US1MG
US1MG
    SK(時科)
    SMA(DO-214AC)
    快恢复二极管 VRRM=1KV If=1A VF=1.65V trr=75ns SMA
US1MG 数据手册
US1AG THRU US1MG SURFACE MOUNT ULTRAFAST RECOVERY RECTIFIER Reverse Voltage - 50 to 1000 V Forward Current - 1 A PINNING PIN FEATURES • For surface mounted applications • Low profile package • Glass Passivated Chip Junction • Easy to pick and place • High efficiency • Lead free in comply with EU RoHS 2011/65/EU directives DESCRIPTION 1 Cathode 2 Anode 1 MECHANICAL DATA • Case: SMA • Terminals: Solderable per MIL-STD-750, Method 2026 • A pprox. Weight: 0.055g / 0.002oz 2 Top View Marking Code: US1A~US1M Simplified outline SMA and symbol Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Symbols Parameter US1AG US1BG US1DG US1GG US1JG US1KG US1MG Units Maximum Repetitive Peak Reverse Voltage V RRM 50 100 200 400 600 800 1000 V Maximum RMS voltage V RMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage V DC 50 100 200 400 600 800 1000 V Maximum Average Forward Rectified Current at T c = 125 °C I F(AV) 1 A Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load I FSM 35 A Maximum Instantaneous Forward Voltage at 1 A VF Maximum DC Reverse Current T a = 25 °C at Rated DC Blocking Voltage T a =125 °C Maximum Reverse Recovery Time (1) Typical Thermal Resistance (2) Operating and Storage Temperature Range 1.0 1.3 1.65 5 100 IR t rr μA 75 50 V ns RθJA 75 °C/W T j , T stg -55 ~ +150 °C (1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A . (2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. 1 of 3 US1AG THRU US1MG Fig.2 Typical Reverse Characteristics Instaneous Reverse Current(μ A) Average Forward Current (A) Fig.1 Forward Current Derating Curve 1.2 1.0 0.8 0.6 0.4 0.2 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 175 100 T J =125°C 10 1.0 T J =25°C 0.1 00 Peak Forward Surage Current (A) Instaneous Forward Current (A) 10 T J =25°C 1.0 US1AG ~US1DG US1GG US1JG ~US1MG 0.01 0.001 0 0.5 1.0 1.5 2.0 40 60 80 100 120 140 Fig.4 Maximum Non-Repetitive Peak Forward Surage Current Fig.3 Typical Forward Characteristics 0.1 20 percent of Rated Peak Reverse Voltage (%) Case Temperature (°C) 40 35 30 25 20 15 10 05 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 2.5 Instaneous Forward Voltage (V) 10 Number of Cycles 2 of 3 100 US1AG THRU US1MG PACKAGE OUTLINE Plastic surface mounted package; 2 leads A A SMA c a VM e A HE g e E A D E HE c e g max 2.2 4.5 2.7 5.2 0.31 1.6 1.5 min 1.9 4.0 2.3 4.7 0.15 1.3 0.9 max 87 181 106 205 12 63 59 min 75 157 91 185 6 51 35 UNIT mm mil g e A D The recommended mounting pad size a 0.3 12 Marking Type number 2.4 (94) US1AG US1A US1BG US1B US1DG US1D US1GG US1G US1JG US1J US1KG US1K US1MG US1M 1.8 (71) 1.8 (71) 1.8 (71) Marking code mm Unit : (mil) 3 of 3
US1MG 价格&库存
很抱歉,暂时无法提供与“US1MG”相匹配的价格&库存,您可以联系我们找货
US1MG
    • 5000+0.03542
    库存:60000
    US1MG
    • 50+0.04800
    • 500+0.04320
    • 5000+0.04000
    • 10000+0.03840
    • 30000+0.03680
    • 50000+0.03584
    库存:5000
    US1MG
      • 5000+0.03542
      库存:90000
      US1MG
        • 5000+0.03542
        US1MG
          • 1+0.08250
          库存:7
          US1MG
            • 5000+0.03542
            库存:6000
            US1MG
            • 50+0.07559
            • 500+0.07110
            • 2000+0.06210
            • 5000+0.05760
            • 15000+0.05310
            • 30000+0.05085
            库存:6775
            US1MG
              • 5000+0.03542
              US1MG
                • 5000+0.03542
                库存:21000
                US1MG
                • 1+0.21120
                • 500+0.07051
                • 2500+0.04697
                • 5000+0.03850
                库存:15109
