS
DB107S 数据手册
Voltage Range - 50 to 1000 Volts Current - 1.0 Ampere FEATURES ·Ideal for printed circuit board ·Reliable low cost construction utilizing molded plastic technique guaranteed:250 seconds / 0.375''(9.5mm) ·High temperature soldering guaranteed:250*/10 led length at 5 lbs., (2.3kg)tension ·Small size, simple installation Leads solderable per MIL-STD-202,Method MIL 208 ·High surge current capability MECHANICAL DATA ·Case: Molded plastic body MIL 2026 ·Terminals:: Plated leads solderable per MIL-STD-750,Method ·Polarity:: Polarity symbols marked on case ·Mounting Position: Any ·Weight:0.02 ounce, 0.4 grams MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25℃ ambient temperature unless otherwise specified.Single phase half-wave wave 60Hz,resistive or inductive load, For capacitive load derate current by 20%. NOTES: DBS for surface mount package. 1 of 2 RATINGS AND CHARACTERISTIC CURVES DB101S THRU DB107S 2 of 2
DB107S 价格&库存
很抱歉,暂时无法提供与“DB107S”相匹配的价格&库存,您可以联系我们找货
DB107S
  • 1+0.30800
  • 30+0.29700
  • 100+0.28600
  • 500+0.26400
  • 1000+0.25300
  • 2000+0.24640
