MB10F 50MIL
MB10F 50MIL
    MDD(辰达半导体)
    MBF
    Vr=1000V VF=1.1@500mA
MB10F 50MIL 数据手册
MB2F THRU MB10F SINGLE PHASE GLASS PASSIVATED BRIDGE RECTIFIERS Voltage Range - 200 to 1000 Volts Current - 0.5/0.8 Ampere MBF FEATURES Glass passivated die construction Low forward voltage drop High current capability High surge current capability Designed for surface mount application Plastic material-UL flammability 94V-0 MECHANICAL DATA Case: MBF,molded plastic Terminals: Plated leads solderable per MIL-STD-750, Method 2026 Polarity: Polarity symbols marked on case Mounting Position: Any Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25 ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load, for capacitive load derate current by 20%. MDD Catalog Number Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current at TC=30 On glass-epoxy P.C.B. On aluminum substrate Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Maximum instantaneous forward voltage drop per leg at 0.5A Maximum DC reverse current TJ =25 at rated DC blocking voltage TJ =125 Typical junction capactiance per leg(Note3) Typical thermal resistance per leg Operating temperature range storage temperature range SYMBOLS VRRM VRMS VDC IF(AV) MDD MB2F MDD MB4F MDD MB6F MDD MB8F MDD MB10F UNITS 200 140 200 400 280 400 600 420 600 800 560 800 1000 700 1000 VOLTS VOLTS VOLTS 0.5 Amps 0.8 IFSM 30 Amps VF 1.1 Volts 5.0 500 13 60 -55 to +150 -55 to +150 uA uA IR CJ R JA TJ TSTG pF /W NOTES:1.On glass epoxy P.C.B. mounted on 0.05x0.05''(1.3x1.3mm) pads 2.On aluminum substrate P.C.B. with on area of 0.8''x0.8''(20x20mm) mounted on 0.05X0.05''(1.3X1.3mm) solder pad 3.Measured at 1.0MHz and applied reverse voltage of 4.0 volts. Fig. 2 Typical Forward Characteristics (per leg) Fig. 1 Output Current Derating Curve IF, INSTANTANEOUS FORWARD CURRENT (A) I(AV), AVERAGE FORWARD RECTIFIED CURRENT (A) RATINGS AND CHARACTERISTIC CURVES MB2F THRU MB10F 1.0 0.8 Al. Substrate PC Board 0.6 0.4 Glass Epoxy PC Board 0.2 0 Resistive or Inductive Load 0 40 80 120 10 1.0 0.1 TA= 25°C Pulse Width = 300µs 0.01 0.2 160 0.6 0.8 1.0 1.2 1.4 1.6 VF, INSTANTANEOUS FORWARD VOLTAGE (V) TA, AMBIENT TEMPERATURE (°C) Fig. 3 Maximum Peak Forward Surge Current (per leg) 35 Fig. 4 Typical Junction Capacitance 100 TJ = 25°C f = 1.0MHz 30 Cj, JUNCTION CAPACITANCE (pF) IFSM, PEAK FORWARD SURGE CURRENT (A) 0.4 20 10 0 TA = 25°C Single Half Sine-Wave Pulse Width =8.3ms (JEDEC Method) 1.0 10 1 10 NUMBER OF CYCLES AT 60 Hz 1 10 VR, REVERSE VOLTAGE (V) The cruve graph is for reference only, can't be the basis for judgment(曲线图仅供参考)! 100
MB10F 50MIL 价格&库存
很抱歉,暂时无法提供与“MB10F 50MIL”相匹配的价格&库存,您可以联系我们找货
