SE24D3T01GM
SE24D3T01GM
    SOCAY(硕凯)
    SOD-323
    ESD保护 VRWM=24V VBR(Min)=26.7V VC=30V IPP=9A SOD323
SE24D3T01GM 数据手册
Bi-directional TVS Diode for ESD Protection SE24D3T01GM Features  Protects one bi-directional I/O line  Low clamping voltage  Working voltages :24V  Low leakage current SOD-323 Main Applications  Cell Phone Handsets and Accessories  Microprocessor based equipment  Personal Digital Assistants (PDA’s)  Notebooks, Desktops, and Servers  Portable Instrumentation Functional Diagram Mechanical Characteristics  SOD-323 Package  Molding Compound Flammability Rating : UL 94V-0  Quantity Per Reel : 3,000pcs Absolute Maximum Ratings (TA=25℃,RH=45%-75%,unless otherwise noted) Parameter Symbol Value Units TSTG -55 to +150 ℃ Operating Junction Temperature Range TJ -55 to +125 ℃ Lead Soldering Temperature TL 260 (10 sec.) ℃ Storage Temperature Range ESD per IEC 61000-4-2 (Air) VESD ESD per IEC 61000-4-2 (Contact) ±15 ±8 KV I-V Curve Characteristics Symbol Parameter IPP Maximum Peak Pulse Current VC Clamping Voltage @ IPP VRWM IR VBR IT Working Peak Reverse Voltage Maximum Reverse Leakage Current @ VRWM Breakdown Voltage @ IT Test Current \ SOCAY Electronics Corp., Ltd. Revision September 20, 2018 www.socay.com 1/3 @ SOCAY Electronics Corp., Ltd. 2018 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Bi-directional TVS Diode for ESD Protection SE24D3T01GM Electrical Characteristics (TA= 25℃) Symbol Conditions Min Typ Max Unit VRwm --- --- --- 24 V VBR IT = 1 mA 26.7 --- --- V IR VR =24V,T=25℃ --- --- 1.0 μA VC IPP = 1A, tp = 8/20μs --- --- 40 V VC IPP = 6A, tp = 8/20μs --- --- 67 V CJ VR = 0V, f = 1MHz --- 23 --- pF Ratings and V-I Characteristics Curves (TA=25ºC, unless otherwise noted) Fig1. Pulse Waveform Fig3. Fig2. Pulse Derating Curve ESD Clamping (8KV Contact) SOCAY Electronics Corp., Ltd. Revision September 20, 2018 www.socay.com 2/3 @ SOCAY Electronics Corp., Ltd. 2018 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Bi-directional TVS Diode for ESD Protection SE24D3T01GM SOD-323 Package Mechanical Data Symbol SOCAY Electronics Corp., Ltd. Revision September 20, 2018 Inches Min. Max. Min. Max. A 1.60 1.80 0.063 0.071 B 0.25 0.35 0.010 0.014 C 2.50 2.70 0.098 0.106 D 0.00 1.00 0.000 0.039 E 1.20 1.40 0.047 0.055 F 0.08 0.15 0.003 0.006 L Land Pattern Millimeters 0.475REF 0.019REF L1 0.25 0.40 0.010 0.016 H 0.00 0.10 0.000 0.004 P 3.00 0.118 P1 0.80 0.031 www.socay.com 3/3 @ SOCAY Electronics Corp., Ltd. 2018 Specifications are subject to change without notice. Please refer to www.socay.com for current information.
SE24D3T01GM 价格&库存
很抱歉,暂时无法提供与“SE24D3T01GM”相匹配的价格&库存,您可以联系我们找货
