KBL406
KBL406
    MDD(辰达半导体)
    KBL
    桥式整流器/整流桥 VRM=600V,IO=4.0A,IFSM=125A,VF=1.0V,IR=10uA
KBL406 数据手册
KBL4005 THRU KBL410 Reverse Voltage - 50 to 1000 V olts Forward Current - 4.0 Amperes SILICON BRIDGE RECTIFIERS Features KBL  The plastic package carries Underwriters Laboratory 0.768(19.5) 0.728(18.5) Flammability Classification 94V-0  Ideal for printed circuit boards  Low reverse leakage  High forward surge current capability 0.580(14.7) 0.540(13.7) 0.640(16.3) 0.598(15.2) +  High temperature soldering guaranteed: 260°C/10 seconds,0.375”(9.5mm) lead length, 5 lbs. (2.3kg) tension AC - 0.670 (17.0) 0.052(1.3) 0.046(1.18) Mechanical Data MIN. Case : JEDEC KBL Molded plastic body Terminals : Solder plated, solderable per MIL-STD-750,Method 2026 Polarity : Polarity symbol marking on body Mounting Position : Any Weight : 0.22 ounce , 6.21 grams 0.083 (2.1) 0.220(5.6) 0.180(4.6) 0.256(6.5) 0.217(5.5) Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25°C ambient temperature unlss otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. Parameter Marking Code Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward output rectified current at TA=50°C Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Rating for Fusing(t
KBL406 价格&库存
很抱歉,暂时无法提供与“KBL406”相匹配的价格&库存,您可以联系我们找货
KBL406
  • 50+0.85233
  • 500+0.83455
库存:40
KBL406
  • 5+1.82801
  • 50+1.49796
  • 150+1.35659
  • 500+0.95181
  • 2500+0.87318
  • 5000+0.82599
库存:22868
KBL406
    • 1+0.92085
    • 50+0.70875
    • 500+0.65310
    库存:520
    KBL406
    • 5+1.65875
    • 50+1.35926
    • 100+1.33887
    • 200+1.23098
    • 500+0.86367
    • 2500+0.79233
    库存:3117
