SM4007PL(A7)
SM4007PL(A7)
    YENJI(台湾元基)
    SOD-123F
    VR=1000V IF=1A 4pF
SM4007PL(A7) 数据手册
SM4001 THRU SM4007 GENERAL PURPOSE PLASTIC RECTIFIER 50V-1000V 1.0A FEATURES ¨ The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 ¨ Construction utilizes void-free molded plastic technique ¨ Low reverse leakage ¨ High forward surge current capability ¨ High temperature soldering guaranteed: 250°C/10 seconds, 0.375" (9.5mm) lead length, 5 lbs. (2.3kg) tension SOD-123FL MECHANICAL DATA Case: JEDEC SOD-123 molded plastic body Terminals: Plated axial leads, solderable per MIL-STD-750, Method 2026 Polarity: Color band denotes cathode end Mounting Position: Any Weight: 0.012 ounce, 0.3 gram MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25°C ambient temperature unless otherwise specified. SYMBOLS SM 4001PL SM 4002PL SM 4003PL SM 4004PL SM 4005PL SM 4006PL *Maximum repetitive peak reverse voltage VRRM 50 100 200 400 600 *Maximum RMS voltage VRMS 35 70 140 280 420 *Maximum DC blocking voltage VDC 50 100 200 400 600 *Maximum average forward rectified current 0.375" (9.5mm) lead length at T A=75°C I(AV) 1.0 Amp *Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) TA=75°C IFSM 30.0 Amps *Maximum instantaneous forward voltage at 1.0A VF 1.1 Volts *Maximum full load reverse current full cycle average 0.375" (9.5mm) lead length at TL=75°C IR(AV) 30.0 µA IR 5.0 50.0 µA trr 30.0 µs TA= 25°C TA=100°C *Maximum DC reverse current at rated DC blocking voltage Typical reverse recovery time Typical junction capacitance (NOTE 1) (NOTE 2) Typical thermal resistance (NOTE 3) Maximum DC blocking voltage temperature *Operating junction and storage temperature range SM 4007PL UNITS 800 1000 Volts 560 700 Volts 800 1000 Volts CJ 15.0 pF RΘJA RΘJL 50.0 25.0 °C/W TA +150 °C TJ, TSTG -50 to +175 °C NOTES: (1) Measured on Tektronix Type "S" recovery plug-in. Tektronix 545 Scope or equivalent, IFM=20mA, IRM=1mA (2) Measured at 1.0 MHz and applied reverse voltage of 4.0 Volts (3) Thermal resistance from junction to ambient and from junction to lead at 0.375" (9.5mm) lead length, P.C.B. mounted 1 SM4001 THRU SM4007 GENERAL PURPOSE PLASTIC RECTIFIER RATINGS AND CHARACTERISTIC CURVES 1.0 .8 .6 .4 Single Phase Half Wave 60Hz Resistive or Inductive Load .2 0 0 25 50 75 FIG. 2 - MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT PEAK FORWARD SURGE CURRENT, (A) AVERAGE FORWARD CURRENT, (A) FIG. 1 - TYPICAL FORWARD CURRENT DERATING CURVE 100 125 150 175 AMBIENT TEMPERATURE, ( ) 25 20 15 10 5 1 Pulse Width = 300us 1% Duty Cycle 1.0 1.2 1.4 1.6 INSTANTANEOUS FORWARD VOLTAGE, (V) 40 60 80 100 TJ = 100 10 5 1 .5 TJ = 25 .1 0 20 60 40 20 TJ = 25 2 1 1.0 2 4 10 20 40 REVERSE VOLTAGE, ( V ) 2 40 60 80 100 120 140 PERCENT OF RATED PEAK REVERSE VOLTAGE, (%) 100 .2 .4 20 50 200 .1 6 8 10 100 FIG. 5 - TYPICAL JUNCTION CAPACITANCE 10 6 4 4 NUMBER OF CYCLES AT 60Hz INSTANTANEOUS REVERSE CURRENT, (uA) T J = 25 .1 JUNCTION CAPACITANCE, (pF) INSTANTANEOUS FORWARD CURRENT, (A) 1.0 .8 2 FIG. 4 - TYPICAL REVERSE CHARACTERISTICS 10 .6 8.3ms Single Half Sine-Wave (JEDED Method) 0 FIG. 3 - TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS .01 .4 SM4001 THRU SM4007 100
SM4007PL(A7) 价格&库存
很抱歉,暂时无法提供与“SM4007PL(A7)”相匹配的价格&库存,您可以联系我们找货
SM4007PL(A7)
    • 50+0.04401
    • 500+0.04131
    • 2000+0.03591
    • 5000+0.03321
    • 15000+0.03051
    • 30000+0.02916
    库存:2145
