GBU6005 THRU GBU610
Reverse Voltage - 50 to 1000 Volts Forward Current - 6.0 Amperes
GLASS PASSIVATED BRIDGE RECTIFIERS
Features
GBU
Surge overload rating -175 amperes peak
.437(11.1)
.430(10.9)
Ideal for printed circuit board
Reliable low cost construction utilizing molded plastic technique
Plastic material has U/L lammability classification 94V-0
.126(3.2)*45°
CHAMFER
.874(22.2)
.860(21.8)
.154(3.9)
.146(3.7)
.752(19.1)
.720(18.3)
.232(5.9)
.224(5.7)
.401(10.2)
.392(9.80)
.073(1.85)
.057(1.45)
Mechanical Data
.100(2.54)
.085(2.16)
.720(18.29)
.680(17.27)
.047(1.2)
.035(0.9)
Case : JEDEC GBU Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
.080(2.03)
.065(1.65)
.210 .210
.190 .190
(5.3) (5.3)
(4.8) (4.8)
Maximum Ratings And Electrical Characteristics
.139(3.53)
.133(3.37)
.106(2.7)
.091(2.3)
.022(.56)
.018(.46)
.210
.190
(5.3)
(4.8)
Dimensions in inches and (millimeters)
Ratings at 25°C ambient temperature unless otherwisespecified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward(with heatsink NOTE 2)
Rectified current @T c =100°C(without heatsink)
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Rating for Fusing(t
很抱歉,暂时无法提供与“GBU606”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+2.90050
- 100+1.73030
- 200+1.21120
- 500+0.86510
- 1000+0.82190
- 5000+0.76130
- 国内价格
- 5+1.64872
- 50+1.33416
- 150+1.19938
- 500+0.96247
- 2500+0.88761
- 5000+0.84261
