MB2S THRU MB10S
SINGLE PHASE GLASS PASSIVATED BRIDGE RECTIFIERS
Voltage Range - 200 to 1000 Volts Current - 0.5/0.8 Ampere
FEATURES
MBS
Ideal for printed circuit board
Reliable low cost construction utilizing
molded plastic technique
High temperature soldering guaranteed:
260 /10 seconds at 5 lbs., (2.3kg) tension
Small size, simple installation
High surge current capability
0.028 0.7
0.010 0.25
MECHANICAL DATA
0.067(1.7)
Case: Molded plastic body
Terminals: Plated leads solderable per MIL-STD-750,
Method 2026
Polarity: Polarity symbols marked on case
Mounting Position: Any
Weight:0.008 ounce, 0.22 grams
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load, for capacitive load derate current by 20%.
MDD Catalog Number
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TC=30
On glass-epoxy P.C.B.
On aluminum substrate
Peak forward surge current,
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage drop
per leg at 0.4A
Maximum DC reverse current
TA=25
at rated DC blocking voltage
TA=125
Typical junction capactiance per leg(Note3)
Typical thermal resistance per leg
Operating temperature range
storage temperature range
SYMBOLS
VRRM
VRMS
VDC
IF(AV)
MDD
MB2S
MDD
MB4S
MDD
MB6S
MDD
MB8S
MDD
MB10S
UNITS
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
VOLTS
VOLTS
VOLTS
0.5
0.8
Amps
IFSM
30
Amps
VF
1.0
Volts
5.0
500
13
70
-55 to +150
-55 to +150
uA
uA
IR
CJ
R JA
TJ
TSTG
pF
/W
NOTES:1.On glass epoxy P.C.B. mounted on 0.05x0.05''(1.3x1.3mm) pads
2.On aluminum substrate P.C.B. with on area of 0.8''x0.8''(20x20mm) mounted on 0.05X0.05''(1.3X1.3mm) solder pad
3.Measured at 1.0MHz and applied reverse voltage of 4.0 volts.
AVERAGE FORWARD RECTIFIED
CURRENT(A)
FIG. 1- DERATING CURVE OUTPUT RECTIFIED
CURRENT FOR
0.8
Aluminum Substrate
0.7
0.6
0.5
0.4
Glass Epoxy
P.C.B.
0.3
0.2
0.1
PEAK FORWARD SURGE CURRENT.(A)
RATINGS AND CHARACTERISTIC CURVES MB2S THRU MB10S
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT PERLEG
35
30
Ta=40
Single Half Sine-Wave
(JEDEC Method)
25
f=60Hz
f=50Hz
10
5
1Cycle
60
80
100
120
140
160
10
AMBIENT TEMPERATURE,( )
10
1
0.01
0.2 0.4
TJ=25
Pulse Width=300us
1% Duty Cycle
0.6
0.8
1.0
1.2
1.4
FIG. 4-TYPICAL REVERSE LEAKAGE
CHARACTERISTICS PER LEG
INSTANTANEOUS REVERSE LEAKAGE
CURRENT.(uA)
INSTANTANEOUS FORWARD
CURRENT(A)
FIG. 3-TYPICAL FORWARD VOLTAGE
0.1
100
NUMBER OF CYCLES
100
TJ=125
10
1
0.1
TJ=25
1.6
0.01
JUNCTION CAPACITANCE.(pF)
FIG. 5-TYPICAL JUNCTION CAPACTITANE
PER LEG
30
25
TJ=25
f=1.0MHZ
Vsig=50mV p-p
10
5
60
80
100
PERCENT OF RATED PEAK REVERSE VOLTAGE(%)
INSTANTANEOUS FORWARD VOLTAGE.(V)
1
10
100
200
REVERSE VOLTAGE.(V)
The cruve graph is for reference only, can't be the basis for judgment(曲线图仅供参考)!
很抱歉,暂时无法提供与“MB10S 46MIL”相匹配的价格&库存,您可以联系我们找货
