KBL4005 THRU KBL410
Reverse Voltage - 50 to 1000 V olts
Forward Current - 4.0 Amperes
SILICON BRIDGE RECTIFIERS
Features
KBL
The plastic package carries Underwriters Laboratory
0.768(19.5)
0.728(18.5)
Flammability Classification 94V-0
Ideal for printed circuit boards
Low reverse leakage
High forward surge current capability
0.580(14.7)
0.540(13.7)
0.640(16.3)
0.598(15.2)
High temperature soldering guaranteed:
260°C/10 seconds,0.375”(9.5mm) lead length, 5
lbs. (2.3kg) tension
AC
0.670
(17.0)
0.052(1.3)
0.046(1.18)
Mechanical Data
MIN.
Case : JEDEC KBL Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.22 ounce , 6.21 grams
0.083
(2.1)
0.220(5.6)
0.180(4.6)
0.256(6.5)
0.217(5.5)
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unlss otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward
output rectified current at
TA=50°C
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Rating for Fusing(t
很抱歉,暂时无法提供与“KBL410”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.63080
- 50+1.32009
- 150+1.18692
- 500+0.88776
- 2500+0.81378
- 5000+0.76929
- 国内价格
- 1+0.95480
- 50+0.73480
- 500+0.67650
- 国内价格
- 50+0.74580
- 1000+0.71472
