US1MD
US1MD
    ST(先科)
    SMA(DO-214AC)
    VR=1000V IF=1A 17pF Trr=75ns
US1MD 数据手册
US1AD THRU US1MD SURFACE MOUNT ULTRAFAST RECOVERY RECTIFIER Reverse Voltage – 50 to 1000 V Forward Current – 1 A Features • For surface mount applications • Low profile package • Built-in strain relief • Easy pick and place • Ultrafast recovery times for high efficiency • Plastic package has Underwriters Laboratories Flammability Classification 94V-0 H C Mechanical Data • Case: SMA (DO-214AC) molded plastic • Terminals: Solder plated, solderable per MIL-STD-750, method 2026 guaranteed • Polarity: Color band denotes cathode end E T M E S Maximum Ratings and Electrical Characteristics Ratings at 25 OC ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load. For capacitive load, derate current by 20 %. Symbols US1AD US1BD US1DD US1GD US1JD US1KD US1MD Units Parameter Maximum Repetitive Peak Reverse Voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS Voltage VRMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage VDC 50 100 200 400 600 800 1000 V Maximum Average Forward Rectified Current at TL = 100 OC IF(AV) 1 A Peak Forward Surge Current 8.3 ms Single Half Sine-wave Superimposed on Rated Load (JEDEC Method) IFSM 30 A Maximum Forward Voltage at 1 A VF 1 1.4 1.7 V IR 5 100 μA Typical Junction Capacitance at 4 V, 1 MHz Cj 17 pF Maximum Reverse Recovery Time at IF = 0.5 A, IR = 1 A, Irr = 0.25 A trr Maximum DC Reverse Current at Rated DC Blocking Voltage Ta = 25 C Ta = 100 OC Typical Thermal Resistance 1) Operating and Storage Temperature Range 1) O 50 75 RθJA 50 Tj, Tstg - 55 to + 150 ns C/W O Mounted on P.C.B. with 0.2 X 0.2" (5 X 5 mm) copper pad areas. SEMTECH ELECTRONICS LTD. Subsidiary of Sino-Tech International (BVI) Limited ® C O Dated:28/02/2012 H Rev:01 US1AD THRU US1MD H C E T M E S SEMTECH ELECTRONICS LTD. Subsidiary of Sino-Tech International (BVI) Limited ® Dated:28/02/2012 H Rev:01
US1MD 价格&库存
很抱歉,暂时无法提供与“US1MD”相匹配的价格&库存,您可以联系我们找货
US1MD
  • 10+0.25510
  • 100+0.19829
  • 300+0.16978
  • 1000+0.14850
库存:2719
US1MD
