KBU606
KBU606
    MDD(辰达半导体)
    KBU
    耐压:600V 电流:6A
KBU606 数据手册
KBU6005 THRU KBU610 Reverse Voltage - 50 to 1000 Volts Forward Current - 6.0 Amperes SILICON BRIDGE RECTIFIERS Features KBU  The plastic package carries Underwriters Laboratory .157(4.0)*45° Flammability Classification 94V-0 0.935(23.7) 0.895(22.7)  Ideal for printed circuit boards  Low reverse leakage 0.15 x0.23L (3.8 x5.7L) HOLE THRU 0.300 (7.5) 0.700(17.8) 0.600(16.8)  High forward surge current capability  High temperature soldering guaranteed: 260°C/10 seconds,0.375”(9.5mm) lead length, 0.780(19.8) 0.740(18.8) AC 5 lbs. (2.3kg) tension 0.669 MIN. (17.0) 0.866 MIN. (22.0) Mechanical Data 0.052(1.3) DIA. 0.048(1.2) Case : JEDEC KBU Molded plastic body Terminals : Solder plated, solderable per MIL-STD-750,Method 2026 Polarity : Polarity symbol marking on body Mounting Position : Any Weight : 0.27ounce,7.59grams 0.220(5.6) 0.180(4.6) 0.087(2.2) 0.071(1.8) 0.280(7.1) 0.236(6.0) Maximum Ratings And Electrical Characteristics Dimensions in inches and (millimeters) Ratings at 25°C ambient temperature unless otherwisespecified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. Parameter Marking Code Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward output rectified current at TA=100 ℃ Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Maximum instantaneous forward voltage drop per birdge element at 6.0A Maximum DC reverse current TA=25°C at rated DC blocking voltage TA=125°C Typical Junction Capacitance Typical Thermal Resistance (Note 1) Operating junction temperature range storage temperature range SYMBOLS VRRM VRMS VDC MDD MDD KBU6005 KBU601 50 35 50 100 70 100 MDD KBU602 MDD KBU604 MDD KBU606 MDD KBU608 MDD KBU610 UNITS 200 140 200 400 280 400 600 420 600 800 560 800 1000 700 1000 V V V I(AV) 6.0 A IFSM 250 A VF 1.1 V 10 1.0 200 2.7 -55 to +150 -55 to +150 μA mA pF °C/W °C °C IR CJ RθJA TJ TSTG NOTES: 1.Thermal resistance from Junction to Ambemt on P.C.board mounting. http://www.microdiode.com Rev:2024A3 Page :1 KBU6005 THRU KBU610 Reverse Voltage - 50 to 1000 Volts Forward Current - 6.0 Amperes Ratings And Characteristic Curves Fig. 2 Maximum Non-repetitive Peak Forward Surge Current Fig. 1 Derating Curve for Output Rectified Current 250 Peak Forward Surge Current, Amperes Average Forward Output Current, Amperes 6.0 4.0 60Hz Resistive of Inductive Load 2.0 0 0 50 100 8.3ms Single half-sine-Wave [JEDEC Method] 200 150 100 50 10 1 100 Number of Cycles at 60HZ 150 o Fig. 4 Typical Reverse Characteristics Case Temperature, C 10 Fig. 3 Typical Instantaneous Forward Characteristics Tc=100 C Instantaneous Reverse Current ,Amperes 100 40 10 4.0 1.0 0.1 TA=25 C .01 0 20 40 60 80 100 120 140 Percent of Rated Peak Reverse Voltage, % 0.1 Tj=25 C Pulse Width=300us 2% duty cycle .01 0.6 0.7 0.8 0.9 1.0 1.1 Fig. 5 Typical Junction Capacitance 1.2 Instantaneous Forward Voltage, Volts 400 1.3 Capacitance, pF Instantaneous Forward Current, Amperes 20 1.0 100 10 Tj=25 C f=1.0MHz Ving =50mV p.p. 1 1.5 2 10 100 Reverse Voltage, Volts The curve above is for reference only. http://www.microdiode.com Rev:2024A3 Page :2
KBU606
- 物料型号:KBU6005至KBU610 - 器件简介:这些硅桥整流器具有50至1000伏的反向电压和6.0安培的正向电流。 - 引脚分配:未在文档中明确说明,但通常桥整流器有四个引脚,两个用于交流输入,两个用于直流输出。 - 参数特性: - 反向电压:50至1000伏特 - 正向电流:6.0安培(在100°C时,需要散热器) - 正向浪涌电流:175安培(对于KBU602型号) - 正向电压降:在6.0安培时,最大为1.0伏特 - 反向漏电流:在25°C时,最大为10微安培,在100°C时,最大为1.0毫安培 - 结电容:典型值为200皮法拉 - 热阻:典型值为4.7°C/W - 工作结温范围:-55至+150°C - 存储温度范围:-55至+150°C - 功能详解: - 这些整流器适合用于印刷电路板,具有低反向漏电流和高正向浪涌电流能力。 - 塑料封装符合UL94V-0可燃性分类,适合高温焊接。 - 极性符号在封装上标记,通过孔安装适用于#6螺丝,最大5英寸磅扭矩。 - 重量为0.27盎司(7.59克)。 - 应用信息:适用于需要高反向电压和正向电流的电路,如电源整流。 - 封装信息:封装为模塑塑料体,引脚为电镀可焊接引线。
KBU606 价格&库存
很抱歉,暂时无法提供与“KBU606”相匹配的价格&库存,您可以联系我们找货
KBU606
  • 5+2.77688
  • 50+2.31384
  • 150+2.11531
  • 400+1.86777
  • 2400+1.75746
  • 4800+1.69125
