SE05D3W11GC
SE05D3W11GC
    SOCAY(硕凯)
    SOD-323
    ESD保护 VRWM=5V VBR(Min)=6V VC=20V IPP=24A SOD323
SE05D3W11GC 数据手册
Transient Voltage Suppressors for ESD Protection SE05D3W11GC Feature  Protects one I/O line or power line  Low clamping voltage  Working voltages : 5V  Low leakage current SOD-323 Applications  Cell Phone Handsets and Accessories  Microprocessor based equipment  Personal Digital Assistants (PDA’s)  Notebooks, Desktops, and Servers  Portable Instrumentation Functional Diagram Mechanical Characteristics  JEDEC SOD-323 Package  Molding Compound Flammability Rating : UL 94V-0  Quantity Per Reel : 3,000pcs  Reel Size : 7 inch Mechanical Characteristics Symbol Parameter Value Units TL Lead Soldering Temperature 260 (10sec) ºC TSTG Storage Temperature Range -55 to +150 ºC TOP Operating Temperature Range -55 to +150 ºC IEC61000-4-2 (ESD) Air Discharge ±15 Contact Discharge ±8 KV I-V Curve Characteristics Symbol Parameter IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP VRWM IF Working Peak Reverse Voltage IR Maximum Reverse leakage Current @ VRWM IT Test Current VB Breakdown Voltage @ IT IF Forward Current VF Forward Voltage @IF PPK Peak Power Dissipation C VC VB VRWM R V IT IR VF IPP Max Capacitance @VR=0V & f=1MHz SOCAY Electronics Corp., Ltd. Revision September I Uni-directional 20, 2018 www.socay.com 1/3 @ SOCAY Electronics Corp., Ltd. 2018 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Transient Voltage Suppressors for ESD Protection SE05D3W11GC Electrical Characteristics (@ 25℃ Unless Otherwise Specified ) Parameter Symbol Conditions Min Typ Max Unit Reverse Working Voltage VR --- --- --- 5.0 V Reverse Breakdown Voltage VBR IT = 1 mA 6.0 --- --- V Reverse Leakage Current IR VR = 5V --- --- 1.0 μA Clamping Voltage VC IPP = 1A, tp = 8/20μs --- --- 9.8 V IPP = 24A, tp = 8/20μs --- --- 20 V Junction Capacitance CJ VR = 0V, f = 1MHz --- 150 --- pF Characteristic Curves Fig1. 8/20μs Pulse Waveform Fig2. ESD Pulse Waveform (according to IEC 61000-4-2) tr 100 Peak Value IPP 80 100% TEST WAVEFORM PARAMETERS tr=8μs td=20μs Percent of Peak Pulse Current % IPP - Peak Pulse Current - % of IPP 120 60 40 td=t IPP/2 20 0 0 5 10 15 20 25 Time (ns) Fig4. ESD Clamping (-8KV Contac per IEC61000-4-2) SOCAY Electronics Corp., Ltd. 20, 2018 tr = 0.7~1ns 60ns ESD Clamping (+8KV Contac per IEC61000-4-2) Revision September 10% 30ns 30 t - Time (μs) Fig3. 90% www.socay.com 2/3 @ SOCAY Electronics Corp., Ltd. 2018 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Transient Voltage Suppressors for ESD Protection SE05D3W11GC SOD-323 Package Outline & Dimensions Millimeters Symbol Min. Nom. Max. Min. Nom. Max. A 0.80 0.90 1.00 0.031 0.035 0.040 A1 0.00 0.05 0.10 0.000 0.002 0.004 A3 Soldering Footprint 20, 2018 0.15 REF 0.006 REF b 0.25 0.32 0.40 0.010 0.012 0.016 C 0.089 0.12 0.177 0.003 0.005 0.007 D 1.60 1.70 1.80 0.062 0.066 0.070 E 1.15 1.25 1.35 0.045 0.049 0.053 L 0.08 HE 2.30 0.098 0.105 0.003 2.50 2.70 0.090 Symbol Millimeters Inches F 1.60 0.063 G 2.85 0.112 J 0.83 0.033 K 0.63 0.025 SOCAY Electronics Corp., Ltd. Revision September Inches www.socay.com 3/3 @ SOCAY Electronics Corp., Ltd. 2018 Specifications are subject to change without notice. Please refer to www.socay.com for current information.
SE05D3W11GC 价格&库存
很抱歉,暂时无法提供与“SE05D3W11GC”相匹配的价格&库存,您可以联系我们找货
