MB2F THRU MB10F
SINGLE PHASE GLASS PASSIVATED BRIDGE RECTIFIERS
Voltage Range - 200 to 1000 Volts Current - 0.5/0.8 Ampere
MBF
FEATURES
Glass passivated die construction
Low forward voltage drop
High current capability
High surge current capability
Designed for surface mount application
Plastic material-UL flammability 94V-0
MECHANICAL DATA
Case: MBF,molded plastic
Terminals: Plated leads solderable per MIL-STD-750,
Method 2026
Polarity: Polarity symbols marked on case
Mounting Position: Any
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load, for capacitive load derate current by 20%.
MDD Catalog Number
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TC=30
On glass-epoxy P.C.B.
On aluminum substrate
Peak forward surge current,
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage drop
per leg at 0.5A
Maximum DC reverse current
TJ =25
at rated DC blocking voltage
TJ =125
Typical junction capactiance per leg(Note3)
Typical thermal resistance per leg
Operating temperature range
storage temperature range
SYMBOLS
VRRM
VRMS
VDC
IF(AV)
MDD
MB2F
MDD
MB4F
MDD
MB6F
MDD
MB8F
MDD
MB10F
UNITS
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
VOLTS
VOLTS
VOLTS
0.5
Amps
0.8
IFSM
30
Amps
VF
1.1
Volts
5.0
500
13
60
-55 to +150
-55 to +150
uA
uA
IR
CJ
R JA
TJ
TSTG
pF
/W
NOTES:1.On glass epoxy P.C.B. mounted on 0.05x0.05''(1.3x1.3mm) pads
2.On aluminum substrate P.C.B. with on area of 0.8''x0.8''(20x20mm) mounted on 0.05X0.05''(1.3X1.3mm) solder pad
3.Measured at 1.0MHz and applied reverse voltage of 4.0 volts.
Fig. 2 Typical Forward Characteristics (per leg)
Fig. 1 Output Current Derating Curve
IF, INSTANTANEOUS FORWARD CURRENT (A)
I(AV), AVERAGE FORWARD RECTIFIED CURRENT (A)
RATINGS AND CHARACTERISTIC CURVES MB2F THRU MB10F
1.0
0.8
Al. Substrate PC Board
0.6
0.4
Glass Epoxy PC Board
0.2
Resistive or Inductive Load
80
120
10
1.0
0.1
TA= 25°C
Pulse Width = 300µs
0.01
0.2
160
0.6
0.8
1.0
1.2
1.4
1.6
VF, INSTANTANEOUS FORWARD VOLTAGE (V)
TA, AMBIENT TEMPERATURE (°C)
Fig. 3 Maximum Peak Forward Surge Current (per leg)
35
Fig. 4 Typical Junction Capacitance
100
TJ = 25°C
f = 1.0MHz
30
Cj, JUNCTION CAPACITANCE (pF)
IFSM, PEAK FORWARD SURGE CURRENT (A)
0.4
TA = 25°C
Single Half Sine-Wave
Pulse Width =8.3ms
(JEDEC Method)
1.0
10
1
10
NUMBER OF CYCLES AT 60 Hz
1
10
VR, REVERSE VOLTAGE (V)
The cruve graph is for reference only, can't be the basis for judgment(曲线图仅供参考)!
100
很抱歉,暂时无法提供与“MB10F 46MIL”相匹配的价格&库存,您可以联系我们找货
